-   OpenFOAM Native Meshers: blockMesh (http://www.cfd-online.com/Forums/openfoam-meshing-blockmesh/)
-   -   Spotting errors in blockMeshDict (http://www.cfd-online.com/Forums/openfoam-meshing-blockmesh/90661-spotting-errors-blockmeshdict.html)
Rachit July 18, 2011 04:05
Hi everyone!
I have been trying to mesh flow over the busemann's biplane.
http://en.wikipedia.org/wiki/Busemann%27s_Biplane
The blockMeshDict file I have written is as follows:
vertices
(-1.0 0.192 -0.01)
(-0.5 0.192 -0.01)
(0.5 0.192 -0.01)
(1.0 0.192 -0.01)
(-1.0 0.096 -0.01)
(-0.5 0.096 -0.01)
(0.5 0.096 -0.01)
(1.0 0.096 -0.01)
(0 0.0842 -0.01)
(0 -0.0842 -0.01)
(-1.0 -0.096 -0.01)
(-0.5 -0.096 -0.01)
(0.5 -0.096 -0.01)
(1.0 -0.096 -0.01)
(-1.0 -0.192 -0.01)
(-0.5 -0.192 -0.01)
(0.5 -0.192 -0.01)
(1.0 -0.192 -0.01)
(-1.0 0.192 0.01)
(-0.5 0.192 0.01)
(0.5 0.192 0.01)
(1.0 0.192 0.01)
(-1.0 0.096 0.01)
(-0.5 0.096 0.01)
(0.5 0.096 0.01)
(1.0 0.096 0.01)
(0 0.0842 0.01)
(0 -0.0842 0.01)
(-1.0 -0.096 0.01)
(-0.5 -0.096 0.01)
(0.5 -0.096 0.01)
(1.0 -0.096 0.01)
(-1.0 -0.192 0.01)
(-0.5 -0.192 0.01)
(0.5 -0.192 0.01)
(1.0 -0.192 0.01)
blocks
hex (22 23 5 4 18 19 1 0) (200 1 152) simpleGrading (1 1 1)
hex (23 24 6 5 19 20 2 1) (200 1 152) simpleGrading (1 1 1)
hex (24 25 7 6 20 21 3 2) (200 1 152) simpleGrading (1 1 1)
hex (28 29 11 10 22 23 5 4) (200 1 152) simpleGrading (1 1 1)
hex (29 27 9 11 23 26 8 5) (200 1 152) simpleGrading (1 1 1)
hex (27 30 12 9 26 24 6 8) (200 1 152) simpleGrading (1 1 1)
hex (26 8 5 23 24 6 6 24) (200 1 152) simpleGrading (1 1 1)
hex (27 9 11 29 30 12 12 30) (200 1 152) simpleGrading (1 1 1)
hex (30 31 13 12 24 25 7 6) (200 1 152) simpleGrading (1 1 1)
hex (32 33 15 14 28 29 11 10) (200 1 152) simpleGrading (1 1 1)
hex (33 34 16 15 29 30 12 11) (200 1 152) simpleGrading (1 1 1)
hex (34 35 17 16 30 31 13 12) (200 1 152) simpleGrading (1 1 1)
edges
patches
mergePatchPairs
However, I get an error of zero or negative pyramid volume at several faces. I do understand that probably there has been mistake on my part in defining the geometry. However, it is a tedious job going through such blockMesh files this long or even longer again and again.:(
Are there any other ways or techniques to spot such errors such as badly defined block or face, etc?
Thanks in advance,
Rachit
wyldckat July 19, 2011 17:01
1 Attachment(s)
Hi Rachit,
If you are using OpenFOAM 2.0 with the official reader for ParaView, not just the internal one, then try the following command when inside your case folder:
paraFoam -block
This blew my mind just now... I thought this only showed the points, but when I saw the results for the tutorial "stressAnalysis/solidDisplacementFoam/plateHole"... See the image attached!! Notice that I picked the option "Wireframe" on that drop-down box on the top center-left of the window.
Best regards,
Bruno
wiedangel November 22, 2011 18:01
thank you for this option ... it is really f a big help for me. makes it easy to detect the errors
