[Netgen] Netgen refinement regions
Old   January 3, 2013, 04:49
Default Netgen refinement regions
Daniele Vicario
danvica is on a distinguished road
Is there any equivalent way to refine a region within Netgen ?
Something as refinementRegions in snappyHexMesh.
Thanks.
Daniele Vicario
blueCFD2.1 - Windows 7
danvica is offline   Reply With Quote
Old   January 3, 2013, 08:29
Philippose Rajan
philippose will become famous soon enough
Hello there,
A Good day to you!
Yes, there is a way of locally refining meshes in netgen.
If you look into the Meshing options, in the second tab, under the basic mesh size settings, you have a box where you can specify a "mesh size file". This file is a simple text-file with the extension ".msz", with the following format:
<num of points>
<x1> <y1> <z1> <maxH1>
<x2> <y2> <z2> <maxH2>
<x3> <y3> <z3> <maxH3>
<xN> <yN> <zN> <maxHN>
<num of lines>
<x11> <y11> <z11> <x12> <y12> <z12> <maxH1>
<x21> <y21> <z21> <x22> <y22> <z22> <maxH2>
<x31> <y31> <z31> <x32> <y32> <z32> <maxH3>
<xN1> <yN1> <zN1> <xN2> <yN2> <zN2> <maxHN>
The first set of points basically specifies the maximum mesh size at the given points, and the second set limits the maximum mesh size along the specified lines to the given values.
In case you do not want to limit mesh sizes along lines, specify a "0" for the "<num of lines>" followed by a new line.
Now.... the values specified in the mesh size file is taken into consideration after all the other mesh size definition functions, and hence, the mesh size file only needs to have those points where you really want the mesh to be locally refined.... all the other parts of the mesh will be meshed with the normal settings.
Be careful to specify the mesh sizes in the units in which the mesh geometry is defined :-)!
Hope this helps.... if you have any questions, feel free to put them up here, and I shall try to clarify them.
Have a nice day ahead!
Philippose
philippose is offline   Reply With Quote
Old   January 3, 2013, 09:44
Daniele Vicario
Thanks for the fast reply !
I already knew about points refinements but I missed the lines option.
Some questions:
- What does "locally" means ? How can you set the control distance of the points/lines ?
- Any plan to add a box option ? (Hey, you've got point and line: it seems natural to have all 3 dimensions... )
I could simulate a box option by N lines... but how to calculate N (see first question) ?
Thanks.
Daniele Vicario
Old   January 3, 2013, 09:48
Daniele Vicario
BTW, I forgot to ask you why in Netgen 5.0 there's no more the "Edit Face mesh size" voice.
On the release notes there's an indication regarding an automatic refinement but I don't understand how to manual modify a surface mesh size.
Daniele Vicario
Old   January 3, 2013, 10:26
Philippose Rajan
Hello again,
In answer to your previous post....
When you specify a mesh size file, Netgen internally constrains the maximum element mesh size around the specified areas (in the case of a line, an internal resolution is used... cant remember the actual value now) for both... the surface mesh as well as the volume elements (tets).
The function was put in on a "need-to" basis, and I guess the requirement for a "box" type mesh restriction never came up (though, I know that there is an internal function which already does exactly this.... except, as of now... it is only used internally :-)!)
For example.... in my cases so far, I have almost always only required annular cylindrical areas in which the mesh should be refined, and for that, I wrote a small python script which writes a ".msz" file (essentially a point-cloud with mesh sizes)
As for your last post regarding the "Edit Face Mesh Size" option :-)! When I implemented this function a couple of years ago, it was purely for either "STEP" or "IGES" files.
Did you compile Netgen 5.0 from scratch yourself? And which platform are you using? It looks like in your case, the OpenCascade support for Netgen 5.0 has not been enabled / compiled.
Philippose
Old   January 3, 2013, 11:14
Daniele Vicario
Thanks for the answers, I'll have to play a little with phyton...
Regarding Netgen 5.0, I just downloaded Netgen-5.0.0_x64.exe (http://sourceforge.net/projects/netg...4.exe/download)
There's a dev release but I haven't try it...
Daniele Vicario
Old   January 24, 2018, 12:48
alix cattermole
alixcattermole is on a distinguished road
I was wondering if you could explain this for me a bit more please as I am a beginner. I am hoping to create the mesh of a ship hull in a domain with added refinement around the ship's hull, mostly near the bow and stern. Would this be possible/recommended using this method?
alixcattermole is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh running killed! Mark JIN OpenFOAM Meshing & Mesh Conversion 7 June 14, 2022 01:37
[snappyHexMesh] Edge Refinement fracasce OpenFOAM Meshing & Mesh Conversion 3 December 2, 2017 13:30
[snappyHexMesh] snappyHexMesh refinement regions ignored guitarbren OpenFOAM Meshing & Mesh Conversion 2 April 9, 2013 03:59
killed "snappyHexMesh" parkh32 OpenFOAM Pre-Processing 2 April 8, 2012 17:12
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 03:23
