Home > Forums > OpenFOAM Native Meshers: blockMesh
Errors during blockMesh meshing
Old   February 14, 2014, 11:57
Default More errors
  #41
Luis Miguel
luigi21 is on a distinguished road
Hello Elia...
I've checked what you suggested me, I switch the vertices order and blockMesh runs well but now I've got a problem when I run checkMesh, the error is even worst, check this out:
Valid index labels are 0..387999
--> FOAM Serious Error :
From function bool zone::checkDefinition(const label maxSize, const bool report) const
in file meshes/polyMesh/zones/zone/zone.C at line 211
Zone internal contains invalid index label 388092
Zone internal contains invalid index label 388093
Zone internal contains invalid index label 388094
Zone internal contains invalid index label 388095
Zone internal contains invalid index label 388096
Zone internal contains invalid index label 388097
Zone internal contains invalid index label 388098
--> FOAM FATAL ERROR:
Too many errors
From function messageStream:perator OSstream&()
in file lnInclude/messageStream.C at line 200.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::error::abort() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 Foam::messageStream:perator Foam::OSstream&() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#3 Foam::messageStream:perator()(char const*, char const*, int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4 Foam::zone::checkDefinition(int, bool) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/checkMesh"
#7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Aborted (core dumped)
this is my new blockMesh file
vertices
( -8 0 0 ) //1
( 6 0 0 ) //2
( 17 0 0 ) //3
( 32 0 0 ) //4
( -8 0.3 0 ) //5
( 12 0.3 0 ) //6
( 14 0.3 0 ) //7
( 32 0.3 0 ) //8
( -8 0.5 0 ) //9
( 12 0.5 0 ) //10
( 14 0.5 0 ) //11
( 32 0.5 0 ) //12
( -8 0 1 ) //13
( 6 0 1 ) //14
( 17 0 1) //15
( 32 0 1) //16
( -8 0.3 1 ) //17
( 12 0.3 1) //18
( 14 0.3 1) //19
( 32 0.3 1) //20
( -8 0.5 1) //21
( 12 0.5 1) //22
( 14 0.5 1) //23
( 32 0.5 1) //24
blocks
hex (0 1 5 4 12 13 17 16) ( 1000 120 1 ) simpleGrading (1 1 1) //block0
hex (2 3 7 6 14 15 19 18) ( 900 120 1 ) simpleGrading (1 1 1) //block1
hex (4 5 9 8 16 17 21 20) ( 1000 80 1 ) simpleGrading (1 1 1) //block2
hex (5 6 10 9 17 18 22 21) ( 100 80 1 ) simpleGrading (1 1 1) //block3
hex (6 7 11 10 18 19 23 22) ( 900 80 1 ) simpleGrading (1 1 1) //block4
edges
boundary
inlet
type patch;
faces
(0 12 16 4)
(4 16 20 8)
bottom
type wall;
faces
(0 1 13 12)
(1 5 17 13)
(5 6 18 17)
(6 2 14 18)
(2 3 15 14)
outlet
type patch;
faces
(3 15 19 7)
(7 19 23 11)
atmosphere
type patch;
faces
(8 9 21 20)
(9 10 22 21)
(10 11 23 22)
frontBack
type empty;
faces
(0 4 5 1)
(2 6 7 3)
(4 8 9 5)
(5 9 10 6)
(6 10 11 7)
(12 13 17 16)
(14 15 19 18)
(16 17 21 20)
(17 18 22 21)
(18 19 23 22)
mergePatchPairs
Any ideas how to fix the problem? thank you so much for your help
luigi21 is offline   Reply With Quote
Old   February 14, 2014, 14:29
Elia Daniele
fakekarma is on a distinguished road
Hallo Luis,
I've run your case in OF2.1.1. Everything is fine for me.
I've attached the log of both blockMesh and checkMesh.
Are you sure that you have cleaned the polyMesh folder before running blockMesh and checkMesh?
Delete alla the files in constant/polyMesh except the blockMeshDict one.
Try to run both applications again and see what happens.
I think you have some old Zone file that conflicts with the new mesh.
Hope it helps.
