[blockMesh] Floating point exception
Old   September 16, 2010, 13:26
Default Floating point exception
elbert
elbertj is on a distinguished road
I get this error while trying to do a 'blockMesh' in /incompressible/pisoFoam/les/pitzDailyDirectMapped
Creating block mesh from
"/home/ejp/codes/OpenFOAM/ejp-1.7.x/pitzDailyDirectMapped/constant/polyMesh/blockMeshDict"
Creating blockCorners
Creating curved edges
Creating blocks
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/ejp/codes/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/ejp/codes/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 __restore_rt at sigaction.c:0
#3 Foam::lineDivide::lineDivide(Foam::curvedEdge const&, int, double) in "/home/ejp/codes/OpenFOAM/OpenFOAM-1.7.x/applications/bin/linux64GccDPOpt/blockMesh"
#4 Foam::blockDescriptor::setEdge(int, int, int, int) in "/home/ejp/codes/OpenFOAM/OpenFOAM-1.7.x/applications/bin/linux64GccDPOpt/blockMesh"
#5 Foam::blockDescriptor::makeBlockEdges() in "/home/ejp/codes/OpenFOAM/OpenFOAM-1.7.x/applications/bin/linux64GccDPOpt/blockMesh"
#6 Foam::blockDescriptor::blockDescriptor(Foam::Field <Foam::Vector<double> > const&, Foam::PtrList<Foam::curvedEdge> const&, Foam::Istream&) in "/home/ejp/codes/OpenFOAM/OpenFOAM-1.7.x/applications/bin/linux64GccDPOpt/blockMesh"
#7 Foam::blockMesh::createTopology(Foam::IOdictionary &) in "/home/ejp/codes/OpenFOAM/OpenFOAM-1.7.x/applications/bin/linux64GccDPOpt/blockMesh"
#8 Foam::blockMesh::blockMesh(Foam::IOdictionary&) in "/home/ejp/codes/OpenFOAM/OpenFOAM-1.7.x/applications/bin/linux64GccDPOpt/blockMesh"
#9 main in "/home/ejp/codes/OpenFOAM/OpenFOAM-1.7.x/applications/bin/linux64GccDPOpt/blockMesh"
#10 __libc_start_main in "/lib64/libc.so.6"
#11 _start in "/home/ejp/codes/OpenFOAM/OpenFOAM-1.7.x/applications/bin/linux64GccDPOpt/blockMesh"
I wonder if this is due to installing OF 1.7.x on Fedora 10. machine details are:
$uname -a
Linux ej2 2.6.27.5-117.fc10.x86_64 #1 SMP x86_64 GNU/Linux
$gcc -v
gcc version 4.3.2 20081105 (Red Hat 4.3.2-7) (GCC)
I don't see this error from the same version of OF installed on Fedora 13. If you know the source of this error, kindly let me know.
Elbert
elbertj is offline   Reply With Quote
icoFoam floating point exception (8) leizhao512 OpenFOAM Running, Solving & CFD 7 November 1, 2018 11:43
A floating point exception has occurred: floating point exception [Overflow]. starlight STAR-CCM+ 4 May 4, 2016 09:08
A floating point exception - SEM Model yansheng STAR-CCM+ 1 April 4, 2016 04:57
Floating point exception from twoPhaseEulerFoam openfoammaofnepo OpenFOAM Running, Solving & CFD 1 March 19, 2016 13:56
Floating point exception (core dumped) for GAMG solver yuhou1989 OpenFOAM Running, Solving & CFD 2 March 24, 2015 19:28
