Home > Forums > Open Source Meshers: Gmsh, Netgen, CGNS, ...
100 % under-determined cells with gmsh
Old   August 31, 2015, 20:55
Default 100 % under-determined cells with gmsh
Hilbert
Hillie is on a distinguished road
Dear Foamers
I am quite new to the world of openfoam, and opensource mesh generation, so bear with me if my problem is trivial. I have been playing around with gmsh to replace icem which i am currently using.
I am currently looking at square tutorial which is on the openfoam wiki (https://openfoamwiki.net/index.php/2...ial_using_GMSH). If I mesh the .geo file of that tutoial, convert that mesh to openfoam and then run checkMesh -allGeometry i get the following problem:
Cell determinant (wellposedness) : minimum: 0 average: 4.84831e-35
***Cells with small determinant (< 0.001) found, number of cells: 940
The entire mesh consists of 940 cells, so all of them are underdetermined. I have checked the mesh with the solvers that I want to use, and they do complain about this, so I do need a solution.
Had anybody seen this before/ has an idea of how to solve it?
Hillie is offline   Reply With Quote
Old   September 3, 2015, 21:48
Hilbert
I have made a bit of progress on this. If after the meshing step i run a refine step (gmsh mymesh.msh -refine) the tutorial mesh seems oke.
If i do the same for the geometry that i am interested in I am still left with about 10 bad cells. If I run the refine step again it will create the double amount of bad cells.
Does anybody have a suggestion on how to remove the bad cells without increasing the cell count by a great deal?
(I set the cells size really small I can reduce the number of bad cells by a couple but this leads to huge meshes which aren't necessary for what i want to do with it )
Thread Tools
Trackbacks are On
This mesh contains patches of type empty but is not 1D or 2D oric OpenFOAM Running, Solving & CFD 36 November 28, 2016 08:12
Cht tutorial in 15 braennstroem OpenFOAM Running, Solving & CFD 197 June 10, 2015 03:02
formatted point data- icem HSK CFX 12 August 11, 2011 21:25
Import problem ARC Open Source Meshers: Gmsh, Netgen, CGNS, ... 0 February 27, 2010 11:56
Negative densities at more than 100 cells Luke CD-adapco 5 December 2, 2008 05:14
