July 18, 2016, 09:28 |
maximal number of patch in gmshToFoam
Laurent DASTUGUE
Rep Power: 11 |
Hi foamers,
i am trying to convert a .msh file using gmshToFoam and there is a fata error occuring. This model involves nearly 800 patches and i think this is the problem. You can see here the error message when i try to compute the gmshToFoam utility : Code:
Mapping region 97 to Foam patch 96 Mapping region 98 to Foam patch 97 Mapping region 99 to Foam patch 98 --> FOAM FATAL IO ERROR: wrong token type - expected int, found on line 0 the punctuation token '*' file: IStringStream.sourceFile at line 0. From function operator>>(Istream&, int&) in file primitives/ints/int/intIO.C at line 68. FOAM exiting Thanks a lot, Laurent |
steadyUniversalMRFFoam Tutorial fails in MixingPlane | HenrikJohansson | OpenFOAM Bugs | 0 | February 14, 2019 04:48 |
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) | AndreP | STAR-CCM+ | 10 | August 2, 2018 07:48 |
Near wall treatment in k-omega SST | Arnoldinho | OpenFOAM Running, Solving & CFD | 38 | March 8, 2017 13:48 |
createPatch Segmentation Fault (CORE DUMPED) | sam.ho | OpenFOAM Pre-Processing | 2 | April 21, 2014 02:01 |
[blockMesh] --> foam fatal error: | lillo763 | OpenFOAM Meshing & Mesh Conversion | 0 | March 5, 2014 10:27 |