Regards,
Elia
fakekarma is offline   Reply With Quote
Old   February 17, 2014, 13:04
Default mesh error solved
  #43
Luis Miguel
Hi Ellia...
Your advice worked well the error has gone, but when I'm running in parallel I get an error in the MULES, I've read this is because of a bad decomposition in the geometric domain but I'm not sure if this error is due to the way I've created my mesh taking into account that my checkMesh now runs well, check this error out:
Foam::error:rintStack(Foam::Ostream&)Foam::error :rintStack(Foam::Ostream&) at ??:?
[0] #1 Foam::sigFpe::sigHandler(int) at ??:?
[1] #1 Foam::sigFpe::sigHandler(int) at ??:?
[1] #2 at ??:?
[0] #2 in "/lib/x86_64-linux-gnu/libc.so.6"
[0] #3 void Foam::MULES::limiter<Foam::geometricOneField, Foam::zeroField, Foam::zeroField>(Foam::Field<double>&, Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::zeroField const&, Foam::zeroField const&, double, double, int) in "/lib/x86_64-linux-gnu/libc.so.6"
[1] #3 void Foam::MULES::limiter<Foam::geometricOneField, Foam::zeroField, Foam::zeroField>(Foam::Field<double>&, Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::zeroField const&, Foam::zeroField const&, double, double, int) at ??:?
[0] #4 void Foam::MULES::limit<Foam::geometricOneField, Foam::zeroField, Foam::zeroField>(Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, Foam::zeroField const&, Foam::zeroField const&, double, double, int, bool) at ??:?
What do you think of that? now I'm running without use parallel run and the simulation stops in the second 3.16 without any error, I mean still runs but it's not making any computation at all. thanks for your help
Best regards.
Old   February 18, 2014, 03:42
Elia Daniele
Hi Luis,
I cannot help you further with that. Since I have no experience with MULES scheme, that I think has something to do with VOF problems, I suggest you to open a new thread somewhere under VOF section, or something similar, maybe someone could help you more!
Regards,
Elia
Old   November 1, 2015, 14:52
Default Problem with mergePatchPairs
  #45
Martin
Ramwi is on a distinguished road
Dear foamers,
I am quite newbie in the whole openfoam thing and I cannot wrap my head around the mesh stitching.
I am trying to create a mesh consisting of several blocks (please consult the attached image)
As I need the number of cells in one of the directions to change, I dividied all to different blocks.
However, when I try to merge adjacent patches, I got the following error:
Zero length edge detected.  Probable projection error: slave patch probably does not project onto master.  Please switch on enriched patch debug for more info
    From function void enrichedPatch::calcCutFaces() const
    in file slidingInterface/enrichedPatch/enrichedPatchCutFaces.C at line 263.
FOAM aborting
my blockMeshDict is:
| \      /  F ield         | OpenFOAM: The Open Source CFD Toolbox           |
|  \    /   O peration     | Version:  2.3.0                                 |
|   \  /    A nd           | Web:      www.OpenFOAM.org                      |
|    \/     M anipulation  |                                                 |
FoamFile
      version      2.0;
      format      ascii;
      class          dictionary;
      location      "constant/polyMesh";
      object      blockMeshDict;
convertToMeters     1;
vertices
     ( 0.0 0.0 0.0 )    //0
     ( 1.0 0.0 0.0 )    //1
