[Gmsh] 3D coil mesh: can't create the volume? |
June 21, 2016, 08:37 |
Rep Power: 10 |
I want to make a 3D structured mesh from this coil shape : (It is a square extruded along a coil path) I made it using FreeCAD, exported it in .iges file format. (also tried .step) My issue is that I can't manage to make the 3D mesh with Gmesh. It looks like the Volume is not took into account. Here is my .geo file, made automatically from the .iges import, and at the end, written by end : I shortened the code defining the coil because the text was too long for the cfd-online forum engine. It builds the 2 square ends and 4 splines to make the coil. EDIT : see the first reply under the post to read the complete definition: the issue may be there because gmsh defines the 2 squares using splines too instead of straight lines. Code:
cl__1 = 1; Point(1) = {35, -3.552713678801e-15, -3.552713678801e-15, cl__1}; Point(2) = {35, -2.841806515585e-13, 16, cl__1}; Point(3) = {25, 7.105490038038999e-15, 0, cl__1}; Point(4) = {25.00000... p12 = newp; Point(p12 + 1) = {34.99995040328159, 9.665512834544799e-12, 25.4999999998708}; Point(p12 + 2) = {34.9999530136352, 9.1418428382896e-12, 24.9999999998776}; Point(p12 + 3) = {34.9999556239888, 8.6181728420344e-12, 24.4999999998844}; Point(p12 + 4) = {34.9999582343424, 8.094502845779199e-12, 23.9999999998912}; Point(p12 + 5) = {34.999960844696, 7.570832849524e-12, 23.499999999898}; Point(p12 + 6) = {34.9999634550496, 7.0471628532688e-12, 22.9999999999048}; Point(p12 + 7) = {34.9999660654032, 6.5234928570136e-12, 22.4999999999116}; Point(p12 + 8) = {34.9999686757568, 5.9998228607584e-12, 21.9999999999184}; Point(p12 + 9) = {34.9999712861104, 5.4761528645032e-12, 21.4999999999252}; Point(p12 + 10) = {34.999973896464, 4.952482868248e-12, 20.999999999932}; Point(p12 + 11) = {34.9999765068176, 4.428812871992799e-12, 20.4999999999388}; Point(p12 + 12) = {34.9999791171712, 3.9051428757376e-12, 19.9999999999456}; Point(p12 + 13) = {34.9999817275248, 3.3814728794824e-12, 19.4999999999524}; Point(p12 + 14) = {34.9999843378784, 2.857802883227201e-12, 18.9999999999592}; Point(p12 + 15) = {34.999986948232, 2.334132886972e-12, 18.499999999966}; Point(p12 + 16) = {34.9999895585856, 1.8104628907168e-12, 17.9999999999728}; Point(p12 + 17) = {34.9999921689392, 1.286792894461601e-12, 17.4999999999796}; Point(p12 + 18) = {34.9999947792928, 7.631228982063999e-13, 16.9999999999864}; Point(p12 + 19) = {34.9999973896464, 2.394529019512009e-13, 16.4999999999932}; Spline(12) = {8, p12 + 1, p12 + 2, p12 + 3, p12 + 4, p12 + 5, p12 + 6, p12 + 7, p12 + 8, p12 + 9, p12 + 10, p12 + 11, p12 + 12, p12 + 13, p12 + 14, p12 + 15, p12 + 16, p12 + 17, p12 + 18, p12 + 19, 2}; Line Loop(1) = {1, 4, -3, -2}; Ruled Surface(1) = {1}; Line Loop(2) = {3, 7, -6, -5}; Ruled Surface(2) = {2}; Line Loop(3) = {6, 10, -9, -8}; Ruled Surface(3) = {3}; Line Loop(4) = {9, 12, -1, -11}; Ruled Surface(4) = {4}; Line Loop(5) = {2, 5, 8, 11}; Plane Surface(5) = {5}; Line Loop(6) = {4, 7, 10, 12}; Plane Surface(6) = {6}; Surface Loop(1) = {1, 2, 3, 4, 5, 6}; Physical Surface("anode") = {4}; Physical Surface("outlet") = {6}; Physical Surface("cathode") = {2}; Physical Surface("inlet") = {5}; Physical Surface("walls") = {1, 3}; Transfinite Line {5, 11, 2, 8, 10, 12, 7, 4} = 30 Using Bump 0.1; Transfinite Line {1, 3, 6, 9} = 100; Transfinite Surface "*"; Recombine Surface "*"; Volume(1) = {1}; Transfinite Volume "*"; Code:
