[Commercial meshers] Problems after converting a CCM Model
Old   November 13, 2009, 06:30
Default Problems after converting a CCM Model
sErik is on a distinguished road
Hello everyone,
I'm studying aerospace engineering at the Technical University of Munich. I have just begun working with OpenFOAM, so I'm still a rookie with the software.
Right now, I have completed all the tutorials and exercises and I would like to start s small own example, but I have several questions.
What exactly is FoamX? I haven't found any specific information neither in the User's Guide nor in the Programmer's Guide. Could you please help me with this problem? Moreover, where can I download the programm, or is it already included in the standard OpenFOAM 1.6 installation?
Are there any ohter methods to integrate the boundary conditions? I have converted a CCM Model with ccm26ToFoam, but now I have trouble with the definitions of the blockMeshDict. How can I automatically define the vertices, without having to name every each of them? Shouldn't they already be made by ccm26ToFoam?
Thanks for your held, I might need some more help for the general understandig of OpenFOAM's behaviour
Greetings,
Erik
sErik is offline   Reply With Quote
Old   November 13, 2009, 06:47
Anonymous
madad2005 is on a distinguished road
If you have converted a ccm+ mesh to foam, then you don't need the blockMeshDict file. This is for the block-structured mesher that comes with foam called blockMesh. If you have named your boundaries properly in ccm+ before converting it, then you should have a list of your boundaries in the <casedir>/constant/polyMesh/boundary file. You specify the specific boundary conditions to apply at each of these boundary zones listed in <casedir>/0 directory, like in the other tutorials.
Does that help at all?
madad2005 is offline   Reply With Quote
Old   November 13, 2009, 07:53
Hi madad2005,
thank you for your help, yes it helps! I deleted all old files in the case, reconverted the .ccm-file and now worked fine.
Now I can see the mesh in ParaView. But the problem is, when I want to apply "p" to the mesh in ParaView, the programm crashes. Here's the error message:
__________________________________________________
keyword ground is undefined in dictionary "/home/fa1/OpenFOAM/eschirach/run/testmodelle/uebung_box/box_ccm/0/p::boundaryField"
file: /home/fa1/OpenFOAM/eschirach/run/testmodelle/uebung_box/box_ccm/0/p::boundaryField from line 21 to line 49.
From function dictionary::subDict(const word& keyword) const
in file db/dictionary/dictionary.C at line 449.
FOAM exiting
I don't know why "ground" should be undefined in p
Here's the "p" file:
version 2.0;
format ascii;
class volScalarField;
location "";
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0.000000;
boundaryField
ground_1
type zeroGradient;
ground_2
type zeroGradient;
step
type zeroGradient;
top
type zeroGradient;
outlet
type cyclic;
inlet
type empty;
right
type wall;
left
type wall;
Actually, there's no keyword ground at all?!
Old   November 13, 2009, 07:57
Anonymous
I've got a feeling you can't use the underscore ('_') when defining patches. Change it to a '-' and it should work.
Old   November 13, 2009, 08:57
I did as you said. I even tried different combinations, like deleting all "_" or "-" or replacing the "2" by an "a".
The Mesh in ParaView is fine, an I even see the different nominations in the"Mesh Parts", but when I like to apply either "p" or "U" it crashes, with followiong statement:
__________________________________________________ _________________________
Attempt to cast type patch to type lduInterface#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/opt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 Foam::Ostream& Foam:perator<< <Foam::error>(Foam::Ostream&, Foam::errorManip<Foam::error>) addr2line failed
#3 Foam::lduInterface const& Foam::refCast<Foam::lduInterface const, Foam::fvPatch const>(Foam::fvPatch const&) in "/opt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so"
#4 Foam::cyclicFvPatchField<double>::cyclicFvPatchFie ld(Foam::fvPatch const&, Foam:imensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so"
#5 Foam::fvPatchField<double>::adddictionaryConstruct orToTable<Foam::cyclicFvPatchField<double> >::New(Foam::fvPatch const&, Foam:imensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so"
#6 Foam::fvPatchField<double>::New(Foam::fvPatch const&, Foam:imensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) addr2line failed
#7 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::GeometricB oundaryField(Foam::fvBoundaryMesh const&, Foam:imensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so"
