September 14, 2005, 04:53 |
Binary mode donbt work
Fabian Peng Karrholm
I have a bit of a strange problem with OpenFOAM 1.2. When I have a mesh or a saved solution that's been saved in binary format, I can't use it for restarting the case or postprocessing with ParaFoam.
It doesn't matter if it's a mesh generated in gambit and converted, or if it's generated with blockMesh. It only works if I use the ascii format. I get this message: --> FOAM FATAL IO ERROR : Expected a ')' while reading binaryBlock, found on line 29 an error file: ../refnozzleLES.ver12.schemetest/0.00204928/nuSgs at line 29. From function Istream::readEnd(const char*) in file db/IOstreams/IOstreams/Istream.C at line 111. What have I done wrong? /Fabian |
September 14, 2005, 04:58 |
Just out of interest, are you
Mattijs Janssens
Rep Power: 26 |
Just out of interest, are you running with compression and if so what happens if you switch off compression?
September 14, 2005, 04:59 |
Hmm, I've been using binary wi
Hrvoje Jasak
Rep Power: 33 |
Hmm, I've been using binary without problems a few days ago; however, compressed binary did not work. Did you use compression of the files (i.e. .gz extension on nuSgs)?
Hrv
September 14, 2005, 05:03 |
Yes, I always do. However, now
Yes, I always do. However, now I just noticed that it works if I turn off compression. Does Foam 1.2 use a new version of gzip?
/Fabian |
September 20, 2005, 11:27 |
Hi Fabian,
can you post thi
Mattijs Janssens
Rep Power: 26 |
Hi Fabian,
can you post this as a bug? |
May 21, 2006, 12:17 |
Can anyone post the fix of thi
Maka Mohu
Rep Power: 18 |
Can anyone post the fix of this bug. I'm still using V 1.2. Thanks.
Kind regards, Maka |
[PyFoam] Problems with the new PyFoam release | zfaraday | OpenFOAM Community Contributions | 13 | December 9, 2014 19:58 |
[PyFoam] having problems with pyfoam Installation | vitorspadetoventurin | OpenFOAM Community Contributions | 3 | December 2, 2014 08:18 |
Grid Check Fails in Parallel Processing Mode | askance | Main CFD Forum | 0 | October 20, 2010 11:11 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 16:45 |
Sliding mesh error | Karl Kevala | FLUENT | 4 | February 21, 2001 16:52 |
