What does it mean?
I put the data in blockMeshDict:
*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.5 | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (0 0 0) //0 (0.001 0 0)//1 (0.001 0.001 0)//2 (0 0.001 0)//3 (0 0 0.01)//4 (0.001 0 0.01)//5 (0.001 0.001 0.01)//6 (0 0.001 0.01)//7 (0 0 0.011)//8 (0.001 0 0.011)//9 (0.001 0.001 0.011)//10 (0 0.001 0.011)//11 (0.006 0 0.011)//12 (0.006 0 0.01)//13 (0.006 0.001 0.01)//14 (0.006 0.001 0.011)//15 ); blocks ( hex (0 1 2 3 4 5 6 7) (5 5 50) simpleGrading (1 1 1) hex (4 5 6 7 8 9 10 11) (5 5 5) simpleGrading (1 1 1) hex (5 6 10 9 12 13 14 15) (25 5 5) simpleGrading (1 1 1) ); edges ( ); patches ( patch inlet ( (3 2 1 0) ) patch outlet ( (15 12 13 14) ) wall walls ( (5 1 2 6) (6 2 3 7) (3 7 4 0) (0 1 5 4) (4 5 9 8) (9 10 11 8) (8 11 7 4) (10 6 7 11) (10 15 14 6) (9 12 15 10) (9 5 13 12) (5 6 14 13) ) ); mergePatchPairs ( ); And the message that I get was: face 8 in patch 2 does not have neighbour cell face: 4(10 15 14 6) What I can do? Thanks |
There don't seems to be anything wrong with the patches.
But maybe you can try to change the third block to Code:
hex (5 6 10 9 13 14 15 12) (25 5 5) simpleGrading (1 1 1) |
Thanks
Thank you! Danke! |
Hi
No, but I did an mistake in the points! Thanks |
