nonAlignedEdge?
Dear OpenFOAMers,
I generated a mesh of axisymetric tube using blockMesh. When checked using checkMesh, I got the following message: ***Number of edges not aligned with or perpendicular to non-empty directions: 280332 <<Writing 287066 points on non-aligned edges to set nonAlignedEdges and checkMesh saved the noneAlignedEdges to polyMesh/sets. Can someone explain what it means? When plotting with paraFoam, the mesh looked fine though. Pei |
Hey Fomer,
I got the same problem. Have you gotten a solution to solve this problem. Kinda regards Claus |
It's quite an old questions but maybe someone has a look here when facing this problem.
I found something about it on the OpenFOAM Wiki website. Paragraph 9 is the important one. http://openfoamwiki.net/index.php/Si...vaned_diffuser Lars |
I got those 'nonAligned' issues..but after defining my patches properly with b.cs it gets
eliminated. |
I also got those issues, but after propertly naming all my patches it disappeared, like ramhari said.
This is probably too late for replying this question. But I hope it will help the others, who will have the same problem in the future. I had the same problem. And I solved the problem by renaming all the points labels.
Hi all,
I had the same issue and I could solve it simply using "flattenMesh" command. In particular, in my case I generated 2D mesh with extrudeMesh utility (starting from 3D mesh). Then, "checkMesh" command decteted "Number of edges not aligned with or perpendicular to non-empty directions" error. I solved it with "flattenMesh" after declaring the empty patches in "constant/polyMesh/boundary" files. I hope this can help Others. bye :) |
Hi all,
I'm having this exact same problem of the edges no aligned and tried almost everything I saw it could solve the problem and it didn't work out. The checkMesh still complains about those edges. Can anyone help me? |
Hi ltiago94,
if you execute "checkMesh" before "extrudeMesh" command, do you get the error related to non alligned edges? |
Hello, I was able to solve this issue. After snappyhexmesh I ran flattenMesh. Then created a folder which the extrudeMesh was getting the information of. I copied the constant and system folder to that new folder and erased the polymesh case inside the original constant. After that i ran extrudeMesh and it was ok.
Thanks |
This happens if your mesh is more than one cell layer thick in the rotation direction.
