can i have two blockmesh blocks one inside each other
i'm finding difficult to capture geometry such as a thin wing for SHM without creating a huge number of cells which crashes SHM.
i want to intersect the STL with the minimum amount of cells and for that i want to create a finer block around the STl and a coarser block around it. Can I do that with only two blocks, one inside each other? |
I would probably do that in snappyHexMesh rather than in blockMesh.
I have a refinement box defined in SHM
but the stl has to intersect the blocks in blockmesh otherwise it doesn't get captured, right? so a thin wing, even if it intersects spanwise and chordwise, if it doesn't intersect thicknesswise it won't show up? |
Sorry, I haven't quite understood what you mean… Do you want to refine the mesh on the domain or on the surface of your geometry?
what i want is to use blockmesh to make a finer block where the object is to ensure intersection and a coarser block for the whole domain. ideally with just two blocks.
1 Attachment(s)
So you need something like what depicted in the attached image.
The domain is a simple square block from blockMesh. The refinement zones are two blocks from SHM. |
but what if you replace the sphere with an airfoil whose thickness is less than the height of a BM block?
mmm… could you post a picture that shows your blockmesh and your airfoil within it?
thanks lore. i think my mesh is pretty coarse actually. i'll try another approach for airfoils, namely a fine 2d mesh with further refinement around the surface. that should give me the resolution i need without the resource drain.