#8 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readField(Foam::Istream&) in "/opt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so"
#9 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) in "/opt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so"
#10 void Foam::vtkPV3Foam::convertVolFields<double>(Foam::f vMesh const&, Foam::PtrList<Foam::PrimitivePatchInterpolation<Fo am::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > > > const&, Foam::IOobjectList const&, vtkMultiBlockDataSet*) in "/opt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libvtkPV3Foam.so"
#11 Foam::vtkPV3Foam::convertVolFields(vtkMultiBlockDa taSet*) in "/opt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libvtkPV3Foam.so"
#12 Foam::vtkPV3Foam::Update(vtkMultiBlockDataSet*, vtkMultiBlockDataSet*) in "/opt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libvtkPV3Foam.so"
#13 vtkPV3FoamReader::RequestData(vtkInformation*, vtkInformationVector**, vtkInformationVector*) in "/opt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libPV3FoamReader_SM.so"
#14 vtkExecutive::CallAlgorithm(vtkInformation*, int, vtkInformationVector**, vtkInformationVector*) addr2line failed
#15 vtkDemandDrivenPipeline::ExecuteData(vtkInformatio n*, vtkInformationVector**, vtkInformationVector*) in "/opt/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linux64Gcc/bin/libvtkFiltering.so.pv3.6"
#16 vtkCompositeDataPipeline::ExecuteData(vtkInformati on*, vtkInformationVector**, vtkInformationVector*) in "/opt/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linux64Gcc/bin/libvtkFiltering.so.pv3.6"
#17 vtkDemandDrivenPipeline::ProcessRequest(vtkInforma tion*, vtkInformationVector**, vtkInformationVector*) in "/opt/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linux64Gcc/bin/libvtkFiltering.so.pv3.6"
#18 vtkStreamingDemandDrivenPipeline::ProcessRequest(v tkInformation*, vtkInformationVector**, vtkInformationVector*) in "/opt/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linux64Gcc/bin/libvtkFiltering.so.pv3.6"
#19 vtkCompositeDataPipeline::ProcessRequest(vtkInform ation*, vtkInformationVector**, vtkInformationVector*) in "/opt/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linux64Gcc/bin/libvtkFiltering.so.pv3.6"
#20 vtkCompositeDataPipeline::ForwardUpstream(vtkInfor mation*) addr2line failed
#21 vtkDemandDrivenPipeline::ProcessRequest(vtkInforma tion*, vtkInformationVector**, vtkInformationVector*) in "/opt/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linux64Gcc/bin/libvtkFiltering.so.pv3.6"
#22 vtkStreamingDemandDrivenPipeline::ProcessRequest(v tkInformation*, vtkInformationVector**, vtkInformationVector*) in "/opt/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linux64Gcc/bin/libvtkFiltering.so.pv3.6"
#23 vtkCompositeDataPipeline::ProcessRequest(vtkInform ation*, vtkInformationVector**, vtkInformationVector*) in "/opt/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linux64Gcc/bin/libvtkFiltering.so.pv3.6"
#24 vtkCompositeDataPipeline::ForwardUpstream(vtkInfor mation*) in "/opt/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linux64Gcc/bin/libvtkFiltering.so.pv3.6"
#25 vtkDemandDrivenPipeline::ProcessRequest(vtkInforma tion*, vtkInformationVector**, vtkInformationVector*) addr2line failed
#26 vtkStreamingDemandDrivenPipeline::ProcessRequest(v tkInformation*, vtkInformationVector**, vtkInformationVector*) in "/opt/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linux64Gcc/bin/libvtkFiltering.so.pv3.6"
#27 vtkCompositeDataPipeline::ProcessRequest(vtkInform ation*, vtkInformationVector**, vtkInformationVector*) in "/opt/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linux64Gcc/bin/libvtkFiltering.so.pv3.6"
#28 vtkDemandDrivenPipeline::UpdateData(int) in "/opt/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linux64Gcc/bin/libvtkFiltering.so.pv3.6"
#29 vtkStreamingDemandDrivenPipeline::Update(int) in "/opt/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linux64Gcc/bin/libvtkFiltering.so.pv3.6"
#30 vtkPVUpdateSuppressor::ForceUpdate() addr2line failed
#31 vtkPVUpdateSuppressorCommand(vtkClientServerInterp reter*, vtkObjectBase*, char const*, vtkClientServerStream const&, vtkClientServerStream&) in "/opt/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linux64Gcc/bin/libvtkPVFiltersCS.so"
#32 vtkClientServerInterpreter::ProcessCommandInvoke(v tkClientServerStream const&, int) addr2line failed
#33 vtkClientServerInterpreter::ProcessOneMessage(vtkC lientServerStream const&, int) in "/opt/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linux64Gcc/bin/libvtkClientServer.so"