     ( 1.0 1.0 0.0 )    //2
     ( 0.0 1.0 0.0 )    //3
     ( 0.25 0.25 0.1 )    //4
     ( 0.75 0.25 0.1 )    //5
     ( 0.75 0.75 0.1 )    //6
     ( 0.25 0.75 0.1 )    //7
     ( 0.25 0.25 0.1 )    //8
     ( 0.75 0.25 0.1 )    //9
     ( 0.75 0.75 0.1 )    //10
     ( 0.25 0.75 0.1 )    //11
     ( 0.5 0.5 0.2 )    //12
     ( 0.0 0.0 0.4 )    //13
     ( 1.0 0.0 0.4 )    //14
     ( 1.0 1.0 0.4 )    //15
     ( 0.0 1.0 0.4 )    //16
     ( 0.25 0.25 0.4 )    //17
     ( 0.75 0.25 0.4 )    //18
     ( 0.75 0.75 0.4 )    //19
     ( 0.25 0.75 0.4 )    //20
     ( 0.25 0.25 0.4 )    //21
     ( 0.75 0.25 0.4 )    //22
     ( 0.75 0.75 0.4 )    //23
     ( 0.25 0.75 0.4 )    //24
     ( 0.5 0.5 0.4 )    //25
     ( 0.0 0.0 0.8 )    //26
     ( 1.0 0.0 0.8 )    //27
     ( 1.0 1.0 0.8 )    //28
     ( 0.0 1.0 0.8 )    //29
     ( 0.25 0.25 0.8 )    //30
     ( 0.75 0.25 0.8 )    //31
     ( 0.75 0.75 0.8 )    //32
     ( 0.25 0.75 0.8 )    //33
     ( 0.25 0.25 0.8 )    //34
     ( 0.75 0.25 0.8 )    //35
     ( 0.75 0.75 0.8 )    //36
     ( 0.25 0.75 0.8 )    //37
     ( 0.5 0.5 0.8 )    //38
     ( 0.0 0.0 1.2 )    //39
     ( 1.0 0.0 1.2 )    //40
     ( 1.0 1.0 1.2 )    //41
     ( 0.0 1.0 1.2 )    //42
     ( 0.25 0.25 1.2 )    //43
     ( 0.75 0.25 1.2 )    //44
     ( 0.75 0.75 1.2 )    //45
     ( 0.25 0.75 1.2 )    //46
     ( 0.25 0.25 1.2 )    //47
     ( 0.75 0.25 1.2 )    //48
     ( 0.75 0.75 1.2 )    //49
     ( 0.25 0.75 1.2 )    //50
     ( 0.5 0.5 1.2 )    //51
edges
blocks
     hex
          ( 0 1 5 4 13 14 18 17 )
          ( 2 1 5 )      simpleGrading      ( 1.0 1.0 1.0 )
     hex
          ( 1 2 6 5 14 15 19 18 )
     hex
          ( 2 3 7 6 15 16 20 19 )
     hex
          ( 3 0 4 7 16 13 17 20 )
     hex
          ( 8 9 12 12 21 22 25 25 )
          ( 1 1 5 )      simpleGrading      ( 1.0 1.0 1.0 )
     hex
          ( 9 10 12 12 22 23 25 25 )
     hex
          ( 10 11 12 12 23 24 25 25 )
     hex
          ( 11 8 12 12 24 21 25 25 )
     hex
          ( 13 14 18 17 26 27 31 30 )
     hex
          ( 14 15 19 18 27 28 32 31 )
     hex
          ( 15 16 20 19 28 29 33 32 )
     hex
          ( 16 13 17 20 29 26 30 33 )
     hex
          ( 21 22 25 25 34 35 38 38 )
     hex
          ( 22 23 25 25 35 36 38 38 )
     hex
          ( 23 24 25 25 36 37 38 38 )
     hex
          ( 24 21 25 25 37 34 38 38 )
     hex
          ( 26 27 31 30 39 40 44 43 )
     hex
          ( 27 28 32 31 40 41 45 44 )
     hex
          ( 28 29 33 32 41 42 46 45 )
     hex
          ( 29 26 30 33 42 39 43 46 )
     hex
          ( 34 35 38 38 47 48 51 51 )
     hex
          ( 35 36 38 38 48 49 51 51 )
     hex
          ( 36 37 38 38 49 50 51 51 )
     hex
          ( 37 34 38 38 50 47 51 51 )
boundary
    slave1
    type patch;
    faces
    ( 4 5 18 17 )
    ( 17 18 31 30 )
    ( 30 31 44 43 )
    ( 5 6 19 18 )
    ( 18 19 32 31 )
    ( 31 32 45 44 )
    ( 6 7 20 19 )
    ( 19 20 33 32 )
    ( 32 33 46 45 )
    ( 7 4 17 20 )
    ( 20 17 30 33 )
    ( 33 30 43 46 )
    master1
    type patch;
    faces
    ( 8 9 22 21 )
    ( 21 22 35 34 )
    ( 34 35 48 47 )
    ( 9 10 23 22 )
    ( 22 23 36 35 )
    ( 35 36 49 48 )
    ( 10 11 24 23 )
    ( 23 24 37 36 )
    ( 36 37 50 49 )
    ( 11 8 21 24 )
    ( 24 21 34 37 )
    ( 37 34 47 50 )
mergePatchPairs
     (    master1 slave1    )
Please, I would be gratefull for any advice.
