Internal Walls
I wish to generate a mesh for the geometry below. It is an air lift reactor :
https://sites.google.com/site/balkri...me/reactor.jpg My blockMeshDict is as follows : Code:
/*--------------------------------*- C++ -*----------------------------------* \ Code:
--> FOAM FATAL ERROR: |
HI balakrishna,
Did you manage to mesh your internal boundaries. I have a similar problem with same error and want to use blockMesh to solve thisproblem. Give me suggestions to solve this problem. regards K.SUresh kumar |
Greetings to both of you!
Check this tutorial: multiphase/interDyMFoam/ras/damBreakWithObstacle See Allrun and createObstacle.setSet. For more about setSet: http://openfoamwiki.net/index.php/SetSet Best regards, Bruno |
Yes ..... this was a long time ago .... i managed to do the meshing and run the case too .... The key was in not meshing the baffles .... i.e. i commented the lines in red ....
blocks |
HI Bruno,
Thanks for pointing the right direction. This is what I want. I already started looking in to the tutorial. I think it will help me solve the problem. regards K.SUresh kumar |
Why are you using blockMesh for a complex geometry?
I would recommend snappyHexMesh. |
Hi all,
@CHiller Your blocks were merged, you as blockMesh said, you are trying to create patch inside the mesh (and it worries blockMesh). You have several choices: 1. Use 4 additional points (though with identical coordinates) to avoid automatic block merging. 2. Use createBaffles utility to create "patch" inside a mesh. @KaLium Complex geometry? |
Thanks
Many thanks Dear Bruno for straight help, It definitely works !:) Regards, Haydi |
