[Other] How to excecute allrun in windows openfoam
Old   November 24, 2009, 05:53
Exclamation How to excecute allrun in windows openfoam
padhu
padmanathan is on a distinguished road
hi all,
I'm using openfoam designer version 1.0 windows based.
While using dam break tutorial we need to execute Allclean and Allrun files, how to execute these files in windows Openfoam?
thanks in advance.
padhu.
padmanathan is offline   Reply With Quote
Old   November 28, 2011, 09:17
tH3f0rC3 is on a distinguished road
Hi there,
I have the same question.
In Linux you just have to type in ./Allrun
But this doesn't work with the wondows version.
Best Regards
tH3f0rC3 is offline   Reply With Quote
Old   November 28, 2011, 16:27
Retired Super Moderator
Bruno Santos
Greetings tH3f0rC3,
You've got at least 4 options:
  1. Install MSys and try to figure out how to set-up the OpenFOAM environment on it.
  2. Install Cygwin... and try to figure how to set-up the OpenFOAM environment on it.
  3. If both fail, try going back to MSys and instead of starting an MSys terminal, try to use only "sh.exe" from it to run the "Allrun" script.
    sh.exe Allrun
  4. Open the "Allrun" script with a compatible text editor (Notepad2 for example, some instructions provided here: http://www.cfd-online.com/Forums/ope...tml#post274751 post #18) and then read the commands listed in the "Allrun" script, translate them and manually execute the commands that do work on the Windows Command Line (WCL).
    For example, the "runApplication" command is a shell script that will not work in WCL.
Disclaimer: I'm the guy who develops blueCFD and in blueCFD we've already got a working solution of running OpenFOAM in Windows using MSys. But blueCFD is a paid service, so I can't disclosure the actual solution
Best regards,
Bruno
Edit: I had forgotten I had written some hints about this about a year ago here: Setting up shop in Windows. I only noticed this after reading another post by tH3f0rC3 here: http://www.cfd-online.com/Forums/ope...tml#post334236
allclean, allrun, dam break
How to run OpenFoam commands with windows command line maksjood OpenFOAM Running, Solving & CFD 1 June 4, 2018 11:19
OpenFOAM 4.0 Released CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 2 October 6, 2017 05:40
openfoam is installed on linux, but windows is damaged! minaret Lounge 5 April 7, 2015 21:58
Caelus: fork of OpenFOAM cnsidero OpenFOAM Announcements from Other Sources 7 November 11, 2014 22:55
Parallel run of OpenFOAM in linux and windows side by side m2montazari OpenFOAM Running, Solving & CFD 5 June 24, 2011 03:26
