[mesh manipulation] datToFoam
Like Tree1Likes
  • 1 Post By wyldckat
Old   August 23, 2012, 10:50
Default datToFoam
chaos is on a distinguished road
hello!
it's my first time using openfoam and i can't even import my mesh
my inputfile is a nastran bulkdata file (.dat)
the syntax is really simple:
BEGIN BULK (koordinate and number of the nodes)
GRID,1,,588062.321633,253262.321633,1798.662318
GRID,2,,588062.321633,253392.110575,1760.908129
(number of the hexaedra nd the needed nodenumbers)
CHEXA 140928 145776 145835 145836 145777 149257 149316+
+ 149317 149258
i found the application dattofoam but theres no documentation what file exactly.
is it for nastran datfiles? because i always get this error:
Build : 2.1.1-221db2718bbb
Exec : datToFoam -noFunctionObjects planner.dat
Date : Aug 23 2012
Time : 07:25:57
Host : "ubuntu"
PID : 5661
Case : /home/stefan/OpenFOAM/stefan-2.1.1/run/dattofoam
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
--> FOAM FATAL IO ERROR:
wrong token type - expected word, found on line 0 the punctuation token ';'
file: IStringStream.sourceFile at line 0.
From function operator>>(Istream&, word&)
in file primitives/strings/word/wordIO.C at line 74.
FOAM exiting
i hope you can help me.
chaos is offline   Reply With Quote
Old   August 23, 2012, 14:24
Retired Super Moderator
Bruno Santos
Greetings chaos,
Welcome to using OpenFOAM! Since it's open-source, you have to go straight to the source code: https://github.com/OpenFOAM/OpenFOAM...am/datToFoam.C
Or go to the code documentation: http://www.openfoam.org/docs/cpp/ - search for datToFoam.
Seems like datToFoam isn't for Nastran files, because it references explicitly in the code this:
std::ifstream plot3dFile(args.args()[1].c_str());
If I'm not mistaken, OpenFOAM can only convert surfaces from Nastran's "*.nas" files:
surfaceConvert a.nas a.stl
Best regards,
Bruno
arnaud6 likes this.
Old   August 27, 2012, 02:22
thx for your help!
i also looked up the sourcecode but wasn't shure if it's compatible.
ok than i'll have to code it on my own.
thx again!