#34 vtkClientServerInterpreter::ProcessStream(vtkClien tServerStream const&) in "/opt/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linux64Gcc/bin/libvtkClientServer.so"
#35 vtkSelfConnection::ProcessStreamLocally(vtkClientS erverStream&) in "/opt/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linux64Gcc/bin/libvtkPVServerCommon.so"
#36 vtkProcessModuleConnection::SendStream(unsigned int, vtkClientServerStream&) in "/opt/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linux64Gcc/bin/libvtkPVServerCommon.so"
#37 vtkProcessModuleConnectionManager::SendStream(long long, unsigned int, vtkClientServerStream&, int) in "/opt/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linux64Gcc/bin/libvtkPVServerCommon.so"
#38 vtkProcessModule::SendStream(long long, unsigned int, vtkClientServerStream&, int) in "/opt/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linux64Gcc/bin/libvtkPVServerCommon.so"
#39 vtkSMProxy::UpdateProperty(char const*, int) in "/opt/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linux64Gcc/bin/libvtkPVServerManager.so"
#40 vtkSMSimpleStrategy::UpdatePipeline() addr2line failed
#41 vtkSMRepresentationStrategy::Update() in "/opt/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linux64Gcc/bin/libvtkPVServerManager.so"
#42 vtkSMDataRepresentationProxy::Update(vtkSMViewProx y*) addr2line failed
#43 vtkSMPVRepresentationProxy::Update(vtkSMViewProxy* ) in "/opt/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linux64Gcc/bin/libvtkPVServerManager.so"
#44 vtkSMViewProxy::UpdateAllRepresentations() in "/opt/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linux64Gcc/bin/libvtkPVServerManager.so"
#45 vtkSMViewProxy::StillRender() in "/opt/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linux64Gcc/bin/libvtkPVServerManager.so"
#46 pqView::qt_metacall(QMetaObject::Call, int, void**) addr2line failed
#47 pqRenderViewBase::qt_metacall(QMetaObject::Call, int, void**) in "/opt/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linux64Gcc/bin/libpqCore.so"
#48 pqRenderView::qt_metacall(QMetaObject::Call, int, void**) in "/opt/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linux64Gcc/bin/libpqCore.so"
#49 QMetaObject::activate(QObject*, int, int, void**) in "/usr/lib/libQtCore.so.4"
#50 QObject::event(QEvent*) in "/usr/lib/libQtCore.so.4"
#51 QApplicationPrivate::notify_helper(QObject*, QEvent*) in "/usr/lib/libQtGui.so.4"
#52 QApplication::notify(QObject*, QEvent*) addr2line failed
#53 QCoreApplication::notifyInternal(QObject*, QEvent*) in "/usr/lib/libQtCore.so.4"
#54 ?? in "/usr/lib/libQtCore.so.4"
#55 ?? in "/usr/lib/libQtCore.so.4"
#56 g_main_context_dispatch in "/usr/lib/libglib-2.0.so.0"
#57 ?? addr2line failed
#58 g_main_context_iteration in "/usr/lib/libglib-2.0.so.0"
#59 QEventDispatcherGlib:rocessEvents(QFlags<QEventL oop::ProcessEventsFlag>) in "/usr/lib/libQtCore.so.4"
#60 ?? in "/usr/lib/libQtGui.so.4"
#61 QEventLoop:rocessEvents(QFlags<QEventLoop::Proce ssEventsFlag>) addr2line failed
#62 QEventLoop::exec(QFlags<QEventLoop::ProcessEventsF lag>) in "/usr/lib/libQtCore.so.4"
#63 QCoreApplication::exec() in "/usr/lib/libQtCore.so.4"
#64 main in "/opt/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linux64Gcc/bin/paraview-real"
#65 __libc_start_main in "/lib/libc.so.6"
#66 vtkObject::RegisterInternal(vtkObjectBase*, int) in "/opt/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linux64Gcc/bin/paraview-real"
From function refCast<To>(From&)
in file /home/dm2/henry/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/typeInfo.H at line 115.
Any ideas?
Old   November 13, 2009, 09:03
Anonymous
What are you running that gives you this error message (by far the biggest I've ever come across, but I'm not big expert)? I see some vtk-related libraries being called, which is strange unless you are trying to convert foam data to vtk format?
Are you trying to run this mesh with a solver or just visualise it? Can you post the output of checkMesh? Also, as a side note, run renumberMesh and then do what you did before to see if you get the same issue.
Old   November 13, 2009, 09:28
It should just be a test case to see how the CCM converter works, I haven't applied any solver yet, nor did I any vtk related operations - voluntarily ;-)
This is the checkMesh result:
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
faces: 58750
internal faces: 53750
cells: 18750
boundary patches: 8
point zones: 0
face zones: 0
cell zones: 0
Overall number of cells of each type:
hexahedra: 18750
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 0
polyhedra: 0
Checking topology...
