Home > Forums > OpenFOAM Native Meshers: blockMesh
Is it possible to define a CONSTANT in the blockMesh file?
Like Tree1Likes
  • 1 Post By olesen
Old   March 18, 2010, 07:47
Default Is it possible to define a CONSTANT in the blockMesh file?
Marco
om3ro is on a distinguished road
I need to simulate several different configurations by changing a geometrical parameter, so I would like to change just the value of a constant instead of changing all the points of the mesh:
A simple example of what i need:
int b;
b=4; // b can vary from 2 to 6 : 2, 2.1, 2.2, 2.3, ... , 5.9, 6.
vertices
(0 -1 0)
(b -1 0)
(b 0 0)
(0 0 0)
(0 -1 1)
(b -1 1)
(b 0 1)
(0 0 1)
Is it possible to make that?
Regards
Marco
om3ro is offline   Reply With Quote
Old   March 18, 2010, 11:27
Paul Garlick
pg22 is on a distinguished road
The m4 pre-processor is handy for this sort of thing. You define the constants in a separate file, blockMeshDict.m4 say, and use m4 to do any necessary calculations and write out a new blockMeshDict file.
There are some examples in the forum and also on the wiki (e.g. OSIG)
pg22 is offline   Reply With Quote
Old   March 19, 2010, 03:14
Mark Olesen
olesen will become famous soon enough
Indeed m4 is the most reasonable approach at the moment.
The dictionary $variable expansions will generally not work, since the blockMeshDict entries are mostly read as straight lists.
However, you don't need to look any further than some of the tutorial examples.
$ git ls-files | grep m4
yields this list of files:
tutorials/compressible/rhoPimpleFoam/angledDuct/constant/polyMesh/blockMeshDict.m4
tutorials/compressible/rhoPorousSimpleFoam/angledDuctImplicit/constant/polyMesh/blockMeshDict.m4
tutorials/incompressible/MRFSimpleFoam/mixerVessel2D/constant/polyMesh/blockMeshDict.m4
tutorials/incompressible/porousSimpleFoam/angledDuctImplicit/constant/polyMesh/blockMeshDict.m4
tutorials/multiphase/interDyMFoam/ras/sloshingTank2D/constant/polyMesh/blockMeshDict.m4
tutorials/multiphase/interDyMFoam/ras/sloshingTank2D3DoF/constant/polyMesh/blockMeshDict.m4
tutorials/multiphase/interDyMFoam/ras/sloshingTank3D/constant/polyMesh/blockMeshDict.m4
tutorials/multiphase/interDyMFoam/ras/sloshingTank3D3DoF/constant/polyMesh/blockMeshDict.m4
tutorials/multiphase/interDyMFoam/ras/sloshingTank3D6DoF/constant/polyMesh/blockMeshDict.m4
tutorials/multiphase/interFoam/MRFInterFoam/mixerVessel2D/constant/polyMesh/blockMeshDict.m4
rajibroy likes this.
olesen is offline   Reply With Quote
constant blockmesh
Thread Tools
Trackbacks are On
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 10:38
Paraview command not found hardy OpenFOAM Paraview & paraFoam 7 September 18, 2008 04:59
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
gcc and executable file from Mac to Linux simone Marras Main CFD Forum 0 April 8, 2007 15:49
