April 21, 2010, 21:16 |
Cyclic command
Andres
Hi everybody!
I am trying to do a simulation in interFoam that recreates the travel of a little drop of a viscuous fluid sorruounded by water. I did it before using the cyclic comand in the blockMeshDict. Now I was asked to do it with a gradient of pressure, but I havenīt been able to do it as the cyclic command repeats the same conditions in the boundary faces of the wedge. Is it possible to stablish a gradient of pressure between 2 cyclic faces? Thanks in advance Last edited by Panagioto; April 23, 2010 at 11:44. |
May 20, 2010, 11:39 |
You might have a go with this using the method channelFoam uses. You would have to modify an existing one or create your own solver in order to do this.
activeBaffleVelocity boundary condition ? | om3ro | OpenFOAM Programming & Development | 10 | November 16, 2020 23:26 |
prescribibg cyclic boundary in openfoam | saeedi | OpenFOAM Running, Solving & CFD | 0 | May 17, 2017 04:00 |
Possible createPatch/createBaffles bug? | simpomann | OpenFOAM Bugs | 2 | July 15, 2014 07:07 |
Cyclic boundary conditions - not parallel patches | Villo | OpenFOAM Running, Solving & CFD | 3 | July 14, 2014 22:50 |
[mesh manipulation] Cyclic Mesh Error | vbchris | OpenFOAM Meshing & Mesh Conversion | 4 | November 15, 2012 13:04 |