Boundary definition OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
Patch Faces Points Surface topology
ground 625 676 ok (non-closed singly connected)
ground2 625 676 ok (non-closed singly connected)
step 250 286 ok (non-closed singly connected)
top 1250 1326 ok (non-closed singly connected)
outlet 500 546 ok (non-closed singly connected)
inlet 250 286 ok (non-closed singly connected)
right 750 821 ok (non-closed singly connected)
left 750 821 ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (-0.05 -0.025 -0.02) (0.05 0.025 0.02)
Mesh (non-empty, non-wedge) directions (1 1 1)
Mesh (non-empty) directions (1 1 1)
Boundary openness (-1.89312e-17 1.14773e-17 2.69356e-17) OK.
Max cell openness = 1.10173e-16 OK.
Max aspect ratio = 1 OK.
Minumum face area = 4e-06. Maximum face area = 4e-06. Face area magnitudes OK.
Min volume = 8e-09. Max volume = 8e-09. Total volume = 0.00015. Cell volumes OK.
Mesh non-orthogonality Max: 0 average: 0
Non-orthogonality check OK.
Face pyramids OK.
Max skewness = 2.50571e-14 OK.
Mesh OK.
End
renumberMesh also results in an error message:
Create time
Create mesh for time = 0
Mesh size: 18750
Band before renumbering: 480
Reading volScalarField cellId
Reading volScalarField cellType
Reading volScalarField p
#2 Foam::Ostream& Foam:perator<< <Foam::error>(Foam::Ostream&, Foam::errorManip<Foam::error>) in "/opt/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/renumberMesh"
#6 Foam::fvPatchField<double>::New(Foam::fvPatch const&, Foam:imensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/renumberMesh"
#7 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::GeometricB oundaryField(Foam::fvBoundaryMesh const&, Foam:imensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/renumberMesh"
#8 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readField(Foam::Istream&) in "/opt/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/renumberMesh"
#9 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) in "/opt/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/renumberMesh"
#10 Foam::List<Foam::word> Foam::ReadFields<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>, Foam::fvMesh>(Foam::fvMesh const&, Foam::IOobjectList const&, Foam::PtrList<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >&, bool) in "/opt/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/renumberMesh"
#11 main in "/opt/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/renumberMesh"
#12 __libc_start_main in "/lib/libc.so.6"
#13 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116
FOAM aborting
Could it be, that I need to specify "p" an "U"? But I actually have them specified in "0". Do I need to copy the hole case into a solver sub-directory? It is now in my "run" directory on the same level as the "tutorial" are.
Old   November 13, 2009, 09:34
Anonymous
Can you paste your p and U files so I can have a look?
Old   November 13, 2009, 10:00
Sure!
Here's p:
FoamFile
version 2.0;
format ascii;
location "";
object p;
boundaryField
ground
type zeroGradient;
ground2
type zeroGradient;
step
type zeroGradient;
top
type zeroGradient;
outlet
type cyclic;
inlet
type empty;
right
type wall;
left
type wall;
And this is U:
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "";
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform ( 0.000000 0.000000 0.000000 );
boundaryField
ground
type fixedValue;
value uniform ( 0.000000 0.000000 0.000000 );
ground2
type fixedValue;
step
type fixedValue;
top
type fixedValue;
outlet
type cyclic;
inlet
type empty;
right
type wall;
left
type wall;
Old   November 13, 2009, 10:14
Anonymous
Why have you set left and right to type wall? I don't think you can do that in the 0/ dictionaries, as that word can only be used in your boundary file (someone correct me if I'm wrong). The correct pressure boundary condition type for an external flow is normally zeroGradient. Also, as far as I'm aware the empty type is required for the parallel faces in 2D meshes. Now, I'm not too sure whether these are the specific errors from which your errors are arising, but best to fix them and then try again.
What are you trying to model?
Btw, FoamX is no longer supported and it wasn't that good anyway (imo).
Old   November 24, 2009, 03:37
Hi madad2005,
thank you for your help, I've managed to get the case running. The problem were some wrong initial conditions for p and U. Now the conversion and the processor are both running. I appreciate your help!
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Problems when using Population balance model with Boiling model luliqiang FLUENT 0 May 28, 2013 05:22
problems couplying pbe-turbulence model adriana.nino OpenFOAM 0 May 14, 2013 15:33
Turbine Analysis - Alternate Rotation Model and Meshing Problems sean89dunn CFX 2 March 23, 2013 22:27
