Home > Forums > OpenFOAM Native Meshers: blockMesh
Create a "triangular box" with blockMesh
Like Tree1Likes
  • 1 Post By voingiappone
Old   January 18, 2012, 06:43
Default Create a "triangular box" with blockMesh
Luca Giannelli
voingiappone is on a distinguished road
Hello everybody....
I have a simple question that I cannot solve in any way.... would you like to help me with this thing??
I want to create a simple solid to use as a part of a more complicated patch. I am already able to create complicated meshes as log as only square faces are involved. For example, if a cube is needed I define the points:
Bottom face
1
2
3
4
Top Face
5
6
7
8
and then the block:
hex(1 2 3 4 5 6 7 8) (..etc etc....)
Easy. But what if I need to create a solid with two triangular faces??? Like for example:
vertices
(0 0 0) //1
(1 0 0) //2
(1 1 0) //3
(0 0 1) //4
(1 0 1) //5
(1 1 1) //6
blocks
hex (1 2 3 4 5 6) (10 10 10) simpleGrading (1 1 1)
If I run a code like this, the blockMesh crashes with a segfault!
Can somebody help me with this thing? It seems that nobody on the net needs to create triangular faces like this....
Thank you in advance!
Luca
voingiappone is offline   Reply With Quote
Old   January 18, 2012, 08:27
romant's Avatar
Roman Thiele
romant is on a distinguished road
Originally Posted by voingiappone View Post
Hello everybody....
Bottom face
1
2
3
4
Top Face
5
6
7
8
and then the block:
Luca
In order to create triangles, you need to place some points double into the hex part. Look at section 5.3.3 on http://www.openfoam.org/docs/user/blockMesh.php
~roman
romant is offline   Reply With Quote
Old   January 18, 2012, 21:13
Luca Giannelli
romant, thank you so much for the fast reply and the fast solution! It was indeed such an easy problem that no tutorial was needed --> no google results.
Believe it or not, I've been reading that page many times without actually reading "through" all the page... I always see that in OpenFOAM manual only the basic things are written and I thought it was the same here... the old RTFM rule still works.
Thanks so much.
Luca
Old   January 22, 2012, 21:52
Luca Giannelli
A small follow-up for those who will read this post in the future (if anybody will ).
I was able to create the mesh I need using the instructions on the link above (actually the blockMesh manual) but I would like to focus the attention to the creation phase.
If your mind works like mine does, you will end up creating your polygon using the same numbering technique as that on the page but rotated according to your configuration (for simplifying). I just wanted to warn that if you do this, you will end with a completely messed up x,y,z coordinate system in that polygon... only!
I was keeping getting the error "Inconsistent number of faces" but I was sure that all was right.... until I decided to just create the polygon itself on a separate blockmesh dictionary and watch the result; I noticed that the x, y and z axis for the resulting subdivision of the mesh where inverted!
This way I learnt that all the polygons in your mesh need the same axis system whichi can be achieved using always the same definition pattern for all the blocks... maybe this will look natural or trivial but keep this in mind when you will draw these atypical polygons!
Take care
Zazen likes this.
Old   May 22, 2015, 02:22
Elisa Lafforgue
Elisa-L is on a distinguished road
Hello everybody,
I have been looking for this for quite a while now, thank you very much! Indeed, it is simple, but I still have one little question: what do you do with the faces? If you have your triangular face, do you create it using double point as in the block?
I am sorry if it is a stupid question but I am new on CFD and don't really understand all...
Elisa
Elisa-L is offline   Reply With Quote
Thread Tools
Trackbacks are On
how to set periodic boundary conditions Ganesh FLUENT 13 January 22, 2014 05:11
Include list of points Hikachu OpenFOAM Native Meshers: blockMesh 0 June 20, 2011 09:03
Actuator disk model audrich FLUENT 0 September 21, 2009 07:06
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 01:07
