[snappyHexMesh] Parts of Geometry not meshed by snappyHexMesh
Old   July 5, 2012, 06:23
Default Parts of Geometry not meshed by snappyHexMesh
Deepak Cheekati
Turbulence is on a distinguished road
Hi Everyone,
I am currently trying to simulate free round jet flow. If the jet inlet diameter is d, my computational domain is a cylinder which is 250d in axial direction and has a diameter of 400d. PFA the image of background mesh with the geometry. Earlier I had problem of inlet pipe completely disappearing. So I chose a background mesh of this shape.
Now my inlet looks good, but my computational domain(the big cylinder) is not meshed.
Can anyone help me in this regard.
Thanks
Turbulence.
| \\ / O peration | Version: 2.1.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1;
vertices
(39.8 39.8 0)
(39.8 39.8 1.1)
(40.2 39.8 1.1)
(40.2 39.8 0)
(39.8 40.2 0)
(39.8 40.2 1.1)
(40.2 40.2 1.1)
(40.2 40.2 0)
(-5 -5 1.1)
(-5 -5 52)
(85 -5 52)
(85 -5 1.1)
(-5 85 1.1)
(-5 85 52)
(85 85 52)
(85 85 1.1)
blocks
hex (0 1 2 3 4 5 6 7) (100 100 100) simpleGrading (1 1 1)
hex (8 9 10 11 12 13 14 15) (200 200 200) simpleGrading (1 1 1)
boundary
bPlane
type patch;
faces
(0 1 2 3)
tPlane
type patch;
faces
(4 7 6 5)
fPlane
type patch;
faces
(0 4 5 1)
backPlane
type patch;
faces
(3 2 6 7)
lPlane
type patch;
faces
(0 3 7 4)
rPlane
type patch;
faces
(1 2 6 5)
BPlane
type patch;
faces
(8 9 10 11)
TPlane
type patch;
faces
(12 15 14 13)
FPlane
type patch;
faces
(8 12 13 9)
BackPlane
type patch;
faces
(11 15 14 10)
LPlane
type patch;
faces
(8 11 15 12)
RPlane
type patch;
faces
(9 10 14 13)
| \\ / O peration | Version: 2.0.1 |
| \\ / A nd | Web: www.OpenFOAM.com |
FoamFile
version 2.0;
format ascii;
class dictionary;
object snappyHexMeshDict;
castellatedMesh true;
snap true;
doLayers true;
addLayers true;
mergeTolerance 1e-06;
geometry
roundjet.stl
type triSurfaceMesh;
name round;
mergeSubRegions true;
meshQualityControls
maxNonOrtho 60;
maxBoundarySkewness 1.1;
maxInternalSkewness 0.7;
minVol 1e-13;
maxConcave 180;
minTwist 0.05;
minArea -1;
minTriangleTwist -1;
minDeterminant 0.001;
minFaceWeight 0.05;
minVolRatio 0.01;
minTetQuality 1e-30;
errorReduction 0.75;
nSmoothScale 4;
castellatedMeshControls
refinementSurfaces
round
level (8 10); // default (min max) refinement for surface
resolveFeatureAngle 45; //Applies maximum level of refinement to cells
//that can see intersections whose angle exceeds
refinementRegions
round
mode distance;
levels ((0.1 10) (0.5 4) (1 2));
locationInMesh (40 40 0.2);
maxLocalCells 1000000;
maxGlobalCells 2000000;
minRefinementCells 0;
nCellsBetweenLevels 5;
allowFreeStandingZoneFaces false;
features
snapControls
nSmoothPatch 20;
tolerance 2.0;
nSolveIter 30;
nRelaxIter 10;
addLayersControls
layers
round_a
nSurfaceLayers 3;
round_b
nSurfaceLayers 3;
round_c
nSurfaceLayers 3;
round_d
nSurfaceLayers 3;
round_e
nSurfaceLayers 3;
round_f
nSurfaceLayers 3;
round_g
nSurfaceLayers 3;
round_h
nSurfaceLayers 3;
round_i
nSurfaceLayers 3;
round_j
nSurfaceLayers 3;
expansionRatio 1.0;
finalLayerThickness 0.4;
minThickness 0.25;
nGrow 0;
relativeSizes true;
featureAngle 60;
nRelaxIter 7;
nSmoothSurfaceNormals 1;
nSmoothNormals 3;
nSmoothThickness 10;
maxFaceThicknessRatio 0.5;
nLayerIter 10;
maxThicknessToMedialRatio 0.2;
minMedianAxisAngle 80;
nBufferCellsNoExtrude 0;
Turbulence is offline   Reply With Quote
Old   July 5, 2012, 08:02
StSchiff
Hi Turbulence,
could you upload a picture without the stl file and with the 'wire' or 'surface with edges' option on? And also at other time steps than 0.
Regards
Stefanie
Old   July 5, 2012, 10:59
Deepak Cheekati
Hi StSchiff,
I have considerably modified the case folder, but with no success.
Now I have reached a stage where if my locationInMesh points to a point inside the inlet pipe, then only inlet pipe is meshed, and the cylinder is lost, vise versa.
Sorry I could not provide you with what you asked.
My paraview stopped working. Will post the pic as soon as possible.
