[Sponsors] | |||||
#21 |
David Segersson
Rep Power: 6 ![]() |
Thanks for your time Mattijs,
I guess you have found my problem. What I do not understand is why they do not match, which I guess in turn causes the geometry to be interpreted as multiple separated parts. As I've extruded the bottom faces simultaneoulsly, one would think they would match... If I could get an answer to if the error is in gmsh or in gmshToFoam, or in my handling, I could continue from there. Now however, I found it hard to know where to begin. Any further suggestions? Regards David |
#22 |
Mattijs Janssens
Rep Power: 13 ![]() |
Don't think the problem is in gmshToFoam. It reads all cells without doing any filtering.
#23 |
David Segersson
Thanks again for your help Mattijs!
I have now solved some of the problems:-) There were two of them: 1. The physical regions badly defined - sorry about this, I should have checked this befire posting. 2. Truncation Since I used geographical coordinates for the mesh, the numbers were so big that truncation became a problem. Solved this by translating the geometry to origo. The conversion now seems to work for all simple geometries. However, as soon as I try something a litter bigger and more complex, such as: I get the following result from checkMesh: Checking geometry... Domain bounding box: (-427 -276 0) (433 284 100) ***Boundary openness (1.93265e-08 1.12445e-07 1.44203e-06) possible hole in boundary description. ***Open cells found, max cell openness: 1, number of open cells 204768 <<Writing 204768 non closed cells to set nonClosedCells Minumum face area = 0.141263. Maximum face area = 238.253. Face area magnitudes OK. Min volume = 0.0651389. Max volume = 1933.7. Total volume = 4.8409e+07. Cell volumes OK. Mesh non-orthogonality Max: 180 average: 20.6569 ***Number of non-orthogonality errors: 102384. <<Writing 102384 non-orthogonal faces to set nonOrthoFaces ***Error in face pyramids: 204768 faces are incorrectly oriented. <<Writing 204768 faces with incorrect orientation to set wrongOrientedFaces Max skewness = 0.479058 OK. Min/max edge length = 0.15 23.8253 OK. All angles in faces OK. Face flatness (1 = flat, 0 = butterfly) : average = 1 min = 1 All face flatness OK. I'm having a hard time to see what could be so wrong with my mesh. Due to the limited ways of checking the quality in gmsh, the best I can do is a visual check. This is quite good though, since the mesh is extruded and the errors should be visible from the original 2d-mesh. However, it seems like the errors I get are not simply a question of quality ("open cells", "face incorrectly oriented"...). It seems like either I have missed something or there is a problem in the conversion. Could theses errors be round-off errors, or could they be caused by different demands on accuracy between gmsh and OpenFoam? Does anybody have advice on how to handle these errors? Is it for example posible to display where the errors take place? BTW, is there a way to use the physical entities from gmsh2.0 in gmshToFoam in OF 1.4.1? Best regards David |
#24 |
Mattijs Janssens
Seems some/all (204768?) of the tets are inside out. Try switching off the automatic orientation with the '-keepOrientation' command line switch.
#25 |
David Segersson
Problem solved. Seeems like the extrusion went bad (some layers were extruded in the wrong direction, strange that gmsh didn't complain). Now I've finally managed to get a OK mesh for a real geometry :-) Now on to recombining into hexes! Thanks! David |
#26 |
Alain Martin
I am trying to get this utility(gmsh2ToFoam) to work with both physical name and type in the Physical Surface("tube symetryPlane") = { .. }; for example. I only get good results if only one name is given. Physical Surface("tube")= {.. }; I quickly look into the source file and I found that the index numberI is not define in the source. Is it defined somewhere? thanks, -Alain |
#27 |
Alain Martin
The problem is not there (numberI). If I give two names in the msh file: . 3 "bottomTop symmetryPlane" . , I get the following messages: word::stripInvalid() called for string bottomTopsymmetryPlane You see that both names a concatenated! -Alain |
#28 |
Takuya OSHIMA
Rep Power: 9 ![]() |
Hi Alaiin,
Which version are you using? I ask this because only some of the most recent versions have this feature. The latest is the one that comes with gmshFoam-20070905 package[1]. If still haven't, could you try the version. [1]http://openfoamwiki.net/index.php/Contrib_gmshFoam Takuya |
#29 |
Alain Martin
Thank you very much Takuya. I was using the version from the forum.
