Salome to OpenFOAM patches tutorial
Hello everyone,
I found this a massive pain in the **** to figure out at first as I am just a beginner with this stuff. So I made a video so others starting out with OF and/or CAE in general have an easier time to figure it out. http://www.youtube.com/watch?v=1zQbU-E4k1U (corrected - Thankyou Nima Sam) http://www.calumdouglas.ch/openfoam/...-7-2-tutorial/ Its just to show how you can get a STEP file into Salome, set up the inlet/outlet/wall patches then import into OF and run it in parallel. Its an interFoam case which is basically a modified version of damBreak. All case files and such are available for download from my website to follow the video. Salome 7.2 OF 2.0.1 |
let me correct the video address ;) :
http://www.youtube.com/watch?v=1zQbU...layer_embedded |
Adding Prism layer
Thanks for this useful videos. I wanted to add prism layer in the tetrahedral mesh generated but since i am a new bee i am not able to generate that.Can you please provide some guidance to do it. i just wanted to add prism layer in a pipe with tetrahedral cells to capture boundary layer. Thanks Himanshu Sharma :) |
Got the solution for adding Prism layer
HI,
I got the solution in the manual how to add viscous layer in the 3 D mesh.its pretty easy. Regards Himanshu Sharma |
viscous layers
OK great,
So now make a video and explain so others can do it. C. |
