[Gmsh] Problem to install gmsh
Old   February 24, 2008, 08:37
Default Problem to install gmsh
Dante De Santis
dante is on a distinguished road
Hi, I'm installing gmsh following this wiki page :
http://openfoamwiki.net/index.php/Contrib_gmshFoam
but when I do
patch -p1 < $WM_PROJECT_USER_DIR/applications/utilities/gmshFoam/gmsh-2.0.8-foam-YYYYMMDD.di ff
I receive the following error:
can't find file to patch at input line 1417
Perhaps you used the wrong -p or --strip option?
The text leading up to this was:
|--- gmsh-2.0.8/Post/Views.h 2007-07-09 22:54:37.000000000 +0900
|+++ gmsh-2.0.8.new/Post/Views.h 2007-08-20 13:01:16.000000000 +0900
File to patch:
why? Can anyone help me?
dante is offline   Reply With Quote
Old   February 24, 2008, 18:59
Default Hi, Dante, If you are sure yo
Takuya OSHIMA
7islands is on a distinguished road
Hi, Dante,
If you are sure you replaced $WM_PROJECT_DIR and YYYYMMDD as appropriate, it might be a version incompatibility of diff and patch. I had another report stating the same problem on this forum but still haven't got conclusion. What version of patch are you using (patch --version)?
Takuya
7islands is offline   Reply With Quote
Old   February 25, 2008, 10:33
Default Hi Takuya, Of course I use th
Dante De Santis
Hi Takuya,
Of course I use the correct names for $WM_PROJECT_DIR and YYYYMMDD. The pathc version on my computer is: "patch 2.5.9".
Old   February 25, 2008, 19:56
Default Hi Dante, I tried 2.5.9 but
Takuya OSHIMA
Hi Dante,
I tried 2.5.9 but could not reproduce the problem... Meanwhile I changed the way to take diffs to a standard manner since the diff included in the gmshFoam package was taken in a bit unusual way. Could you try it and report how it works?
gmsh-2.0.8-foam-20070905-patchFix.diff.bz2
Takuya
BuoyantBoussinesqSimpleFoam_Facing problem Mondal131211 OpenFOAM Running, Solving & CFD 1 April 10, 2019 19:41
Gmsh problem liub Mesh Generation & Pre-Processing 0 December 17, 2015 13:26
[OpenFOAM.com] I have problem in install openFoam 1.5 emadhamdy OpenFOAM Installation 4 October 24, 2015 23:55
[Gmsh] problem converting mesh from gmsh Fried OpenFOAM Meshing & Mesh Conversion 8 October 18, 2011 08:53
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
