-   Open Source Meshers: Gmsh, Netgen, CGNS, ... (http://www.cfd-online.com/Forums/openfoam-meshing-open/)
-   -   using nglib (http://www.cfd-online.com/Forums/openfoam-meshing-open/104605-using-nglib.html)
vijay.sudharshanam July 12, 2012 03:59
using nglib
Hello everyone.
I'm using nglib to load a CAD geometry in IGES format and generate surface mesh. I want to heal the geometry before generating the mesh but I do not find any healing functions in nglib.h. I tried to dig through the nglib source code and found that OCCGeometry has a healing function called HealGeometry(). But I'm not able to create an object of type OCCGeometry since it generates the compilation error "Undefined symbols: vtable for NetgenGeometry referenced from..." and "vtable for OCCGeometry referenced from...".
Can someone tell me how to create an instance of OCCGeometry in my code?
wyldckat July 14, 2012 11:56
Greetings vijay.sudharshanam and welcome to the forum!
You better try NETGEN's dedicated mailing list: http://sourceforge.net/projects/netgen-mesher/forums
Because this sub-forum is for how to use NETGEN and other open-source meshers with OpenFOAM.
Best regards,
Bruno
vijay.sudharshanam July 16, 2012 02:13
Hello Bruno.
I will post this in netgen related forum that you mentioned. Thank you.
