Home > Forums > Open Source Meshers: Gmsh, Netgen, CGNS, ...
ideasUnvToFoam with inner parts
Like Tree3Likes
Old   October 22, 2013, 15:24
Francois Beaubert
francois is on a distinguished road
Matt_h,
I'm facing the same problem.
I've tried to use the ideasUnvToFoam of OF v2.2.2 but got the same error message :
ideasUnvToFoam: ideasUnvToFoam.C:1271: int main(int, char**): Assertion `noveau > -1' failed.
I applied the patch and recompile the ideasUnvToFoam without more success.
Any tips, this bug is driving me insane ...
Thanks for your help
Have a nice day
François
francois is offline   Reply With Quote
Old   October 22, 2013, 20:07
Matt_h is on a distinguished road
well francois, my problem was a simple error in that I had named one of the faces twice...it took someone else to have a look at the output and point it out, then it was obvious.
Sorry I can't help much more than this!
Matt_h is offline   Reply With Quote
Old   October 23, 2013, 06:01
Francois Beaubert
Thanks Matt_h for your kind answer.
It looks like that the problem arise when the group of faces (named "Fin" in my case) is regonised as a faceZone.
I've tried with and without this group of faces in salome and the following error only appears when there is this faceZone.
This is the error message I get when using the internal group of faces "Fin" in Salome 6.6:
0: Fin is faceZone
1: Cyclic1 is patch
2: Cyclic1_mirrored is patch
3: Outlet_final is patch
4: Inlet_final is patch
5: PipeWall_final is patch
Constructing mesh with non-default patches of size:
    Cyclic1     150
    Cyclic1_mirrored    150
    Outlet_final        100
    Inlet_final 100
    PipeWall_final      400
--> FOAM Warning :
    From function polyMesh::polyMesh(... construct from shapes...)
    in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 626
    Found 400 undefined faces in mesh; adding to default patch.
Adding cell and face zones
 Face Zone Fin  25
Aborted (core dumped)
Matt_h, please could you send me your hdf or Salome python dump file for testing purpose ?
Or can someone send me a working example with a inner baffle to try to understand what's wrong with my however very simple case .
Thank you very much for your help.
Cheers
François
Old   March 11, 2014, 13:34
Amin S
xerxes92005 is on a distinguished road
Hi Matt&Francois. I have the same problem.
my geometry and mesh groups were created in salome-meca and seem to be ok. no duplicate faces or extra edges. when I use ideasUnvToFoam,terminal issues warning:
Sorting boundary faces according to group (patch)
0: inlet is patch
1: outlet is patch
2: cylinder is faceZone
3: top is patch
4: bottom is patch
5: front is patch
6: back is faceZone
inlet 450
outlet 450
top 450
bottom 450
front 5973
--> FOAM Warning :
From function polyMeshlyMesh(... construct from shapes...)
Found 6423 undefined faces in mesh; adding to default patch.
Face Zone cylinder 2025
how did you manage to fix it? what do you mean by "put top_bottom" twice??
xerxes92005 is offline   Reply With Quote
Old   April 19, 2014, 13:46
Alexs is on a distinguished road
Hi All
I am new with Salome and OpenFoam and I have similar problem with internal faces, i am tried to simulate a Sump Pump and i am making my geometry in Salome 6.6.0. My mesh was created using Partition operation.
After that i tried to Convert it with ideasUnvToFoam but throws me an error with internal faces
|  \\    /   O peration     | Version:  2.1.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.1.1-221db2718bbb
Exec   : ideasUnvToFoam Prueba_V2.unv
Date   : Apr 19 2014
Time   : 12:49:23
Host   : "Alexs-Laptop"
PID    : 6528
Case   : /home/alexs/Tesis/CFD_OpenFoam/fosa
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Processing tag:164
Starting reading units at line 3.
l:1
units:"  SI: Meter (newton)"
unitType:2
Unit factors:
    Length scale       : 1
    Force scale        : 1
    Temperature scale  : 1
    Temperature offset : 273.15
Processing tag:2420
Skipping tag 2420 on line 9
Skipping section at line 9.
Processing tag:2411
Starting reading points at line 20.
Read 49375 points.