Info : Running 'gmsh -3 serpentin1Transfinite.geo' [Gmsh 2.8.3, 1 node, max. 4 threads] Info : Started on Tue Jun 21 14:14:50 2016 Info : Reading 'serpentin1Transfinite.geo'... Info : Done reading 'serpentin1Transfinite.geo' Info : Meshing 1D... Info : Meshing curve 1 (Nurb) Info : Meshing curve 2 (Nurb) Info : Meshing curve 3 (Nurb) Info : Meshing curve 4 (Nurb) Info : Meshing curve 5 (Nurb) Info : Meshing curve 6 (Nurb) Info : Meshing curve 7 (Nurb) Info : Meshing curve 8 (Nurb) Info : Meshing curve 9 (Nurb) Info : Meshing curve 10 (Nurb) Info : Meshing curve 11 (Nurb) Info : Meshing curve 12 (Nurb) Info : Done meshing 1D (0.093044 s) Info : Meshing 2D... Info : Meshing surface 3 (transfinite) Info : Meshing surface 2 (transfinite) Info : Meshing surface 4 (transfinite) Info : Meshing surface 1 (transfinite) Info : Meshing surface 5 (transfinite) Info : Meshing surface 6 (transfinite) Info : Done meshing 2D (0.0170281 s) Info : Meshing 3D... Info : Meshing volume 1 (transfinite) Info : Done meshing 3D (0.042758 s) Info : Optimizing 3D mesh... Info : Done optimizing 3D mesh (3e-06 s) Info : Optimizing 3D mesh with Netgen... Info : Done optimizing 3D mesh with Netgen (2e-06 s) Info : 90228 vertices 97289 elements Info : Writing 'serpentin1Transfinite.msh'... Info : Done writing 'serpentin1Transfinite.msh' Code:
Info : Running 'gmsh -check serpentin1Transfinite.msh' [Gmsh 2.8.3, 1 node, max. 4 threads] Info : Started on Tue Jun 21 14:15:01 2016 Info : Reading 'serpentin1Transfinite.msh'... Info : 13168 vertices Info : Vertex numbering is dense Info : 13166 elements Info : Done reading 'serpentin1Transfinite.msh' Info : Checking mesh coherence (13166 elements)... Info : Checking for duplicate vertices... Info : Checking for duplicate elements... Info : Done checking mesh coherence Code:
Starting to read mesh format at line 2 Read format version 2.2 ascii 0 Starting to read physical names at line 5 Physical names:5 Surface 1 anode Surface 2 outlet Surface 3 cathode Surface 4 inlet Surface 5 walls Starting to read points at line 13 Vertices to be read:13168 Vertices read:13168 Starting to read cells at line 13184 Cells to be read:13166 Mapping region 5 to Foam patch 0 Mapping region 3 to Foam patch 1 Mapping region 1 to Foam patch 2 Mapping region 4 to Foam patch 3 Mapping region 2 to Foam patch 4 Cells: total:0 hex :0 prism:0 pyr :0 tet :0 --> FOAM FATAL IO ERROR: No cells read from file "mesh/serpentin1Transfinite.msh" Does your file specify any 3D elements (hex=5, prism=6, pyramid=7, tet=4)? Perhaps you have not exported the 3D elements? file: mesh/serpentin1Transfinite.msh at line 26352. From function readCells(..) in file gmshToFoam.C at line 726. FOAM exiting Any idea please ??? Is there an error using the lines Surface Loop(1) = {1, 2, 3, 4, 5, 6}; Volume(1) = {1}; ? Thank you very much for your reply |
June 21, 2016, 08:47 |
Rep Power: 10 |
here is the complete .geo file :
