-   OpenFOAM Native Meshers: blockMesh (
-   -   ..neighbour cell face (
hpon July 16, 2010 04:57
1 Attachment(s)
When I run blockMesh I get the following message: "FOAM FATAL ERROR: face 0 in patch 4 does not have neighbour cell face: 4(8 9 15 14)". What does that mean? What is wrong with the patch?
I have attached the blockMeshDict file.
gulru April 5, 2011 07:32
I have the same problem.
Could you find a solution?
ngj April 5, 2011 07:42
It tells you that none of the blocks (hex) that you have defined have block faces, which are defined as you have defined the boundary patch. I took a quick look in your blockMeshDict and none of your blocks actually contain all of the points on that boundary patch.
/ Niels
deji April 16, 2011 13:31
1 Attachment(s)
I have a similar issue with my mesh, with possible face ordering problems for the cyclic patch. Can anyone help some, blockMeshDict is attached.
deji April 16, 2011 14:11
Thanks guys, I already fixed the problem....:):p:D
