[Gmsh] Cell to node connectivity after 'gmshToFoam'
Old   May 1, 2015, 07:11
Default Cell to node connectivity after 'gmshToFoam'
Jibran
Jibran is on a distinguished road
Hello Foamers,
Objective:
I am interested in obtaining the cell to node connectivity in a particular order for my mesh.
Description:
I use gmsh to create my mesh and I can see from the .msh file that the cell to node connectivity is in the order as specified by the gmsh manual (which I need). However when I run 'gmshToFoam testCase.msh' that order is disturbed if I check the cell to node connectivity through 'mesh.cellPoints()'. Now the connectivity is not in any particular order as shown below.
Results:
1. Connectivity before gmshToFoam (from .msh file):
Cell 0 --> ( 0 4 20 19 36 38 56 55 )
Cell 1 --> ( 19 20 21 18 55 56 57 54 )
2. Connectivity after gmshToFoam (from mesh.cellPoints()):
Cell 0 --> ( 0 4 19 20 36 38 55 56 )
Cell 1 --> ( 18 19 20 21 54 55 56 57 )
As can be seen from the text in red the ordering is changed. I also tried 'gmshToFoam -keepOrientation testCase.msh' but it gave the same result. Any help in this regard will be appreciated. Thanks!
Jibran Haider
https://jibranhaider.com/
Jibran is offline   Reply With Quote
Old   June 8, 2015, 09:09
Jibran
Dear All,
I am still not able to figure out how it works. Any hints?
Regards
Jibran Haider
connectivity, gmshtofoam, openfoam
[ICEM] Error in mesh writing helios ANSYS Meshing & Geometry 21 August 19, 2021 14:18
How does connectivity macros work for cell zones doruk Fluent UDF and Scheme Programming 11 June 15, 2020 05:58
Journal file error magicalmarshmallow FLUENT 3 April 4, 2014 12:25
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 22:56
FvMatrix coefficients shrina OpenFOAM Running, Solving & CFD 10 October 3, 2013 14:38
