[Netgen] Netgen: double triangles on overlapping parts
Old   November 28, 2013, 10:05
Default Netgen: double triangles on overlapping parts
kontras
kontra is on a distinguished road
For a surface mesh with Netgen,
when two surfaces overlap I get a duplicated mesh on the overlapping part.
healing tool doesn't work.
How can I avoid that?
(I tried the input file in both brep and iges format)
kontra is offline   Reply With Quote
netgen, overlap, triangle
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 07:31
Warning message C4133 while compiling Arminius Fluent UDF and Scheme Programming 0 October 2, 2017 11:44
Continuing User Defined Real Gas Model issues aeroman FLUENT 6 April 8, 2016 03:34
Missing math.h header Travis FLUENT 4 January 15, 2009 11:48
REAL GAS UDF brian FLUENT 6 September 11, 2006 08:23
