[blockMesh] cannot open file controlDict
Old   January 4, 2010, 10:22
Unhappy cannot open file controlDict
thomas rouillon
thorou is on a distinguished road
I am a new user of Open foam and blockmesh. I tried to do the first tutorial : cavity.
When I want to generate the mesh I have this message :
cannot open file
file: /home/caelinux/Bureau/TEST_OF/cavity/constant/polyMesh/system/controlDict
at line 0.
From function regI0object::readStream(const word&)
in file db/regI0object/regI0objectRead.C at line 66.
FOAM exiting
I made an installation on USB-hard drive , it is possible that it is the origin of the error ?
Sincerely
Thomas
thorou is offline   Reply With Quote
Old   January 5, 2010, 15:40
Eric Nutsch
ericnutsch is on a distinguished road
Send a message via Skype™ to ericnutsch
Yes, it is likely that the usb install is the root of your error.
Openfoam is trying to find the controlDict at its typical location on the hard drive. Two possible solutions here:
1. Simply copy the entire tutorials directory to the hard drive in the location it is looking for it (directory structure should be quite similar). This will probably be the easiest, but might not work in certian cases.
2. Make sure your bashrc knows the where open foam is at. Read part 3 at this link: http://www.opencfd.co.uk/openfoam/doc/README.html
I have used openfoam directly, so I am not certain if cea handles stuff differently or not.
Good Luck!
ericnutsch is offline   Reply With Quote
Old   January 7, 2010, 01:24
amgode's Avatar
Amol
amgode is on a distinguished road
Just take a look at the location where the controlDict is being searched....
at line 0.
I would say you might get some results if you fire the application from the case directory and not the constant polyMesh directory...........
Hope this helps !!!!!!!!!!!!
-- Amol
amgode is offline   Reply With Quote
openfoam;blockmesh
[Other] Tabulated thermophysicalProperties library chriss85 OpenFOAM Community Contributions 62 October 2, 2022 03:50
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 08:06
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 01:22
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 10:59
