Home > Forums > OpenFOAM Native Meshers: blockMesh
Axisymmetric blockMesh error. Are Arcs needed?
Old   November 2, 2010, 12:25
Default Axisymmetric blockMesh error. Are Arcs needed?
Andy
andygdl is on a distinguished road
I'm having problems meshing a fairly complicated axisymmetric nozzle. I've had no problems in the past with axisymmetric meshes, but this one is causing problems. The error is as follows:
Create time
Creating block mesh from
    "/home/andy/OpenFOAM/andy-1.7.1/run/gt_hemi/axihemifull/constant/polyMesh/blockMeshDict"
Creating blockCorners
Creating curved edges
#0  Foam::error::printStack(Foam::Ostream&) in "/home/andy/OpenFOAM/OpenFOAM-1.7.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#1  Foam::sigFpe::sigFpeHandler(int) in "/home/andy/OpenFOAM/OpenFOAM-1.7.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#2  Uninterpreted:
#3  Foam::coordinateRotation::calcTransform(Foam::Vector<double> const&, Foam::Vector<double> const&, Foam::coordinateRotation::axisOrder const&) in "/home/andy/OpenFOAM/OpenFOAM-1.7.1/lib/linuxGccDPOpt/libmeshTools.so"
#4  Foam::coordinateRotation::coordinateRotation(Foam::Vector<double> const&, Foam::Vector<double> const&) in "/home/andy/OpenFOAM/OpenFOAM-1.7.1/lib/linuxGccDPOpt/libmeshTools.so"
#5  Foam::coordinateSystem::coordinateSystem(Foam::word const&, Foam::Vector<double> const&, Foam::Vector<double> const&, Foam::Vector<double> const&) in "/home/andy/OpenFOAM/OpenFOAM-1.7.1/lib/linuxGccDPOpt/libmeshTools.so"
#6  Foam::cylindricalCS::cylindricalCS(Foam::word const&, Foam::Vector<double> const&, Foam::Vector<double> const&, Foam::Vector<double> const&, bool) in "/home/andy/OpenFOAM/OpenFOAM-1.7.1/lib/linuxGccDPOpt/libmeshTools.so"
#7  Foam::arcEdge::calcAngle() in "/home/andy/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linuxGccDPOpt/blockMesh"
#8  Foam::arcEdge::arcEdge(Foam::Field<Foam::Vector<double> > const&, Foam::Istream&) in "/home/andy/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linuxGccDPOpt/blockMesh"
#9  Foam::curvedEdge::addIstreamConstructorToTable<Foam::arcEdge>::New(Foam::Field<Foam::Vector<double> > const&, Foam::Istream&) in "/home/andy/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linuxGccDPOpt/blockMesh"
#10  Foam::curvedEdge::New(Foam::Field<Foam::Vector<double> > const&, Foam::Istream&) in "/home/andy/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linuxGccDPOpt/blockMesh"
#11  Foam::blockMesh::createTopology(Foam::IOdictionary&) in "/home/andy/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linuxGccDPOpt/blockMesh"
#12  Foam::blockMesh::blockMesh(Foam::IOdictionary&) in "/home/andy/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linuxGccDPOpt/blockMesh"
#13  main in "/home/andy/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linuxGccDPOpt/blockMesh"
#14  __libc_start_main in "/lib/libc.so.6"
#15  _start at /usr/src/packages/BUILD/glibc-2.10.1/csu/../sysdeps/i386/elf/start.S:122
Floating point exception
The problem goes away if I replace the 'arcs' with lines - i.e. the arcs put in for rotation about the axis (not the arcs that define the shape of the geometry!).
I've checked, the interpolation points all seem in order. I don't think its any problem with 'crazy' surfaces bounded by 2 splines and 2 arcs, as I've used a very similar geometry before and not had any problems.
The obvious question is: 'do I actually need to make them arcs?'. It is only 5 degrees, would it make any difference to the solution if they were just lines?
Otherwise, does anyone have an idea what the problem is? Thanks very much for any help!
I've included the blockMeshDict.fail that doesn't work and the blockMeshDict.yay that works without arcs
ps. I realise I didn't need to define 'line a b'... I was young and crazy!
andygdl is offline   Reply With Quote
Thread Tools
Trackbacks are On
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
BlockMesh not making arcs Disco_Caine OpenFOAM Meshing Format & General Technical 3 July 6, 2010 10:16
Blockmesh cavity error message tonitoney OpenFOAM Installation 2 March 17, 2008 12:59
Axisymmetric cases Test with blockmesh and icoFoam frackowi OpenFOAM Running, Solving & CFD 2 July 11, 2007 19:02
