June 16, 2006, 07:24 |
Creating circle blockmesh
Hrvoje Jasak
Rep Power: 33 |
You can make a much nicer mesh than that: put a square in the middle and 4 blocks around it. The quality of the mesh will be better, you won't get the worning + the code will run faster.
Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
June 16, 2006, 08:27 |
You didn't get me right - I me
Hrvoje Jasak
Rep Power: 33 |
You didn't get me right - I meant a mesh like this:
You should be able to see 5 blocks. As for the discretisation, try using least square gradients and the rest should be OK. Hrv
October 13, 2014, 15:28 |
Rep Power: 13 |
how you calculate the arcs of the block? To my knowledge it's done by using sine and cosine? thanks,
[blockMesh] Wierd behaviour of blockMesh creating axis in wedge | rcastilla | OpenFOAM Meshing & Mesh Conversion | 1 | December 4, 2018 06:24 |
[blockMesh] Segmentation Fault when creating block mesh topography (blockMesh) | jbrydg01 | OpenFOAM Meshing & Mesh Conversion | 2 | May 11, 2017 05:37 |
[Other] Having problems creating the correct half of a circle | vroembroem | OpenFOAM Meshing & Mesh Conversion | 3 | July 3, 2016 18:24 |
[blockMesh] Error while running blockMesh | Harak | OpenFOAM Meshing & Mesh Conversion | 0 | December 11, 2014 09:36 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