Thank you very much for replying
Modified code:
FoamFile
version 2.0;
format ascii;
class dictionary;
snap true;
doLayers true;
addLayers true;
geometry
roundjet.stl
name round;
refinementBox1
type searchableBox;
min (39.9 39.9 -0.1);
max (40.1 40.1 0.3);
refinementBox2
type searchableBox;
min (-0.1 -0.1 0.9);
max (80.1 80.1 1.2);
refinementBox3
type searchableBox;
min (-0.1 -0.1 50);
max (80.1 80.1 51.2);
meshQualityControls
maxNonOrtho 60;
minVol 1e-13;
maxConcave 180;
minTwist 0.05;
minArea -1;
minFaceWeight 0.05;
minVolRatio 0.01;
nSmoothScale 4;
refinementSurfaces
round
refinementRegions
round
mode distance;
refinementBox1
mode inside;
levels ((1.0 80));
refinementBox2
mode inside;
levels ((1.0 100));
refinementBox3
mode inside;
levels ((1.0 100));
locationInMesh (40 40.1 0.3);
features
snapControls
nSmoothPatch 10;
tolerance 2.0;
nSolveIter 10;
nRelaxIter 10;
addLayersControls
layers
round_a
nSurfaceLayers 3;
round_b
nSurfaceLayers 3;
round_c
nSurfaceLayers 3;
round_d
nSurfaceLayers 3;
round_e
nSurfaceLayers 3;
round_f
nSurfaceLayers 3;
round_g
nSurfaceLayers 3;
round_h
nSurfaceLayers 3;
round_i
nSurfaceLayers 3;
round_j
nSurfaceLayers 3;
expansionRatio 1.0;
minThickness 0.25;
nGrow 0;
relativeSizes true;
featureAngle 60;
nRelaxIter 7;
nSmoothNormals 3;
nLayerIter 10;
FoamFile
version 2.0;
format ascii;
class dictionary;
convertToMeters 1;
vertices
(39.8 39.8 0)
(39.8 39.8 1.1)
(40.2 39.8 1.1)
(40.2 39.8 0)
(39.8 40.2 0)
(39.8 40.2 1.1)
(40.2 40.2 1.1)
(40.2 40.2 0)
(-5 -5 1.1)
(-5 -5 52)
(85 -5 52)
(85 -5 1.1)
(-5 85 1.1)
(-5 85 52)
(85 85 52)
(85 85 1.1)
blocks
boundary
bPlane
type patch;
faces
(0 1 2 3)
tPlane
type patch;
faces
(4 7 6 5)
fPlane
type patch;
faces
(0 4 5 1)
backPlane
type patch;
faces
(3 2 6 7)
lPlane
type patch;
faces
(0 3 7 4)
rPlane
type patch;
faces
(1 2 6 5)
BPlane
type patch;
faces
(8 9 10 11)
TPlane
type patch;
faces
(12 15 14 13)
FPlane
type patch;
faces
(8 12 13 9)
BackPlane
type patch;
faces
(11 15 14 10)
LPlane
type patch;
faces
(8 11 15 12)
RPlane
type patch;
faces
(9 10 14 13)
Old   August 7, 2012, 08:58
Kalyan
kalyangoparaju is on a distinguished road
Deepak,
If I understand your problem right, you have a cylinder ( pipe) within a bigger pipe(domain) right? And do you want to mesh the inside of the smaller pipe or outside of the smaller pipe?
Let us know so that we can be of more help :-)
Kalyan
kalyangoparaju is offline   Reply With Quote
Old   August 8, 2012, 14:03
Default SHM Problem
Tom
Irish09 is on a distinguished road
Deepak,
From what I understand of your problem, you may be attempting to do something in a more complicated fashion than necessary.
Look at my 2-dimensional figure here:
Figure A shows a cylinder representing where the jet will be protruding into the domain with which you want to study. It's hard to tell from your first image, but if your set up is like this, then OpenFOAM will not like having a mesh on two sides of a wall and to my knowledge there is no way around that.
Figure C shows the cylinder for the jet being directly next to the domain in which the jet will flow into. If you setup is like this, then when you tell SHM that the interior is inside your cylinder, then that is all that will mesh and if you tell it the interior is inside the larger domain, then that is all that will mesh. Once SHM reaches the boundary of what it perceives to be the interior of the flow it won't look any farther for more objects to mesh. Therefore one will inevitably not be meshed in this process.
Figure B shows the cylinder and the outlet domain as one STL file. This makes it slightly more complicated to apply boundary conditions as you have to use Salome, ProEngineer, Paraview, or some other program to split the surfaces into different parts, but it will mesh correctly in SHM.
In my opinion, it is probably easier to make the mesh that you are desiring using a blockMeshDict file directly. I know you can make circles by utilizing two arcs and hardcode all the necessary information into it, but it is probably still easier and will produce a better and more controllable mesh than SHM.
Hope this helps.
Irish09 is offline   Reply With Quote
Old   August 8, 2012, 16:27
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
Looking at situation A, it is possible to have internal faces (baffles), but not by default in blockMesh. If you can get the faces to exist (not too bad in blockMesh), then you have to do a little magic with topoSet and the baffles utilities (createBaffles and mergeOrSplitBaffles).
mturcios777 is offline   Reply With Quote
[ANSYS Meshing] CATIA Geometry Generation and Meshing danielsullivan ANSYS Meshing & Geometry 0 April 3, 2017 21:11
[snappyHexMesh] snappyHexMesh meshed inside an outside of stl bastil OpenFOAM Meshing & Mesh Conversion 5 May 7, 2016 16:12
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 08:17
how to mesh my geometry with two parts of volumes chankhar FLUENT 1 June 5, 2006 07:38
CFX10 post, geometry parts not visible Claudia CFX 0 May 19, 2006 07:22