Best regards,
Martin
Note: I am also attaching a minimal example of the problematic case.
Ramwi is offline   Reply With Quote
Old   December 30, 2015, 08:44
  #46
Martin
Dear Foamers,
back here again. The solution to my problem might be divided to the following steps:
  1. Divide the mesh to completely separate blocks (I divided it to 4 prisms which did not share any vertices).
  2. Subdivide the resulting prisms by the "layers" which should contain different number of cells
  3. Merge resulting patches in 1 direction by mergePatchPairs
  4. Merge the rest of the patches using stitchMesh utility
  5. Use zipUpMesh utility to improve the mesh quality
Note: Also, it is much better to use higher number of cells.
Resulting mesh then looks (top view) like this:
However, the resulting mesh is of a pure quality which can be seen on this solution (corresponds to water flow on steel, ReL = 60, interFoam):
Note: In my case, a much better approach was to replace the necessity of using "prism-like" blocks by using curved edges (polyLine).
Old   March 9, 2016, 13:04
  #47
Adam
Gates is on a distinguished road
Dear Foamers,
I am new to openFoam i would to like seek advice regarding meshing..here is my blockMeshDict,snappyHexMesh
blockMeshDict.txt snappyHexMeshDict.txt
after run blockMesh command it shows this after run blockMesh.txt
snappyHexMesh and paraFoam..paraview only shows my stl file but do not have domain..
i hope someone can help me
Gates is offline   Reply With Quote
Old   March 26, 2016, 07:13
Martin
Hello Gates,
Did you manage to solve your problem? If not, please could you paste the commands you use to create your mesh? And also the corresponding logs (at least something like "after run snappyHexMesh".
Best wishes,
Martin
Old   May 29, 2016, 05:25
Default blockMesh error
  #49
thanasisB is on a distinguished road
Hello to everyone, I have a problem while I'm trying to create my blockMesh. I've checked my mesh several times, but i cannot find the error. It shows me the message:
Inconsistent number of faces between block pair 3 and 4
From function blockMesh::calcMergeInfo()
in file blockMesh/blockMeshMerge.C at line 217.
FOAM exiting
Could anyone help me?
thanasisB is offline   Reply With Quote
Old   May 29, 2016, 07:28
Marco Atzori
Atzori is on a distinguished road
Hi!
I tried to use your blockMeshDict, but I obtain a "bad" warning before the error:
Creating block mesh topology
--> FOAM Warning :
    From function polyMesh::polyMesh(... construct from shapes...)
    in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 903
    Found 3 undefined faces in mesh; adding to default patch.
I advise you to solve this warning before: check again the faces (I know: it is very boring).
BTW, if I remember properly, the error in itself could be related with the fact that you cannot put a vertex on an edge: a face can match with another face only, i.e.: edges should be enterly in common between near cells.
Hope that helps!
Atzori is offline   Reply With Quote
Old   May 29, 2016, 21:32
Antimony is on a distinguished road
Your problem comes from the following blocks:
 hex (4 9 10 5 33 38 39 34) (3 5 1) simpleGrading (1 1 1)
 hex (3 8 9 4 32 37 38 33) (6 26 1) simpleGrading (1 1 1)
And is related to the fact that unless you have duplicate vertices defining duplicate lines, you cannot have different mesh resolutions on an edge.
In your case, in the first instance, edge connected by the vertices 4 & 9 has 3 divisions. In the second instance, edge connected by the vertices 4 & 9 has 6 divisions.
This is not allowed by blockMesh.
Hope this helps.
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   May 30, 2016, 10:51
Thank you very much for your help. I guess that if i want to dense my mesh, i have to use edgeGrading command. Am i right???
Thank you again!
blockmeshdict block mesh
Thread Tools
Trackbacks are On
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 42 May 14, 2012 20:48
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
