Home > Forums > OpenFOAM Native Meshers: blockMesh
Boundaries
Old   November 30, 2010, 16:31
Default Boundaries
Pietro
pit0687 is on a distinguished road
Hi!
I've to set the boundaries of my domain. The domain is a squared plane (1x1x0.1) and I'm starting from the transport tutorial file. I should set a number of patches and a starting patch but I don't know which one to choose, as I don't know how the patches are numbered. Can you help me?
Thanks
pit0687 is offline   Reply With Quote
Old   December 11, 2010, 11:48
Usit McCarra
McCarra is on a distinguished road
Patches are not numbered, there's no need to put them in order. Once you've defined your vertices (numbered), blocks, and edges you can define your patch by the faces it is composed of. And every face is defined by the NUMBER (not coordinate) of the four vertices it contains.
Look at the blockMeshDict of tutorials/incompressible/icoFoam/cavity/constant/polyMesh as an example.
Hope it helps
McCarra is offline   Reply With Quote
Thread Tools
Trackbacks are On
Setting Flow/Pressure Boundaries in Floworks Eran FloEFD, FloWorks & FloTHERM 3 August 11, 2009 04:23
periodic boundaries - flow through a net PK FLUENT 0 July 12, 2007 11:58
Periodic Boundaries in GAMBIT!! swetha FLUENT 1 November 26, 2006 23:02
problems replacing old boundaries Jared CD-adapco 4 August 5, 2005 19:36
mass flux correction at outflow boundaries Subhra Datta Main CFD Forum 2 November 24, 2003 14:11