cl__1 = 1; Point(1) = {35, -3.552713678801e-15, -3.552713678801e-15, cl__1}; Point(2) = {35, -2.841806515585e-13, 16, cl__1}; Point(3) = {25, 7.105490038038999e-15, 0, cl__1}; Point(4) = {25.000000000137, 3.798405561654e-06, 15.999947792928, cl__1}; Point(5) = {25, 8.881784197001e-16, 10, cl__1}; Point(6) = {24.999947793065, 3.798416055467e-06, 25.999947792792, cl__1}; Point(7) = {35, 3.552713678801e-15, 10, cl__1}; Point(8) = {34.999947792928, 1.018914638805e-11, 25.999999999864, cl__1}; p1 = newp; Point(p1 + 1) = {33.28697578667563, 10.81557595430603, 0.7999999999999649}; Point(p1 + 2) = {28.31559506160125, 20.57248086873501, 1.600000000000005}; Point(p1 + 3) = {20.57248485494981, 28.31560779522319, 2.400000000000103}; Point(p1 + 4) = {10.81559385895301, 33.28697488757213, 3.200000000000139}; Point(p1 + 5) = {-3.934240595526717e-07, 34.99998761012458, 4.000000000000092}; Point(p1 + 6) = {-10.81559370025635, 33.286983947342, 4.8}; Point(p1 + 7) = {-20.5724838605131, 28.31560799352859, 5.599999999999903}; Point(p1 + 8) = {-28.31559583718905, 20.57247413673261, 6.399999999999838}; Point(p1 + 9) = {-33.28697791557772, 10.81557986333438, 7.19999999999981}; Point(p1 + 10) = {-34.99999952433, -7.283063041541027e-14, 7.99999999999975}; Point(p1 + 11) = {-33.2869779155778, -10.81557986333407, 8.799999999999667}; Point(p1 + 12) = {-28.31559583718945, -20.5724741367307, 9.599999999999756}; Point(p1 + 13) = {-20.57248386051387, -28.31560799352474, 10.39999999999986}; Point(p1 + 14) = {-10.81559370025707, -33.28698394733719, 11.19999999999993}; Point(p1 + 15) = {-3.934244503511763e-07, -34.99998761011999, 12}; Point(p1 + 16) = {10.8155938589526, -33.28697488756801, 12.80000000000009}; Point(p1 + 17) = {20.57248485494896, -28.31560779521928, 13.60000000000011}; Point(p1 + 18) = {28.31559506160023, -20.5724808687317, 14.40000000000003}; Point(p1 + 19) = {33.28697578667518, -10.81557595430443, 15.19999999999995}; Spline(1) = {1, p1 + 1, p1 + 2, p1 + 3, p1 + 4, p1 + 5, p1 + 6, p1 + 7, p1 + 8, p1 + 9, p1 + 10, p1 + 11, p1 + 12, p1 + 13, p1 + 14, p1 + 15, p1 + 16, p1 + 17, p1 + 18, p1 + 19, 2}; p2 = newp; Point(p2 + 1) = {34.5, 3.5527136788005e-16, -2.2204460492505e-17}; Point(p2 + 2) = {34, 7.105427357601e-16, -4.440892098501e-17}; Point(p2 + 3) = {33.5, 1.06581410364015e-15, -6.6613381477515e-17}; Point(p2 + 4) = {33, 1.4210854715202e-15, -8.881784197002e-17}; Point(p2 + 5) = {32.5, 1.77635683940025e-15, -1.11022302462525e-16}; Point(p2 + 6) = {32, 2.1316282072803e-15, -1.3322676295503e-16}; Point(p2 + 7) = {31.5, 2.48689957516035e-15, -1.55431223447535e-16}; Point(p2 + 8) = {31, 2.8421709430404e-15, -1.7763568394004e-16}; Point(p2 + 9) = {30.5, 3.19744231092045e-15, -1.99840144432545e-16}; Point(p2 + 10) = {30, 3.5527136788005e-15, -2.2204460492505e-16}; Point(p2 + 11) = {29.5, 3.907985046680551e-15, -2.44249065417555e-16}; Point(p2 + 12) = {29, 4.2632564145606e-15, -2.6645352591006e-16}; Point(p2 + 13) = {28.5, 4.618527782440651e-15, -2.88657986402565e-16}; Point(p2 + 14) = {28, 4.9737991503207e-15, -3.1086244689507e-16}; Point(p2 + 15) = {27.5, 5.32907051820075e-15, -3.33066907387575e-16}; Point(p2 + 16) = {27, 5.6843418860808e-15, -3.5527136788008e-16}; Point(p2 + 17) = {26.5, 6.03961325396085e-15, -3.77475828372585e-16}; Point(p2 + 18) = {26, 6.3948846218409e-15, -3.9968028886509e-16}; Point(p2 + 19) = {25.5, 6.75015598972095e-15, -4.21884749357595e-16}; Spline(2) = {1, p2 + 1, p2 + 2, p2 + 3, p2 + 4, p2 + 5, p2 + 6, p2 + 7, p2 + 8, p2 + 9, p2 + 10, p2 + 11, p2 + 12, p2 + 13, p2 + 14, p2 + 15, p2 + 16, p2 + 17, p2 + 18, p2 + 19, 3}; p3 = newp; Point(p3 + 1) = {23.77641052640401, 7.725406834925433, 0.799967528881368}; Point(p3 + 2) = {20.22542459964436, 14.69463299397066, 1.599976999479448}; Point(p3 + 3) = {14.6946330566992, 20.22543763519334, 2.399974747972084}; Point(p3 + 4) = {7.725423698554923, 23.77640723674901, 3.199972942024594}; Point(p3 + 5) = {-4.777837354197345e-06, 24.99998746685228, 3.999973862993754}; Point(p3 + 6) = {-7.725429725077163, 23.77641908865229, 4.799973770831803}; Point(p3 + 7) = {-14.69463293255824, 20.22543734322262, 5.599973156628059}; Point(p3 + 8) = {-20.22542311606549, 14.69462207042045, 6.399974258167043}; Point(p3 + 9) = {-23.7764114478925, 7.725409692672865, 7.199975287514579}; Point(p3 + 10) = {-24.9999995243625, -1.899201690136465e-06, 7.99997389646725}; Point(p3 + 11) = {-23.7764102741238, -7.725413305162711, 8.799972505419536}; Point(p3 + 12) = {-20.22542088342103, -14.6946251433837, 9.599973534766855}; Point(p3 + 13) = {-14.69462985958553, -20.22543957586559, 10.39997463630607}; Point(p3 + 14) = {-7.725426112577281, -23.77642026241737, 11.1999740221024}; Point(p3 + 15) = {-9.794303075238986e-07, -24.99998746683572, 11.99997392994034}; Point(p3 + 16) = {7.725427311049618, -23.77640606296714, 12.79997485090963}; Point(p3 + 17) = {14.69463612967655, -20.22543540255435, 13.59997304496233}; Point(p3 + 18) = {20.22542683230346, -14.69462992099718, 14.39997079345485}; Point(p3 + 19) = {23.77641170014313, -7.725403222406675, 15.19998026405267}; Spline(3) = {3, p3 + 1, p3 + 2, p3 + 3, p3 + 4, p3 + 5, p3 + 6, p3 + 7, p3 + 8, p3 + 9, p3 + 10, p3 + 11, p3 + 12, p3 + 13, p3 + 14, p3 + 15, p3 + 16, p3 + 17, p3 + 18, p3 + 19, 4}; p4 = newp; Point(p4 + 1) = {34.50000000000685, 1.899200031019044e-07, 15.9999973896464}; Point(p4 + 2) = {34.0000000000137, 3.798402975263305e-07, 15.9999947792928}; Point(p4 + 3) = {33.50000000002055, 5.697605919507566e-07, 15.9999921689392}; Point(p4 + 4) = {33.0000000000274, 7.596808863751827e-07, 15.9999895585856}; Point(p4 + 5) = {32.50000000003425, 9.496011807996088e-07, 15.999986948232}; Point(p4 + 6) = {32.0000000000411, 1.139521475224035e-06, 15.9999843378784}; Point(p4 + 7) = {31.50000000004795, 1.329441769648461e-06, 15.9999817275248}; Point(p4 + 8) = {31.0000000000548, 1.519362064072887e-06, 15.9999791171712}; Point(p4 + 9) = {30.50000000006165, 1.709282358497313e-06, 15.9999765068176}; Point(p4 + 10) = {30.0000000000685, 1.899202652921739e-06, 15.999973896464}; Point(p4 + 11) = {29.50000000007535, 2.089122947346165e-06, 15.9999712861104}; Point(p4 + 12) = {29.0000000000822, 2.279043241770591e-06, 15.9999686757568}; Point(p4 + 13) = {28.50000000008905, 2.468963536195017e-06, 15.9999660654032}; Point(p4 + 14) = {28.0000000000959, 2.658883830619443e-06, 15.9999634550496}; Point(p4 + 15) = {27.50000000010275, 2.84880412504387e-06, 15.999960844696}; Point(p4 + 16) = {27.0000000001096, 3.038724419468296e-06, 15.9999582343424}; Point(p4 + 17) = {26.50000000011645, 3.228644713892722e-06, 15.9999556239888}; Point(p4 + 18) = {26.0000000001233, 3.418565008317148e-06, 15.9999530136352}; Point(p4 + 19) = {25.50000000013015, 3.608485302741574e-06, 15.9999504032816}; Spline(4) = {2, p4 + 1, p4 + 2, p4 + 3, p4 + 4, p4 + 5, p4 + 6, p4 + 7, p4 + 8, p4 + 9, p4 + 10, p4 + 11, p4 + 12, p4 + 13, p4 + 14, p4 + 15, p4 + 16, p4 + 17, p4 + 18, p4 + 19, 4}; p5 = newp; Point(p5 + 1) = {25, 6.75015598972095e-15, 0.4999999999999996}; Point(p5 + 2) = {25, 