Home > Forums > OpenFOAM Native Meshers: blockMesh
Cyclic command
Old   April 21, 2010, 21:16
Default Cyclic command
Andres
Panagioto is on a distinguished road
Hi everybody!
I am trying to do a simulation in interFoam that recreates the travel of a little drop of a viscuous fluid sorruounded by water. I did it before using the cyclic comand in the blockMeshDict. Now I was asked to do it with a gradient of pressure, but I havenīt been able to do it as the cyclic command repeats the same conditions in the boundary faces of the wedge.
Is it possible to stablish a gradient of pressure between 2 cyclic faces?
Thanks in advance
Panagioto is offline   Reply With Quote
Old   May 20, 2010, 11:39
kjetil is on a distinguished road
You might have a go with this using the method channelFoam uses. You would have to modify an existing one or create your own solver in order to do this.
kjetil is offline   Reply With Quote
Thread Tools
Trackbacks are On
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 18:08
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
OpenFOAM15 installables are incomplete problem with paraFoam tryingof OpenFOAM Bugs 17 December 7, 2008 05:41
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