Processing tag:2412
Starting reading cells at line 98773.
First occurrence of element type 11 for cell 1 at line 98774
First occurrence of element type 41 for cell 942 at line 101597
First occurrence of element type 111 for cell 20794 at line 141301
Read 272066 cells and 19852 boundary faces.
Processing tag:2467
Starting reading patches at line 685435.
For group 1 named wall trying to read 18444 patch face indices.
For group 2 named inlet trying to read 426 patch face indices.
For group 3 named outlet trying to read 50 patch face indices.
For group 4 named pipe_inlet trying to read 932 patch face indices.
Of 19852 so-called boundary faces 2210 belong to two cells and are therefore internal
0: wall is faceZone
1: inlet is patch
2: outlet is patch
3: pipe_inlet is faceZone
    inlet    426
    outlet    50
--> FOAM Warning :
    in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 619
    Found 17166 undefined faces in mesh; adding to default patch.
 Face Zone wall     18444
Abortado (`core' generado)
I would greatly appreciate any advice as to how to work around this problem, i am tried not to use the partition operation but i need maintain the two separate solid.
Alexs is offline   Reply With Quote
Old   April 22, 2014, 05:30
laurentb's Avatar
Laurent B
laurentb is on a distinguished road
Did you try to apply the patch ideasUnvToFoam.patch ?
laurentb is offline   Reply With Quote
Old   April 22, 2014, 12:22
Originally Posted by laurentb View Post
Hi Laurentb
Yes, i already applied the patch, but i'm still having the trouble.
Any suggestions?
Best Regards
Old   June 16, 2014, 09:53
Default Segmentation Fault (core dumped)
  #28
NewMember is on a distinguished road
Hi at all,
I want to import files from Salome to OpenFoam with "ideasUnvToFoam". It is working with easy geometric shapes but when it is getting a little bit more complex there is coming the following message in the shell:
Create time
Processing tag:164
l:1
unitType:2
Unit factors:
Length scale : 1
Force scale : 1
Processing tag:2420
Processing tag:2411
Read 1888 points.
Processing tag:2412
Starting reading cells at line 3799.
First occurrence of element type 11 for cell 1 at line 3800
First occurrence of element type 41 for cell 1537 at line 8408
Read 0 cells and 3744 boundary faces.
Processing tag:2467
Starting reading patches at line 15898.
For group 1 named Wall trying to read 130 patch face indices.
For group 2 named Temp_Spot trying to read 26 patch face indices.
0: Wall is #0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigSegv::sigHandler(int) at ??:?
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
at ??:?
#4 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
at ??:?
Segmentation fault (core dumped)
Can anybody tell me the meaning or what to do next?
Thank you for your help!!
Best regards!
NewMember is offline   Reply With Quote
Old   January 9, 2015, 08:33
Default Hiiii
  #29
Manjunath Reddy
manju819 is on a distinguished road
Check patches again in salome. On two patches you might have given same name.
manju819 is offline   Reply With Quote
Old   May 7, 2015, 10:30
Howar
Howard is on a distinguished road
Originally Posted by NewMember View Post
Hi at all,
Create time
Processing tag:164
l:1
unitType:2
Unit factors:
Length scale : 1
Force scale : 1
Processing tag:2420
Processing tag:2411
Read 1888 points.
Processing tag:2412
Processing tag:2467
at ??:?
at ??:?
Best regards!
I solve the same problem by check and make sure different patches don't have same faces.
Howard is offline   Reply With Quote
Thread Tools
Trackbacks are On
ideasUnvToFoam fails pizzaice OpenFOAM Meshing & Mesh Conversion 4 July 19, 2013 17:01
How to handle suction and pressure side of an airfoil as two different parts? TKE ANSYS Meshing & Geometry 4 March 17, 2011 07:49
How to handle suction and pressure side of an airfoil as two different parts? TKE ANSYS Meshing & Geometry 0 March 4, 2011 08:48
Creating 100 derived parts / Splitting derived parts for mass flux calculation xamo STAR-CCM+ 8 September 29, 2009 05:35
SnappyHexMesh complex geometries amp thin wall parts hsieh OpenFOAM Mesh Utilities 0 September 22, 2008 17:34
