Home > Forums > Open Source Meshers: Gmsh, Netgen, CGNS, ...
gmshtoFoam error
Old   April 14, 2015, 19:26
Default gmshtoFoam error
dsn
Aditya
dsn is on a distinguished road
Hi everyone,
I have created a simple geometry and tried to import it into openfoam but when i do that using gmshtoFoam i get the following error
[aditya@localhost cavity_copy]$ gmshToFoam flatplate3.msh
gmshToFoam: error while loading shared libraries: libmpi.so.12: cannot open shared object file: No such file or directory
Can someone please help me out with why this is happening?
Regards,
Aditya
dsn is offline   Reply With Quote
Old   April 15, 2015, 01:41
Alexey Matveichev
alexeym will become famous soon enough
The error means, that after OpenFOAM compilation MPI libraries disappeared (were upgraded/removed). As your other questions were about installation on Fedora 19, and as this version of distribution is not maintained any more, the upgrade possibility seems to be improbable.
Do other OpenFOAM components (icoFoam for example) work as expected? Or do they also fail with the same error message?
alexeym is offline   Reply With Quote
Old   April 15, 2015, 11:16
dsn
Aditya
Hi alex,
I did install openfoam again using the instructions found in this website. Openfoam is working properly now except the parallel run. i.e blockmesh, icofoam and paraview etc all of them work perfectly.
So does it mean that I can never use gmsh generated meshes for my OF?
Is there a way around this problem?
Regards,
Aditya
Old   April 15, 2015, 11:53
Alexey Matveichev
I do not know, I have never used OpenFOAM with broken MPI installation.
Old   April 15, 2015, 11:56
dsn
Aditya
I dont understand why I always run into just the openmpi problem. I re-installed OF twice but still the problem persists. Any solution?
Regards
Old   April 15, 2015, 19:25
dsn
Aditya
Now i seem to have a problem running blockmesh as well. How do i get around this problem?
Old   April 16, 2015, 02:21
Alexey Matveichev
I looked through your thread about installation on Fedora 19 and it seems I know the reason for the behavior. After you have said, you wish to use MPICH, wyldckat suggested you to uninstall OpenMPI and install MPICH (post #31). Then you have decided, you do not like MPICH and uninstall it (post #34). So I guess now you have OpenFOAM built with either system-wide installed OpenMPI, or system-wide installed MPICH, but you uninstalled both.
So you can either a) install OpenMPI/MPICH system-wide (using yum command), b) rebuild OpenFOAM with OpenMPI from ThirdParty folder.
Old   April 16, 2015, 07:09
Bruno Santos
wyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nice
FYI: I've answered here: OpenFOAM installation Fedora 19 - post #36
Thread Tools
Trackbacks are On
blockMesh with double grading. spwater OpenFOAM Native Meshers: blockMesh 78 March 12, 2015 15:54
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 20:30
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 07:24