Now it works perfectly. -Alain |
#30 |
Juergen Neubauer
Rep Power: 0 ![]() |
trying to install gmshFoam I ran into a problem: ~/OpenFOAM/neubauer-1.4.1/applications/utilities/gmshFoam> ./Allwmake + wmake libso libgmshMessageStream /home/neubauer/OpenFOAM/OpenFOAM-1.4.1/wmake/wmakeLnInclude: linking include files to /home/neubauer/OpenFOAM/neubauer-1.4.1/applications/utilities/gmshFoam/libgmshMe ssageStream/lnInclude Making dependency list for source file gmshMessageStream.C SOURCE=gmshMessageStream.C ; g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -IlnInclude -I. -I/home/neubauer/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/gmshMessageStream.o /tmp/ccWuhAbc.s: Assembler messages: /tmp/ccWuhAbc.s:5: Warning: setting incorrect section attributes for .text._ZN4Foam4endlERNS_7OstreamE /tmp/ccWuhAbc.s:37: Warning: setting incorrect section attributes for .text._ZNSs12_S_constructIPcEES0_T_S1_RKSaIcESt20f orward_iterator_tag /tmp/ccWuhAbc.s:1499: Error: unknown pseudo-op: `.weakref' /tmp/ccWuhAbc.s:1500: Error: unknown pseudo-op: `.weakref' /tmp/ccWuhAbc.s:1501: Error: unknown pseudo-op: `.weakref' /tmp/ccWuhAbc.s:1502: Error: unknown pseudo-op: `.weakref' /tmp/ccWuhAbc.s:1503: Error: unknown pseudo-op: `.weakref' /tmp/ccWuhAbc.s:1504: Error: unknown pseudo-op: `.weakref' /tmp/ccWuhAbc.s:1505: Error: unknown pseudo-op: `.weakref' /tmp/ccWuhAbc.s:1506: Error: unknown pseudo-op: `.weakref' /tmp/ccWuhAbc.s:1507: Error: unknown pseudo-op: `.weakref' /tmp/ccWuhAbc.s:1508: Error: unknown pseudo-op: `.weakref' /tmp/ccWuhAbc.s:1509: Error: unknown pseudo-op: `.weakref' /tmp/ccWuhAbc.s:1510: Error: unknown pseudo-op: `.weakref' /tmp/ccWuhAbc.s:1511: Error: unknown pseudo-op: `.weakref' /tmp/ccWuhAbc.s:1512: Error: unknown pseudo-op: `.weakref' /tmp/ccWuhAbc.s:1809: Warning: setting incorrect section attributes for .data.DW.ref.__gxx_personality_v0 make: *** [Make/linux64GccDPOpt/gmshMessageStream.o] Error 1 How can I resolve this issue? Thanks for your help. Ciao, Juergen |
#32 |
Pierre-Olivier Dallaire
Hi Takuya,
is gmsh2Foam is compatible with OpenFoam-1.5 ? Best regards, Pierre-Oliver |
#33 |
Takuya OSHIMA
Hi Pierre-Olivier,
The current status is that I still haven't done anything about 1.5-porting. While I definitely have a plan to port the gmshFoam suite to OF 1.5 and Gmsh 2.2 along with support for Gmsh 2.2's new features (mainly for postprocessing though) I don't have a concrete timeline yet. I'll post a quick patch when I have time to do so but I guess it will be next month at the earliest. If there's someone who successfully ported gmshFoam/gmsh2ToFoam (even not the complete gmshFoam-suite), feel free to attach the patch to the wiki. Takuya |
#34 |
Ok, thanks Takuya !
