[blockMesh] snappyHexMesh for a pipe
Old   July 15, 2010, 10:06
Default snappyHexMesh for a pipe
Grace
Grace is on a distinguished road
Hello to everybody
I am very very new in OpenFoam and currently I am trying to use snappyHexMesh to create a mesh for a pipe. I produced the 3 stl files each one corresponding to inlet, outlet and shell of the pipe and my initial mesh box which i created using blockMesh. When I execute snappyHexMesh only the boundaries from the blockMesh are printed out...I get no error msg at all...Any ideas why this is happening?
Your help is much appreciated
Thank you
Grace
Grace is offline   Reply With Quote
need help about double pipe heat exchanger with chtMultiRegionSimpleFoam wuyangzhen OpenFOAM 10 December 12, 2017 00:19
Snappyhexmesh vertical manifold pipe in tank [SOLVED] spk363 Mesh Generation & Pre-Processing 1 February 17, 2016 19:51
[snappyHexMesh] snappyHexMesh - spiral shaped pipe internal flow callmety OpenFOAM Meshing & Mesh Conversion 2 July 30, 2015 23:28
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
