[blockMesh] stitching on arcs
Old   March 15, 2010, 09:48
Default stitching on arcs
RBJ
Robin Koldeweij
RBJ is on a distinguished road
Dear All,
For a multi-phase flow simulation I have a spider-web mesh, as can be seen in the picture. I create the blockmesh file with a matlab script. The mesh exists of a couple of wedge-type blocks in circumferential direction. I have noticed for a test-case simulation that other meshes (like o-type) don't give correct results (not even close!).
At a certain location in axial direction, say at the arrow, I want fluid dropping into the domain. Therefore I thought of making an inlet at a certain location in axial direction. I also want to make a block for this with new nodes and an arc on the downside going through the mesh' radius.
The total outside boundary of the cylinder is called 'freeStream' I have tried to do stitchmesh freestream inletDownSide -partial, but all I got was errors like
#0  Foam::error::printStack(Foam::Ostream&) in "/uhome/koldewei/OpenFOAM/OpenFOA
M-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#1  Foam::error::abort() in "/uhome/koldewei/OpenFOAM/OpenFOAM-1.6/lib/linux64Gc
#2  Foam::enrichedPatch::calcCutFaces() const in "/uhome/koldewei/OpenFOAM/OpenF
OAM-1.6/lib/linux64GccDPOpt/libdynamicMesh.so"
#3  Foam::enrichedPatch::cutFaces() const in "/uhome/koldewei/OpenFOAM/OpenFOAM-
#4  Foam::slidingInterface::coupleInterface(Foam::polyTopoChange&) const in "/uh
ome/koldewei/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libdynamicMesh.so"
#5  Foam::polyTopoChanger::topoChangeRequest() const in "/uhome/koldewei/OpenFOA
#6  Foam::polyTopoChanger::changeMesh(bool, bool, bool, bool) in "/uhome/koldewe
#7  main in "/uhome/koldewei/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDP
Opt/stitchMesh"
#8  __libc_start_main in "/lib64/libc.so.6"
#9  _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.
S:116
    From function void enrichedPatch::calcCutFaces() const
    in file slidingInterface/enrichedPatch/enrichedPatchCutFaces.C at line 567.
FOAM aborting
Does anyone have any clues on how to perform this?
Of course it would be possible to manually select the nodes on which the inlet should be added, but I'd like to make it more an automatic procedure: change some variables in my Matlab script -> blockMesh > stitchmesh > run simulation
RBJ is offline   Reply With Quote
[blockMesh] Axisymmetric blockMesh error. Are Arcs needed? andygdl OpenFOAM Meshing & Mesh Conversion 0 November 2, 2010 11:25
how to create arcs in fluent MADHU BABU FLUENT 2 June 2, 2003 08:00
Stitching volumes Jim FLUENT 0 April 1, 2003 09:19
Stitching volumes Jimmy Fidelity CFD 1 March 28, 2003 15:48
creating volume by stitching faces Prabhu.B FLUENT 3 June 27, 2002 19:33
