[Commercial meshers] Conversion form .ccm to openFoam |
September 16, 2011, 05:35 |
Viktoria Erfurt
I'm trying to converge a .ccm file to openFoam but first I need ccm26ToFoam. By using the comand: $FOAM_APP/utilities/mesh/conversion/Optional/Allwmake I get this reply: + /opt/ThirdParty-2.0.1/AllwmakeLibccmio + cd libccmio-2.6.1 + cpMakeFiles libccmio + set +x cpMakeFiles libccmio . + wmake libso '/opt/ThirdParty-2.0.1/platforms/linux64GccDPOpt/lib/libccmio.so' is up to date. + '[' -e /opt/ThirdParty-2.0.1/platforms/linux64GccDPOpt/lib/libccmio.so ']' + wmake ccm26ToFoam g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam201/src/finiteVolume/lnInclude -I/opt/openfoam201/src/meshTools/lnInclude -I/opt/ThirdParty-2.0.1/libccmio-2.6.1 -I/opt/ThirdParty-2.0.1/libccmio-2.6.1/lnInclude -IlnInclude -I. -I/opt/openfoam201/src/OpenFOAM/lnInclude -I/opt/openfoam201/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed Make/linux64GccDPOpt/ccm26ToFoam.o -L/opt/openfoam201/platforms/linux64GccDPOpt/lib \ -lfiniteVolume -lmeshTools -L/opt/ThirdParty-2.0.1/platforms/linux64GccDPOpt/lib -lccmio -lOpenFOAM -ldl -lm -o /opt/openfoam201/platforms/linux64GccDPOpt/bin/ccm26ToFoam /usr/lib64/gcc/x86_64-suse-linux/4.5/../../../../x86_64-suse-linux/bin/ld: warning: libtriSurface.so, needed by /opt/openfoam201/platforms/linux64GccDPOpt/lib/libfiniteVolume.so, not found (try using -rpath or -rpath-link) /usr/lib64/gcc/x86_64-suse-linux/4.5/../../../../x86_64-suse-linux/bin/ld: warning: libPstream.so, needed by /opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so, not found (try using -rpath or -rpath-link) /opt/openfoam201/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::triSurface(Foam::fileName const&)' /opt/openfoam201/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::UIPstream::read(Foam::UPstream::commsTypes, int, char*, long, int)' /opt/openfoam201/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::triSurface()' /opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so: undefined reference to `Foam::UIPstream::UIPstream(Foam::UPstream::commsT ypes, int, Foam:ynamicList<char, 0u, 2u, 1u>&, int&, int, bool, Foam::IOstream::streamFormat, Foam::IOstream::versionNumber)' /opt/openfoam201/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::scalePoints(double)' /opt/openfoam201/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::triSurface(Foam::fileName const&)' /opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so: undefined reference to `Foam::UPstream::abort()' /opt/openfoam201/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::geometricSurfacePatch:perator==(Foam::geo metricSurfacePatch const&) const' /opt/openfoam201/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::subsetMesh(Foam::List<bool> const&, Foam::List<int>&, Foam::List<int>&) const' /opt/openfoam201/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::edgeOwner() const' /opt/openfoam201/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::triSurface(Foam::List<Foam::lab elledTri> const&, Foam::List<Foam::geometricSurfacePatch> const&, Foam::Field<Foam::Vector<double> > const&)' /opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so: undefined reference to `Foam::UPstream::init(int&, char**&)' /opt/openfoam201/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::geometricSurfacePatch::geometricSurfacePatc h()' /opt/openfoam201/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::UIPstream::UIPstream(int, Foam::PstreamBuffers&)' /opt/openfoam201/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::triSurface::~triSurface()' /opt/openfoam201/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::triSurface:perator=(Foam::triSurface const&)' /opt/openfoam201/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::reduce(double&, Foam::sumOp<double> const&)' /opt/openfoam201/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::sortedEdgeFaces() const' /opt/openfoam201/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::triSurface(Foam::List<Foam::lab elledTri> const&, Foam::Field<Foam::Vector<double> > const&)' /opt/openfoam201/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::triSurface(Foam::triSurface const&)' /opt/openfoam201/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::triSurface(Foam::List<Foam::lab elledTri>&, Foam::List<Foam::geometricSurfacePatch> const&, Foam::Field<Foam::Vector<double> >&, bool)' /opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so: undefined reference to `Foam::UPstream::addValidParOptions(Foam::HashTabl e<Foam::string, Foam::word, Foam::string::hash>&)' /opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so: undefined reference to `Foam::UPstream::exit(int)' /opt/openfoam201/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::faceTriangulation::faceTriangulation(Foam:: Field<Foam::Vector<double> > const&, Foam::face const&, Foam::Vector<double> const&, bool)' /opt/openfoam201/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::~triSurface()' /opt/openfoam201/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::triSurface::write(Foam::fileName const&, bool) const' /opt/openfoam201/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `typeinfo for Foam::triSurface' /opt/openfoam201/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::movePoints(Foam::Field<Foam::Ve ctor<double> > const&)' /opt/openfoam201/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam:imensionedField<int, Foam::triSurfaceGeoMesh>::typeName' /opt/openfoam201/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::triSurface(Foam::triSurface const&)' /opt/openfoam201/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::markZones(Foam::List<bool> const&, Foam::List<int>&) const' /opt/openfoam201/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::UOPstream::write(Foam::UPstream::commsTypes , int, char const*, long, int)' /opt/openfoam201/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::writeStats(Foam::Ostream&) const' /opt/openfoam201/platforms/linux64GccDPOpt/lib/libmeshTools.so: undefined reference to `Foam::triSurface::clearOut()' /opt/openfoam201/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::UPstream::waitRequests()' collect2: ld returned 1 exit status make: *** [/opt/openfoam201/platforms/linux64GccDPOpt/bin/ccm26ToFoam] Fehler 1 I'm using openFoam 2.0.1, which I has just installed on openSuse 11.3. Can somebody please help me to solve this problem? Do I need to recompile gcc in order to compile openFoam first, like it is written in the http://openfoamwiki.net/index.php/Ho...nFOAM#Preamble Or can I avoid it by this problem? Thanks in advance! With regards, Viktoria |
November 29, 2011, 16:40 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Viktoria,
Sorry for the really late reply, but I only saw your post now... Anyway, the solution is already posted here: http://www.cfd-online.com/Forums/ope...tml#post316994 - post #29. I haven't tested it with the openSUSE version but it should work. Best regards, Bruno
ccm, ccm+, ccm+ 4, ccm26tofoam |
Display Modes | |
[Commercial meshers] Conversion Fluent cas and dat file to OpenFoam | matteo_gautero | OpenFOAM Meshing & Mesh Conversion | 11 | July 14, 2020 12:09 |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 14:24 |
[Commercial meshers] Mesh conversion .gtm to OpenFOAM | ansab | OpenFOAM Meshing & Mesh Conversion | 2 | December 6, 2016 13:48 |
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 21, 2016 11:50 |
Modified OpenFOAM Forum Structure and New Mailing-List | pete | Site News & Announcements | 0 | June 29, 2009 05:56 |
