November 20, 2013, 14:06 |
Boundary Layer Mesh in GMSH
I am trying to create boundary layers around some walls in my model but there is something screwing up. 1. When I run the code only with BoundaryLayer 1 it works. But if I run it with both BoundaryLayers it only creates BoundaryLayer 2. 2. BoundaryLayer 2 isn't working correct (see picture). Does anyone know how the soultion of my problems could be. Code:
capillary = 0.0001; Jet_Disrupter = 0.0001; Walls = 0.001; Point(1) = {0, 0, 0, capillary}; Point(2) = {0.006, 0, 0, capillary}; Point(3) = {0.006, 0.000254, 0, capillary}; Point(4) = {0.006, 0.0008, 0, Walls}; Point(5) = {0.004, 0.0008, 0, Walls}; Point(6) = {0.004, 0.0064, 0, Walls}; Point(7) = {0, 0.0064, 0, Walls}; Point(8) = {0, 0.0123, 0, Walls}; Point(9) = {0.0045, 0.0123, 0, Walls}; Point(10) = {0.0595, 0.0123, 0, Walls}; Point(11) = {0.1043, 0.0011, 0, Walls}; Point(12) = {0.1045, 0.0011, 0, Walls}; Point(13) = {0.1045, 0.0123, 0, Walls}; Point(14) = {0.1300, 0.0123, 0, Walls}; Point(15) = {0.1300, 0, 0, Walls}; Point(16) = {0.02415, 0.0033, 0, Jet_Disrupter}; Point(17) = {0.02465, 0.0033, 0, Jet_Disrupter}; Point(18) = {0.02415, 0, 0, Jet_Disrupter}; Point(19) = {0.02465, 0, 0, Jet_Disrupter}; Point(20) = {-0.048, 0.000254, 0, capillary}; Point(21) = {-0.048, 0, 0, capillary}; Point(22) = {-0.046, 0.0015875, 0, Walls}; Point(23) = {-0.046, 0.005, 0, Walls}; Point(24) = {-0.062, 0, 0, Walls}; Point(25) = {-0.062, 0.005, 0, Walls}; Point(26) = {-0.048, 0.0015875, 0, Walls}; Line(1) = {24, 25}; Line(2) = {25, 23}; Line(3) = {23, 22}; Line(4) = {22, 26}; Line(5) = {26, 20}; Line(6) = {20, 3}; Line(7) = {3, 4}; Line(8) = {4, 5}; Line(9) = {5, 6}; Line(10) = {6, 7}; Line(11) = {7, 8}; Line(12) = {8, 9}; Line(13) = {9, 10}; Line(14) = {10, 11}; Line(15) = {11, 12}; Line(16) = {12, 13}; Line(17) = {13, 14}; Line(18) = {14, 15}; Line(19) = {15, 19}; Line(20) = {19, 17}; Line(21) = {17, 16}; Line(22) = {16, 18}; Line(23) = {18, 2}; Line(24) = {2, 1}; Line(25) = {1, 21}; Line(26) = {21, 24}; Line Loop(27) = {13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12}; Plane Surface(28) = {27}; Rotate {{1, 0, 0}, {0, 0, 0}, -0.08} { Surface{28}; } Extrude {{1, 0, 0}, {0, 0, 0}, 0.04} { Surface{28}; Layers{1}; // 1 Element thick Recombine; } Surface Loop(142) = {141, 59, 28, 63, 67, 71, 75, 78, 82, 86, 89, 96, 100, 104, 108, 112, 116, 120, 124, 128, 132, 136, 140}; Volume(143) = {142}; Physical Volume(144) = {1}; Physical Surface(145) = {96, 100}; Physical Surface(146) = {104, 108, 112, 116, 120, 124, 128, 132, 136}; Physical Surface(147) = {140}; Physical Surface(148) = {59, 63, 71, 67, 89, 82, 86}; Physical Surface(149) = {75, 78}; Physical Surface(150) = {141}; Physical Surface(151) = {28}; //BoundaryLayer1 Field[1] = BoundaryLayer; Field[1].EdgesList = {13, 14, 15, 16}; Field[1].NodesList = {9, 10, 11, 12, 13}; Field[1].hfar = 0.0005; Field[1].hwall_n = 0.0000005; Field[1].hwall_t = 0.001; Field[1].thickness = 0.0001; //0.0004 Field[1].ratio = 1.5; Field[1].fan_angle = 30; Field[1].Quads = 1; BoundaryLayer Field = 1; //BoundaryLayer2 Field[2] = BoundaryLayer; Field[2].EdgesList = {3, 4, 5, 6, 7, 8, 9, 10, 11}; Field[2].NodesList = {3, 4, 5, 6, 7, 8, 20, 22, 23, 26}; Field[2].hfar = 0.0005; Field[2].hwall_n = 0.0000005; Field[2].hwall_t = 0.001; Field[2].thickness = 0.0001; Field[2].ratio = 1.5; Field[2].fan_angle = 30; Field[2].Quads = 1; BoundaryLayer Field = 2; |
September 1, 2021, 03:43 |
chandra shekhar pant
Thanks for sharing your script/code, I found your post really helpful to make an boundary layer, have you tried been successful in your case? Any further comment will be a great help, thanks in advance. |
[Gmsh] Gmsh 3.0 - Boundary layer mesh | PaulBet | OpenFOAM Meshing & Mesh Conversion | 4 | December 2, 2019 09:33 |
My radial inflow turbine | Abo Anas | CFX | 27 | May 11, 2018 01:44 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
[snappyHexMesh] Boundary layer in a pipe | Clementhuon | OpenFOAM Meshing & Mesh Conversion | 6 | March 12, 2012 12:41 |
[snappyHexMesh] Boundary layer generation problems | ivan_cozza | OpenFOAM Meshing & Mesh Conversion | 0 | October 6, 2010 13:47 |
