[Gmsh] Gmsh Error: Curve 1 already exists ???
Old   October 2, 2014, 10:32
Default Gmsh Error: Curve 1 already exists ???
sisi is on a distinguished road
When I try to open the attached file in Gmsh I receive the following error message:
line 35: Curve 1 already exists
sisi is offline   Reply With Quote
Old   October 2, 2014, 10:52
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
both Spline and Line define curves, so you should use Line(3). You can also use newl expression to get next available line number (http://www.geuz.org/gmsh/doc/texinfo...neral-commands).
alexeym is offline   Reply With Quote
Old   October 2, 2014, 11:21
Thank you!
[OpenFOAM.org] OpenFOAM 5.x (mrklein patch) and macOS High Sierra podallaire OpenFOAM Installation 14 March 27, 2020 14:45
[Gmsh] Converting gmsh to OpenFoam Friendly OpenFOAM Meshing & Mesh Conversion 3 June 26, 2018 05:46
[Gmsh] Insatlling gmsh from the source code-issue? CFD-Lover OpenFOAM Meshing & Mesh Conversion 20 June 12, 2018 06:39
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
