[snappyHexMesh] STL file
Old   January 13, 2012, 08:28
Default STL file
stephane sanchi
openfoam_user is on a distinguished road
I have problem with newly created STL files.
I use OF-2.1.x.
I have created an STL file with ICEMCFD version 13.
But SHM doesn't see any patch:
Adding patches for surface regions
Patch Type Region
Added patches in = 0 s
Has someone encountered same kind of problem recently.
Best regards,
Stephane
openfoam_user is offline   Reply With Quote
Old   January 15, 2012, 08:53
Retired Super Moderator
Bruno Santos
Hi Stephane,
OK, there are several reasons why this might have happened:
  • The STL file might not be in a visible place in the initial bounding box mesh.
  • The resolution of the bounding mesh might be insufficient to have enough lines crossing the STL geometry.
  • The names used in "snappyHexMeshDict" might not relate directly to the STL file.
  • Which "snappyHexMeshDict" file are you using as reference? If it was from OpenFOAM 1.7 or older, I think those aren't compatible with the new definitions on and above 2.0.
  • Is the STL file in binary or ASCII format?
  • Just in case... Did you try this with OpenFOAM 2.0.x as well?
Best regards,
Bruno
Old   January 16, 2012, 04:19
stephane sanchi
Hi Bruno,
None of your proposals solve my problem.
It is strange because when I use the surfaceFeatureExtract command to extract the edges sHM see the edges (and do the refinement). But sHM still doesn't any patch so it can't delete any cells inside or outside.
Best regards,
Stephane.
Old   January 16, 2012, 05:24
stephane sanchi
Hi Bruno,
If I write as below sHM see the patch:
geometry
flange.stl
type triSurfaceMesh;
name flange;
But if I write as below sHM doesn't see any patch:
geometry
flange.stl
regions
FLANGE// Named region in the STL file
name flange;// User-defined patch name
Why ?
Regards,
Stephane.
Old   January 16, 2012, 15:14
Bruno Santos
Hi Stephane,
I thought it might be something like that. Older versions of OpenFOAM (<2.0.0) allowed that kind of renaming. But with >= 2.0.0, snappyHexMesh considers a more hierarchical name assignment. If I'm not mistaken, you should write "flange_FLANGE" or "flange.FLANGE". Let me check the examples... no, wait, that's only when the naming procedure is done automatically, as shown in the examples:
  • "mesh/snappyHexMesh/flange"
  • "incompressible/simpleFoam/motorBike"
But tutorial "multiphase/interPhaseChangeFoam/cavitatingBullet" does support the naming procedure you are using!
OK, the base example present in the source code at "applications/utilities/mesh/generation/snappyHexMesh/" clearly indicates:
    sphere.stl
        //tolerance   1E-5;   // optional:non-default tolerance on intersections
        //maxTreeDepth 10;    // optional:depth of octree. Decrease only in case
                              // of memory limitations.
        // Per region the patchname. If not provided will be <name>_<region>.
        regions
            secondSolid
                name mySecondPatch;
Mmm... upon re-reading your last post, the comments are too much on top of the word itself:
FLANGE//
There is no space between the name and the comment marker!
Best regards,
Bruno
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 08:46
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 01:22
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 17:18
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
