Home > Forums > OpenFOAM Native Meshers: blockMesh
blockMesh - help
Old   June 16, 2011, 11:10
Default blockMesh - help
Ammar Tareen
atareen64 is on a distinguished road
Dear All,
I created a half laval-nozzle mesh using blockMesh and I put some effort into it. When I ran blockMesh, the mesh got created but with a lot of warnings like 'zero or negative pyramid volume'. And even though I am able to view the mesh in paraview, the I can't run the solver on it because it fails three mesh checks.
I have a hunch as to what could be wrong with the mesh but I'm not sure. Can anybody look at the mesh or the blockMesh warnings and tell me what's going on?
I'm uploading the mesh and a test case so anybody can generate blockMesh without trouble.
Thanks a lot!
-Ammar.
atareen64 is offline   Reply With Quote
Old   June 16, 2011, 12:13
Martin
MartinB is on a distinguished road
Hi Ammar,
change the z-coordinates of your vertices from ( x y 5.0 ) to ( x y -5.0 ). Be careful with your vertices 76, 77, 78, 79 when using a replace command in a text editor.
As an alternative you can renumber all the hex blocks: take the last four digits and place them before the first four digits.
Have fun
Martin
MartinB is offline   Reply With Quote
Old   June 16, 2011, 15:32
Ammar Tareen
Martin!
Thank you for that suggestion, it worked. Silly mistake, Thanks a lot!
~Ammar.
Thread Tools
Trackbacks are On
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
tutorial 2.2 Stress(...) trouble with blockMesh colinB OpenFOAM Native Meshers: blockMesh 8 January 22, 2012 11:32
Installation/Tutorial - libraries not found (blockMesh) bernarde OpenFOAM 3 June 19, 2009 12:36
IcoFoam Not Installed and blockMesh command not found cesarbz OpenFOAM Installation 6 July 4, 2008 04:44
Blockmesh cavity error message tonitoney OpenFOAM Installation 2 March 17, 2008 12:59
