[blockMesh] 90 degrees pipe bend - changing shape midway |
May 20, 2010, 11:25 |
Rep Power: 17 |
Dear foamers,
I have created a bend in blockMesh using the O-grid technique (squared center section). However, when investigating the 3D geometry in paraView, the mid pipe profile (45 degrees) of the bend is not quite circular. I have looked over the arc section in blockMeshDict over and over again, but I cannot find any obvious errors. It this how it is supposed to be, or should I file a bug report? |
May 25, 2010, 02:29 |
Lachlan Graham
Rep Power: 16 |
I have had a similar experience with a pipe bend geometry, I could not find anything to explain it. I used Solidworks to check the numbers used on the arcs, could not fix the problem. Lachlan |
May 25, 2010, 04:16 |
Rep Power: 17 |
Good. A temporary solution in blockMesh may be to create pipe bend in increments of, say ~40 degrees. Apart from that, an external mesh/geometry seems to be the only way out at the moment.
I have now also filed a "bug report" using a 179.9 degree bend (-> http://www.cfd-online.com/Forums/ope...rved-bend.html). |
May 25, 2010, 20:07 |
Lachlan Graham
Rep Power: 16 |
Many thanks for that. I was also going to try the simple if tedious option of increments. I will also have a go with ExtrudeMesh as in the bug report.
Regards, Lachlan |
Display Modes | |
need help about double pipe heat exchanger with chtMultiRegionSimpleFoam | wuyangzhen | OpenFOAM | 10 | December 12, 2017 00:19 |
[PyFoam] Problems with the new PyFoam release | zfaraday | OpenFOAM Community Contributions | 13 | December 9, 2014 18:58 |
[PyFoam] having problems with pyfoam Installation | vitorspadetoventurin | OpenFOAM Community Contributions | 3 | December 2, 2014 07:18 |
How to get "Fully developed flow" at pipe inlet without changing length | nihossain | FLUENT | 0 | November 2, 2011 16:22 |
changing Mesh with known new points for shape | kilerskill | OpenFOAM | 15 | February 16, 2011 03:21 |
