[snappyHexMesh] snappyHexMesh memory or install problem?
Old   April 12, 2010, 09:50
Exclamation snappyHexMesh memory or install problem?
carowjp's Avatar
Jim Carow
carowjp is on a distinguished road
Hi All,
I receive the following error running snappyHexMesh during mesh castellation surface refinement iterations:
new cannot satisfy memory request.
This does not necessarily mean you have run out of virtual memory.
It could be due to a stack violation caused by e.g. bad use of pointers or an out of date shared library
The number of cells is over 2 million since I had to increase the limit in snappyHexMeshDict.
I am running Ubuntu 9.04/OF 1.6 on a 32 bit Core2 with 3 gb of RAM.
Is this an install problem or a memory problem? Any ideas or workarounds are welcomed.
thanks,
Jim
carowjp is offline   Reply With Quote
error, memory, snappyhexmesh, virtual memory
[snappyHexMesh] snappyHexMesh <-> dynamicMeshDict problem with protected cells Billy_16 OpenFOAM Meshing & Mesh Conversion 2 November 21, 2020 03:34
[ANSYS Meshing] Interface node number and memory allocation problem Whitebear ANSYS Meshing & Geometry 2 June 22, 2016 04:41
[snappyHexMesh] snappyHexMesh: problem meshing baffle (surface with zero thickness) julien.decharentenay OpenFOAM Meshing & Mesh Conversion 7 June 16, 2012 08:12
Polyflow Simulation with ViscoElastic Model memory problem sid2909 FLUENT 0 May 10, 2010 05:29
CFX CPU time & real time Nick Strantzias CFX 8 July 23, 2006 17:50
