Home > Forums > OpenFOAM Native Meshers: blockMesh
Trouble with MergePatchPairs: Duplicate Point Found in Cut Face
Old   August 31, 2010, 22:13
Default Trouble with MergePatchPairs: Duplicate Point Found in Cut Face
Daniel
dancfd is on a distinguished road
Good evening all,
I am trying to produce an airfoil with a flap with overlapping geometry but are separate patches (so that they can rotate relative to each other). To test this, I have attempted to create a mesh with some overlap, however I am given the following error when I run blockMesh:
Adding point and face zones
Creating attachPolyTopoChanger
--> FOAM FATAL ERROR:
Duplicate point found in cut face. Error in the face cutting algorithm for global face 4(97410 97428 97430 97412) local face 4(151 150 152 153)
Slave size: 250 Master size: 90 index: 74.
Face:
41
97411
97429
etc
I am unfamiliar with this type of error, and I do not know how to fix this problem. Can anyone suggest a solution? I have attached the blockMeshDict, the log file for the error (though I shortened the lists with "...") and a visual representation of the mesh (this shows the . I would appreciate any help that could be offered.
Regards,
Dan
dancfd is offline   Reply With Quote
Old   August 31, 2010, 23:02
Martin
MartinB is on a distinguished road
Sorry, false alarm by me... first block is fine... problem is somewhere else...
Martin
Last edited by MartinB; August 31, 2010 at 23:15. Reason: Misinterpretation by me...
MartinB is offline   Reply With Quote
Old   March 24, 2013, 14:25
Default Hi Daniel
Sasan Ghomi
sasanghomi is on a distinguished road
Originally Posted by dancfd View Post
Good evening all,
Face:
41
97411
97429
etc
Regards,
Dan
Hi Daniel
Did you find the origin of this error?
I have a same error for engine simulation (sliding interface for valves)...
How can I fix this error?
Thanks and best regards,
Sasan.
sasanghomi is offline   Reply With Quote
Old   March 24, 2013, 17:26
Daniel
Hello Sasan,
Unfortunately not; I had to remove the oscillating flap from the scope of my project.
Best of luck.
Dan
Old   March 13, 2014, 04:01
Albrecht vBoetticher
vonboett is on a distinguished road
I have the same error with stitch mesh. Check mesh is OK. Any hints?
vonboett is offline   Reply With Quote
Thread Tools
Trackbacks are On
Internal walls of zero thickness anger OpenFOAM Native Meshers: blockMesh 22 December 15, 2015 03:06
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 28 May 28, 2015 13:37
BlockMesh FOAM warning gaottino OpenFOAM Native Meshers: blockMesh 7 July 19, 2010 14:11
BlockMeshmergePatchPairs hjasak OpenFOAM Native Meshers: blockMesh 11 August 15, 2008 07:36
'Edge of current face was not found in search box. Jacky CFX 0 November 16, 2002 21:14