6.3948846218409e-15, 0.9999999999999996}; Point(p5 + 3) = {25, 6.039613253960851e-15, 1.5}; Point(p5 + 4) = {25, 5.6843418860808e-15, 2}; Point(p5 + 5) = {25, 5.32907051820075e-15, 2.5}; Point(p5 + 6) = {25, 4.9737991503207e-15, 3}; Point(p5 + 7) = {25, 4.618527782440651e-15, 3.5}; Point(p5 + 8) = {25, 4.2632564145606e-15, 4}; Point(p5 + 9) = {25, 3.90798504668055e-15, 4.499999999999999}; Point(p5 + 10) = {25, 3.5527136788005e-15, 4.999999999999999}; Point(p5 + 11) = {25, 3.19744231092045e-15, 5.499999999999999}; Point(p5 + 12) = {25, 2.8421709430404e-15, 5.999999999999999}; Point(p5 + 13) = {25, 2.48689957516035e-15, 6.499999999999999}; Point(p5 + 14) = {25, 2.1316282072803e-15, 6.999999999999999}; Point(p5 + 15) = {25, 1.77635683940025e-15, 7.499999999999999}; Point(p5 + 16) = {25, 1.4210854715202e-15, 7.999999999999999}; Point(p5 + 17) = {25, 1.06581410364015e-15, 8.5}; Point(p5 + 18) = {25, 7.105427357601e-16, 9}; Point(p5 + 19) = {25, 3.552713678800504e-16, 9.5}; Spline(5) = {3, p5 + 1, p5 + 2, p5 + 3, p5 + 4, p5 + 5, p5 + 6, p5 + 7, p5 + 8, p5 + 9, p5 + 10, p5 + 11, p5 + 12, p5 + 13, p5 + 14, p5 + 15, p5 + 16, p5 + 17, p5 + 18, p5 + 19, 5}; p6 = newp; Point(p6 + 1) = {23.77637942271676, 7.725395028110497, 10.79996752868822}; Point(p6 + 2) = {20.22540628442055, 14.69461847251175, 11.59997699943675}; Point(p6 + 3) = {14.6946183372976, 20.22541887775483, 12.39997474801252}; Point(p6 + 4) = {7.725414835562436, 23.77638161371448, 13.19997294196919}; Point(p6 + 5) = {-4.369282990523971e-06, 24.99995970468934, 13.99997386291042}; Point(p6 + 6) = {-7.725421141501236, 23.77639466495889, 14.79997377082443}; Point(p6 + 7) = {-14.694617879098, 20.22541687914596, 15.59997315663087}; Point(p6 + 8) = {-20.22540245114558, 14.69460548372962, 16.39997425809336}; Point(p6 + 9) = {-23.77638733224092, 7.72540083349461, 17.19997528744359}; Point(p6 + 10) = {-24.99997342083, -1.526408995644601e-06, 17.999973896433}; Point(p6 + 11) = {-23.77638473789596, -7.725406031478821, 18.79997250534116}; Point(p6 + 12) = {-20.2253993119169, -14.69461104354239, 19.59997353469108}; Point(p6 + 13) = {-14.69461422650177, -20.22541780354248, 20.39997463631247}; Point(p6 + 14) = {-7.725418563303268, -23.77639503424744, 21.1999740220954}; Point(p6 + 15) = {-1.387996832136196e-06, -24.99996302193447, 21.99997392985702}; Point(p6 + 16) = {7.725420041180197, -23.77638203411787, 22.79997485085928}; Point(p6 + 17) = {14.6946201625467, -20.22541192358474, 23.59997304499864}; Point(p6 + 18) = {20.22540291112722, -14.69461375593091, 24.39997079339639}; Point(p6 + 19) = {23.77639315196277, -7.725398896346661, 25.1999802638931}; Spline(6) = {5, p6 + 1, p6 + 2, p6 + 3, p6 + 4, p6 + 5, p6 + 6, p6 + 7, p6 + 8, p6 + 9, p6 + 10, p6 + 11, p6 + 12, p6 + 13, p6 + 14, p6 + 15, p6 + 16, p6 + 17, p6 + 18, p6 + 19, 6}; p7 = newp; Point(p7 + 1) = {24.9999973897834, 3.79840612048075e-06, 16.4999477929212}; Point(p7 + 2) = {24.9999947794298, 3.7984066437955e-06, 16.9999477929144}; Point(p7 + 3) = {24.9999921690762, 3.79840716711025e-06, 17.4999477929076}; Point(p7 + 4) = {24.9999895587226, 3.798407690425e-06, 17.9999477929008}; Point(p7 + 5) = {24.999986948369, 3.79840821373975e-06, 18.499947792894}; Point(p7 + 6) = {24.9999843380154, 3.7984087370545e-06, 18.9999477928872}; Point(p7 + 7) = {24.9999817276618, 3.79840926036925e-06, 19.4999477928804}; Point(p7 + 8) = {24.9999791173082, 3.798409783684e-06, 19.9999477928736}; Point(p7 + 9) = {24.9999765069546, 3.79841030699875e-06, 20.4999477928668}; Point(p7 + 10) = {24.999973896601, 3.7984108303135e-06, 20.99994779286}; Point(p7 + 11) = {24.9999712862474, 3.79841135362825e-06, 21.4999477928532}; Point(p7 + 12) = {24.9999686758938, 3.798411876943e-06, 21.9999477928464}; Point(p7 + 13) = {24.9999660655402, 3.79841240025775e-06, 22.4999477928396}; Point(p7 + 14) = {24.9999634551866, 3.7984129235725e-06, 22.9999477928328}; Point(p7 + 15) = {24.999960844833, 3.79841344688725e-06, 23.499947792826}; Point(p7 + 16) = {24.9999582344794, 3.798413970202e-06, 23.9999477928192}; Point(p7 + 17) = {24.9999556241258, 3.79841449351675e-06, 24.4999477928124}; Point(p7 + 18) = {24.9999530137722, 3.7984150168315e-06, 24.9999477928056}; Point(p7 + 19) = {24.9999504034186, 3.79841554014625e-06, 25.4999477927988}; Spline(7) = {4, p7 + 1, p7 + 2, p7 + 3, p7 + 4, p7 + 5, p7 + 6, p7 + 7, p7 + 8, p7 + 9, p7 + 10, p7 + 11, p7 + 12, p7 + 13, p7 + 14, p7 + 15, p7 + 16, p7 + 17, p7 + 18, p7 + 19, 6}; p8 = newp; Point(p8 + 1) = {25.5, 3.730349362741e-15, 10}; Point(p8 + 2) = {26, 3.907985046681e-15, 10}; Point(p8 + 3) = {26.5, 4.085620730621e-15, 10}; Point(p8 + 4) = {27, 4.263256414561e-15, 10}; Point(p8 + 5) = {27.5, 4.440892098501e-15, 10}; Point(p8 + 6) = {28, 4.618527782441e-15, 10}; Point(p8 + 7) = {28.5, 4.796163466381e-15, 10}; Point(p8 + 8) = {29, 4.973799150321001e-15, 10}; Point(p8 + 9) = {29.5, 5.151434834261e-15, 10}; Point(p8 + 10) = {30, 5.329070518201001e-15, 10}; Point(p8 + 11) = {30.5, 5.506706202141e-15, 10}; Point(p8 + 12) = {31, 5.684341886081001e-15, 10}; Point(p8 + 13) = {31.5, 5.861977570021e-15, 10}; Point(p8 + 14) = {32, 6.039613253961001e-15, 10}; Point(p8 + 15) = {32.5, 6.217248937901e-15, 10}; Point(p8 + 16) = {33, 6.394884621841e-15, 10}; Point(p8 + 17) = {33.5, 6.572520305781e-15, 10}; Point(p8 + 18) = {34, 6.750155989721e-15, 10}; Point(p8 + 19) = {34.5, 6.927791673661e-15, 10}; Spline(8) = {5, p8 + 1, p8 + 2, p8 + 3, p8 + 4, p8 + 5, p8 + 6, p8 + 7, p8 + 8, p8 + 9, p8 + 10, p8 + 11, p8 + 12, p8 + 13, p8 + 14, p8 + 15, p8 + 16, p8 + 17, p8 + 18, p8 + 19, 7}; p9 = newp; Point(p9 + 1) = {33.28694468298838, 10.81556414749148, 10.79999999980681}; Point(p9 + 2) = {28.31557674637745, 20.57246634727634, 11.59999999995723}; Point(p9 + 3) = {20.57247013554825, 28.31558903778467, 12.40000000004029}; Point(p9 + 4) = {10.81558499596076, 33.28694926453743, 13.19999999994432}; Point(p9 + 5) = {1.513110703399434e-08, 34.99995984796148, 13.99999999991627}; Point(p9 + 6) = {-10.81558511667846, 33.28695952364863, 14.79999999999225}; Point(p9 + 7) = {-20.5724688070493, 28.31558752945221, 15.60000000000257}; Point(p9 + 8) = {-28.31557517226427, 20.57245755004223, 16.39999999992629}; Point(p9 + 9) = {-33.28695379992151, 10.81557100415658, 17.1999999999292}; Point(p9 + 10) = {-34.999973420795, 3.727928330476971e-07, 17.999999999966}; Point(p9 + 11) = {-33.28695237934944, -10.81557258965012, 18.79999999992168}; Point(p9 + 12) = {-28.31557426568681, -20.57246003688935, 19.59999999992425}; Point(p9 + 13) = {-20.57246822743285, -28.31558622120141, 20.40000000000646}; Point(p9 + 14) = {-10.81558615098579, -33.28695871916649, 21.19999999999303}; Point(p9 + 15) = {-8.019928401381549e-07, -34.99996316521701, 