January 23, 2012, 14:21 |
Convert a interior face into a wall
M. Montero
Rep Power: 17 |
I hope anyone can help me. What I want is to convert some internal faces into patches. In the attached picture, the mesh is surrounded by a inlet, outlet, up and down. The down side is a wall. Now, I want to convert the selected internal faces ( the original mesh is 2D) into a wall. This is a sketch of a more difficult problem. The point is that in this way, I can select a wall condition at any position of the original mesh between inlet and outlet. I have tried 1.- create a set with Toposet, 2.- then use SetsToZones - noFlipMap to create the faceZones 3.- Modify boundary file and 0/files, then, createBaffles with the command: > createBaffles tab pared tab is the name of the set and of the faceZone. pared is the name of the patch added to the boundary file What I obtain is: Create time Create mesh for time = 0 Converting faces on zone "tab" into baffles. Found 9 faces on zone "tab" --> FOAM FATAL IO ERROR: incorrect first token, expected <label> or '(' or '{', found on line 0 the word 'pared' file: IStringStream.sourceFile at line 0. From function operator>>(Istream&, FixedList<T, Size>&) in file /share/apps/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/FixedListIO.C at line 71. FOAM exiting --------------------------- Thank you very much Best Regards |
Display Modes | |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 11:00 |
Very technical question about solving wall boundary layer ... | jlb001 | FLUENT | 6 | December 27, 2014 06:56 |
Need to Convert Wall to inetrior boundary in transient calculations. | sam181087 | Fluent UDF and Scheme Programming | 1 | December 23, 2014 08:28 |
[Commercial meshers] tmerge utility creates unwanted interface/walls comes in the final mesh | Shoonya | OpenFOAM Meshing & Mesh Conversion | 11 | January 20, 2012 07:23 |
UDF for wall slipping | HFLUENT | Fluent UDF and Scheme Programming | 0 | April 27, 2011 13:03 |
