Home > Forums > OpenFOAM Native Meshers: blockMesh
Multi-resolution Mesh
Old   October 28, 2010, 20:38
Default Multi-resolution Mesh
wulong is on a distinguished road
Is it possible to create the multi-resolution 2D mesh?
For example,
In region A (0,1)X(0,1), the resolution is 32X32; in region B (1,2)X(0,1), the resolution is 128X128; region A and B is connected by the face at plane X=1.
wulong is offline   Reply With Quote
Old   October 29, 2010, 04:24
akidess's Avatar
Anton Kidess
Yes, it's fairly simple too. All you have to do is define a block mesh with two blocks (using 12 points).
Old   October 29, 2010, 06:11
I use the two blocks with 12 points, but it doesn't work. The OpenFoam complains "The edge is not consist at the X=1" .
So, I use two blocks with 16 points and 4 pair of points have the same coordinate. The OpenFoam does't complain, but the two blocks are not connected.
I don't know how to do.
Old   October 29, 2010, 07:06
akidess's Avatar
Anton Kidess
You need 12 points in the vertices list. The order of the vertices should be consistent to what you find for a hexahedron on U-127 in the user guide. Then you can define to blocks
hex (0 1 2 3 4 5 6 7) (32 32 1) simpleGrading (1 1 1)
hex (1 8 9 2 5 10 11 6) (128 128 1) simpleGrading (1 1 1)
Thread Tools
Trackbacks are On
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
multi region mesh using snappyHexMesh fumiya OpenFOAM Native Meshers: snappyHexMesh and Others 0 July 8, 2010 10:14
external flow with snappyHexMesh chelvistero OpenFOAM 11 January 15, 2010 20:43
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