Pierre-Olivier |
#35 |
Veselin Lefterov
I'm trying to compile the latest version of gmsh2ToFoam (from 20070312) in compatibility with OpenFOAM-1.6. When I run wmake, I get the following errors: Code:
Making dependency list for source file polyMeshBandCompression.C could not open file Time.hh for source file polyMeshBandCompression.C Making dependency list for source file gmsh2ToFoam.C could not open file Time.hh for source file gmsh2ToFoam.C SOURCE=polyMeshBandCompression.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/Veselin/OpenFOAM/OpenFOAM-1.6/src/meshTools/lnInclude -I/home/Veselin/OpenFOAM/OpenFOAM-1.6/src/dynamicMesh/lnInclude -I/home/Veselin/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/Veselin/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/home/Veselin/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/polyMeshBandCompression.o polyMeshBandCompression.C: In constructor ‘Foam::polyMeshBandCompression::polyMeshBandCompression(const Foam::IOobject&, const Foam::pointField&, const Foam::cellShapeList&, const Foam::faceListList&, const Foam::wordList&, const Foam::wordList&, const Foam::word&, const Foam::wordList&)’: polyMeshBandCompression.C:60: error: no matching function for call to ‘Foam::polyMesh::polyMesh(const Foam::IOobject&, const Foam::Field<Foam::Vector<double> >&, const Foam::List<Foam::cellShape>&, const Foam::List<Foam::List<Foam::face> >&, const Foam::List<Foam::word>&, const Foam::List<Foam::word>&, const Foam::word&, const Foam::List<Foam::word>&)’ /home/Veselin/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/polyMesh.H:257: note: candidates are: Foam::polyMesh::polyMesh(const Foam::IOobject&, const Foam::Xfer<Foam::Field<Foam::Vector<double> > >&, const Foam::cellShapeList&, const Foam::faceListList&, const Foam::wordList&, const Foam::wordList&, const Foam::word&, const Foam::word&, const Foam::wordList&, bool) /home/Veselin/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/polyMesh.H:242: note: Foam::polyMesh::polyMesh(const Foam::IOobject&, const Foam::Xfer<Foam::Field<Foam::Vector<double> > >&, const Foam::Xfer<Foam::List<Foam::face> >&, const Foam::Xfer<Foam::List<Foam::cell> >&, bool) /home/Veselin/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/polyMesh.H:231: note: Foam::polyMesh::polyMesh(const Foam::IOobject&, const Foam::Xfer<Foam::Field<Foam::Vector<double> > >&, const Foam::Xfer<Foam::List<Foam::face> >&, const Foam::Xfer<Foam::List<int> >&, const Foam::Xfer<Foam::List<int> >&, bool) /home/Veselin/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/polyMesh.H:219: note: Foam::polyMesh::polyMesh(const Foam::IOobject&) /home/Veselin/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/polyMesh.H:166: note: Foam::polyMesh::polyMesh(const Foam::polyMesh&) polyMeshBandCompression.C: In member function ‘Foam::polyMesh* Foam::polyMeshBandCompression::renumberedMesh() const’: polyMeshBandCompression.C:213: error: ‘allFaces’ was not declared in this scope polyMeshBandCompression.C:246: error: ‘allPoints’ was not declared in this scope make: *** [Make/linux64GccDPOpt/polyMeshBandCompression.o] Error 1 If you have any ideas on how to solve the problem - you're welcome! Thanks in advance guys! |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| grid file converter | Frank Muldoon | Main CFD Forum | 1 | December 10, 2008 03:17 |
| Where to modify the foam banner in version 141 | leosding | OpenFOAM | 1 | January 13, 2008 04:44 |
| New version fluent file open in Old version ? | MANOJKUMAR | FLUENT | 0 | October 29, 2005 03:29 |
| Tecplot file converter for Paraview/OpenDX | Mason | Main CFD Forum | 2 | September 19, 2005 12:25 |