21.99999999991661}; Point(p9 + 16) = {10.81558658908234, -33.28695085871593, 22.7999999999495}; Point(p9 + 17) = {20.572468887819, -28.31558431624622, 23.60000000003605}; Point(p9 + 18) = {28.31557114042426, -20.57246470366217, 24.39999999994122}; Point(p9 + 19) = {33.28695723849519, -10.81557162824202, 25.1999999998402}; Spline(9) = {7, p9 + 1, p9 + 2, p9 + 3, p9 + 4, p9 + 5, p9 + 6, p9 + 7, p9 + 8, p9 + 9, p9 + 10, p9 + 11, p9 + 12, p9 + 13, p9 + 14, p9 + 15, p9 + 16, p9 + 17, p9 + 18, p9 + 19, 8}; p10 = newp; Point(p10 + 1) = {25.49994779305815, 3.60849576939182e-06, 25.9999504031456}; Point(p10 + 2) = {25.9999477930513, 3.418575475322641e-06, 25.9999530134992}; Point(p10 + 3) = {26.49994779304445, 3.228655181253461e-06, 25.9999556238528}; Point(p10 + 4) = {26.9999477930376, 3.038734887184281e-06, 25.9999582342064}; Point(p10 + 5) = {27.49994779303075, 2.848814593115101e-06, 25.99996084456}; Point(p10 + 6) = {27.9999477930239, 2.658894299045921e-06, 25.9999634549136}; Point(p10 + 7) = {28.49994779301705, 2.468974004976741e-06, 25.9999660652672}; Point(p10 + 8) = {28.9999477930102, 2.279053710907561e-06, 25.9999686756208}; Point(p10 + 9) = {29.49994779300335, 2.089133416838381e-06, 25.9999712859744}; Point(p10 + 10) = {29.9999477929965, 1.899213122769202e-06, 25.999973896328}; Point(p10 + 11) = {30.49994779298965, 1.709292828700022e-06, 25.9999765066816}; Point(p10 + 12) = {30.9999477929828, 1.519372534630842e-06, 25.9999791170352}; Point(p10 + 13) = {31.49994779297595, 1.329452240561662e-06, 25.9999817273888}; Point(p10 + 14) = {31.9999477929691, 1.139531946492483e-06, 25.9999843377424}; Point(p10 + 15) = {32.49994779296225, 9.496116524233027e-07, 25.999986948096}; Point(p10 + 16) = {32.9999477929554, 7.596913583541228e-07, 25.9999895584496}; Point(p10 + 17) = {33.49994779294855, 5.697710642849428e-07, 25.9999921688032}; Point(p10 + 18) = {33.9999477929417, 3.798507702157629e-07, 25.9999947791568}; Point(p10 + 19) = {34.49994779293485, 1.899304761465834e-07, 25.9999973895104}; Spline(10) = {6, p10 + 1, p10 + 2, p10 + 3, p10 + 4, p10 + 5, p10 + 6, p10 + 7, p10 + 8, p10 + 9, p10 + 10, p10 + 11, p10 + 12, p10 + 13, p10 + 14, p10 + 15, p10 + 16, p10 + 17, p10 + 18, p10 + 19, 8}; p11 = newp; Point(p11 + 1) = {35, 6.75015598972095e-15, 9.5}; Point(p11 + 2) = {35, 6.3948846218409e-15, 9}; Point(p11 + 3) = {35, 6.039613253960851e-15, 8.5}; Point(p11 + 4) = {35, 5.6843418860808e-15, 8}; Point(p11 + 5) = {35, 5.32907051820075e-15, 7.5}; Point(p11 + 6) = {35, 4.9737991503207e-15, 7}; Point(p11 + 7) = {35, 4.618527782440651e-15, 6.5}; Point(p11 + 8) = {35, 4.2632564145606e-15, 6}; Point(p11 + 9) = {35, 3.90798504668055e-15, 5.5}; Point(p11 + 10) = {35, 3.5527136788005e-15, 5}; Point(p11 + 11) = {35, 3.19744231092045e-15, 4.5}; Point(p11 + 12) = {35, 2.8421709430404e-15, 4}; Point(p11 + 13) = {35, 2.48689957516035e-15, 3.5}; Point(p11 + 14) = {35, 2.1316282072803e-15, 3}; Point(p11 + 15) = {35, 1.77635683940025e-15, 2.5}; Point(p11 + 16) = {35, 1.4210854715202e-15, 2}; Point(p11 + 17) = {35, 1.06581410364015e-15, 1.5}; Point(p11 + 18) = {35, 7.105427357601e-16, 1}; Point(p11 + 19) = {35, 3.552713678800504e-16, 0.5}; Spline(11) = {7, p11 + 1, p11 + 2, p11 + 3, p11 + 4, p11 + 5, p11 + 6, p11 + 7, p11 + 8, p11 + 9, p11 + 10, p11 + 11, p11 + 12, p11 + 13, p11 + 14, p11 + 15, p11 + 16, p11 + 17, p11 + 18, p11 + 19, 1}; p12 = newp; Point(p12 + 1) = {34.99995040328159, 9.665512834544799e-12, 25.4999999998708}; Point(p12 + 2) = {34.9999530136352, 9.1418428382896e-12, 24.9999999998776}; Point(p12 + 3) = {34.9999556239888, 8.6181728420344e-12, 24.4999999998844}; Point(p12 + 4) = {34.9999582343424, 8.094502845779199e-12, 23.9999999998912}; Point(p12 + 5) = {34.999960844696, 7.570832849524e-12, 23.499999999898}; Point(p12 + 6) = {34.9999634550496, 7.0471628532688e-12, 22.9999999999048}; Point(p12 + 7) = {34.9999660654032, 6.5234928570136e-12, 22.4999999999116}; Point(p12 + 8) = {34.9999686757568, 5.9998228607584e-12, 21.9999999999184}; Point(p12 + 9) = {34.9999712861104, 5.4761528645032e-12, 21.4999999999252}; Point(p12 + 10) = {34.999973896464, 4.952482868248e-12, 20.999999999932}; Point(p12 + 11) = {34.9999765068176, 4.428812871992799e-12, 20.4999999999388}; Point(p12 + 12) = {34.9999791171712, 3.9051428757376e-12, 19.9999999999456}; Point(p12 + 13) = {34.9999817275248, 3.3814728794824e-12, 19.4999999999524}; Point(p12 + 14) = {34.9999843378784, 2.857802883227201e-12, 18.9999999999592}; Point(p12 + 15) = {34.999986948232, 2.334132886972e-12, 18.499999999966}; Point(p12 + 16) = {34.9999895585856, 1.8104628907168e-12, 17.9999999999728}; Point(p12 + 17) = {34.9999921689392, 1.286792894461601e-12, 17.4999999999796}; Point(p12 + 18) = {34.9999947792928, 7.631228982063999e-13, 16.9999999999864}; Point(p12 + 19) = {34.9999973896464, 2.394529019512009e-13, 16.4999999999932}; Spline(12) = {8, p12 + 1, p12 + 2, p12 + 3, p12 + 4, p12 + 5, p12 + 6, p12 + 7, p12 + 8, p12 + 9, p12 + 10, p12 + 11, p12 + 12, p12 + 13, p12 + 14, p12 + 15, p12 + 16, p12 + 17, p12 + 18, p12 + 19, 2}; Line Loop(1) = {1, 4, -3, -2}; Ruled Surface(1) = {1}; Line Loop(2) = {3, 7, -6, -5}; Ruled Surface(2) = {2}; Line Loop(3) = {6, 10, -9, -8}; Ruled Surface(3) = {3}; Line Loop(4) = {9, 12, -1, -11}; Ruled Surface(4) = {4}; Line Loop(5) = {2, 5, 8, 11}; Plane Surface(5) = {5}; Line Loop(6) = {4, 7, 10, 12}; Plane Surface(6) = {6}; Surface Loop(1) = {1, 2, 3, 4, 5, 6}; Physical Surface("anode") = {4}; Physical Surface("outlet") = {6}; Physical Surface("cathode") = {2}; Physical Surface("inlet") = {5}; Physical Surface("walls") = {1, 3}; Transfinite Line {5, 11, 2, 8, 10, 12, 7, 4} = 30 Using Bump 0.1; Transfinite Line {1, 3, 6, 9} = 100; Transfinite Surface "*"; Recombine Surface "*"; Volume(1) = {1}; Transfinite Volume "*"; |
June 21, 2016, 15:30 |
In addition to geometric volume, you have to define physical volume. For example, you can add the following line to your geo-file: Code:
Physical Volume("mesh") = {1}; Code:
... Cells: total:83259 hex :83259 prism:0 pyr :0 tet :0 ... |
July 18, 2016, 05:09 |
Rep Power: 10 |
I didn't take the time to thank you! so thanks a lot! It worked fine.
coil, gmsh, gmshfoam, mesh 3d |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 17:16 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
How to use "translation" in solidBodyMotionFunction in OpenFOAM | rupesh_w | OpenFOAM Running, Solving & CFD | 5 | August 16, 2016 04:27 |
[snappyHexMesh] snappyHexMesh does not create mesh in body volume | Illmatic | OpenFOAM Meshing & Mesh Conversion | 1 | July 11, 2016 21:35 |
Problem of simulating of small droplet with radius of 2mm | liguifan | OpenFOAM Running, Solving & CFD | 5 | June 3, 2014 02:53 |
