[Other] how to generate a series of grids
Old   January 7, 2014, 03:00
Default how to generate a series of grids
zdong
abbott.hn is on a distinguished road
"NPARC Alliance Tutorial on CFD Verification and Validation" said that :
"The easiest approach for generating the series of grids is to generate a grid with what one would consider fine grid spacing, perhaps reaching the upper limit of one's tolerance for generating a grid or waiting for the computation on that grid to converge. Then coarser grids can be obtained by removing every other grid line in each coordinate direction. This can be continued to create additional levels of coarser grids"
My question is :
are there any utilites in OpenFOAM or other package clould remove every other grid line in each coordinate direction of a grid?
PS: the grid i need to deal with is the discretization of the external flowfield around a very complex geometry configuration.
Thanks for your reply!!!
abbott.hn is offline   Reply With Quote
Old   January 7, 2014, 03:01
Bernhard
Bernhard is on a distinguished road
No, there is no such utility.
Bernhard is offline   Reply With Quote
[Commercial meshers] Using ICEM to generate unstructured grids and then transfer to be used in OPENFOAM Jingxue Wang OpenFOAM Meshing & Mesh Conversion 0 September 29, 2017 05:04
how do we generate the grids in the CFD program? yzeyue Main CFD Forum 0 March 8, 2014 21:33
How to generate tetrahedral/hybrid grids by blockmesh Tarak OpenFOAM 1 November 5, 2010 03:25
How to generate tetrahedral/hybrid grids by blockmesh Tarak OpenFOAM 0 October 4, 2010 15:00
Correct way to generate grids for boundary layer quarkz Main CFD Forum 5 November 23, 2006 23:25
