edge detection (solved!)
Hi, lately I've been having a lot of trouble with cfMesh edge detection. The mesh is fine otherwise, but sharp edges are not conformed or "snapped". I have the original geometry in a file whole.stl, and I'm using the following command to detect edges:
surfaceFeatureEdges -angle 120 whole.stl whole.fms http://blacklight.fi/~zordiack/cfmesh.jpg Any help? Is this the correct way to use edge detection with cfMesh or is there a better way? I don't recall having this problem before, but I might just have been lucky. I'm using OpenFOAM-dev with cfMesh 1.1.1. |
Okay this is (again) going to be one those post where I correct myself. It turns out I've been using the included angle option the wrong way around. It doesn't work the same way as in snappyHexMesh. So if you want to include i.e. all edges with at least 90 degree angle, you should use a SMALLER than 90 degrees angle specification with surfaceFeatureEdges, or just use the default (which is 45 degrees):
surfaceFeatureEdges whole.stl whole.fms http://blacklight.fi/~zordiack/cfmesh2.jpg |
You can inspect the feature edges by using:
FMSToSurface <inputSurfaceMesh>.fms <outputSurface> -exportFeatureEdges -exportFeatureEdges writes feature edges in a vtk file, which you can visualize in ParaView. |
Can you please tell me why it is saying to me that surfaceFeatureEdges command not found?
