[Gmsh] Problem with Gmsh
Like Tree4Likes
Old   November 23, 2007, 12:09
Default Problem with Gmsh
Nishant
nishant_hull is on a distinguished road
Hi all..
I am trying to simulate naca aerofoil on foam using mesh from gmsh. i created a mesh using gmsh and convert it to foam polmesh format using gmshToFoam. I am repeatedly getting this warning...
--> FOAM Warning : Not using gmsh face 4(64 122 123 65) since zero vertex is not on boundary of polyMesh
--> FOAM Warning :
From function gmshToFoam
in file gmshToFoam.C at line 799
Could not match gmsh face 4(64 122 123 65) to any of the interior or exterior faces that share the same 0th point
However it is getting executed and I am getting polymesh directory with all files. but again... the files are reading just the points and not the faces or boundaries etc.
patches in boundary files are even taking nFace=0 and startface=0 in all patches.
The .geo file for my mesh is as follows:
Point (137) = {0.999972181112207, -3, 0.4, 0.1};
Point (138) = {0.999972181112207, -3, 0.5, 0.1};
Line (26) = {57, 61};
Line (27) = {59, 62};
Line (31) = {60, 66};
Line (35) = {58, 70};
Line (42) = {25, 77};
Line (43) = {102, 50};
Line (62) = {128, 77};
Line (63) = {25, 127};
Line (64) = {102, 130};
Line (65) = {50, 129};
Line (66) = {61, 128};
Line (67) = {70, 128};
Line (68) = {57, 127};
Line (69) = {58, 127};
Line (70) = {127, 128};
Line (71) = {62, 130};
Line (72) = {130, 129};
Line (73) = {59, 129};
Line (74) = {130, 66};
Line (75) = {129, 60};
CatmullRom (76) = {77, 126, 125, 124, 123, 122, 121, 120, 119, 118, 117, 116, 115, 114, 113, 112, 111, 110, 109, 108, 107, 106, 105, 104, 103, 102};
CatmullRom (77) = {102, 101, 100, 99, 98, 97, 96, 95, 94, 93, 92, 91, 90, 89, 88, 87, 86, 85, 84, 83, 82, 81, 80, 79, 78, 77};
CatmullRom (78) = {50, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25};
CatmullRom (79) = {25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50};
Line (108) = {136, 77};
Line (109) = {25, 135};
Line (110) = {102, 138};
Line (111) = {137, 50};
Line (112) = {138, 137};
Line (113) = {136, 135};
Line (114) = {132, 77};
Line (115) = {25, 131};
Line (116) = {132, 131};
Line (117) = {134, 133};
Line (118) = {133, 50};
Line (119) = {102, 134};
Line (124) = {61, 132};
Line (125) = {132, 134};
Line (126) = {134, 62};
Line (127) = {57, 131};
Line (128) = {131, 133};
Line (129) = {133, 59};
Line (130) = {70, 136};
Line (131) = {136, 138};
Line (132) = {138, 66};
Line (133) = {60, 137};
Line (134) = {137, 135};
Line (135) = {135, 58};
Line Loop (121) = {77, -42, 79, -43};
Plane Surface (121) = {121};
Line Loop (123) = {76, 43, 78, 42};
Plane Surface (123) = {123};
Line Loop (137) = {135, 35, 130, 113};
Plane Surface (137) = {137};
Line Loop (139) = {134, -113, 131, 112};
Plane Surface (139) = {139};
Line Loop (141) = {133, -112, 132, -31};
Plane Surface (141) = {141};
Line Loop (143) = {67, 62, -108, -130};
Plane Surface (143) = {143};
Line Loop (145) = {108, -77, 110, -131};
Plane Surface (145) = {145};
Line Loop (147) = {64, 74, -132, -110};
Plane Surface (147) = {147};
Line Loop (149) = {69, -63, 109, 135};
Plane Surface (149) = {149};
Line Loop (151) = {109, -134, 111, -79};
Plane Surface (151) = {151};
Line Loop (153) = {65, 75, 133, 111};
Plane Surface (153) = {153};
Line Loop (155) = {118, 65, -73, -129};
Plane Surface (155) = {155};
Line Loop (157) = {65, -72, -64, 43};
Plane Surface (157) = {157};
Line Loop (159) = {63, 70, 62, -42};
Plane Surface (159) = {159};
Line Loop (161) = {71, -64, 119, 126};
Plane Surface (161) = {161};
Line Loop (163) = {119, -125, 114, 76};
Plane Surface (163) = {163};
Line Loop (165) = {129, 27, -126, 117};
Plane Surface (165) = {165};
Line Loop (167) = {128, -117, -125, 116};
Plane Surface (167) = {167};
Line Loop (169) = {127, -116, -124, -26};
Plane Surface (169) = {169};
Line Loop (171) = {114, -62, -66, 124};
Plane Surface (171) = {171};
Line Loop (173) = {118, 78, 115, 128};
Plane Surface (173) = {173};
Line Loop (175) = {63, -68, 127, -115};
Plane Surface (175) = {175};
Line Loop (177) = {73, -72, -71, -27};
Plane Surface (177) = {177};
Line Loop (179) = {75, 31, -74, 72};
Plane Surface (179) = {179};
Line Loop (181) = {70, -66, -26, 68};
Plane Surface (181) = {181};
Line Loop (183) = {69, 70, -67, -35};
Plane Surface (183) = {183};
Line Loop (189) = {42, -114, 116, -115};
Plane Surface (189) = {189};
Line Loop (191) = {119, 117, 118, -43};
Plane Surface (191) = {191};
Line Loop (193) = {109, -113, 108, -42};
Plane Surface (193) = {193};
Line Loop (195) = {111, -43, 110, 112};
Plane Surface (195) = {195};
Surface Loop (185) = {143, 183, 149, 151, 139, 137, 145, 121, 147, 179, 153, 141, 157, 159};
Volume (185) = {185};
Surface Loop (187) = {163, 161, 177, 155, 173, 123, 175, 181, 171, 169, 167, 165, 159, 157};
Volume (187) = {187};
Physical Surface ("Inlet_5") = {137, 139, 141, 181, 183};
Physical Surface ("outlet_5") = {165, 167, 169, 177, 179};
Recombine Surface {163,171,161,177,143,145,147,157,121,159,175,181,1 83,137,139,141,149,151,173,155 ,153,179,165,167,169};
Thanks and regards,
Nishant
nishant_hull is offline   Reply With Quote
Old   November 23, 2007, 12:14
Default I again try to export mesh for
Nishant
I again try to export mesh for a simple cube geometry ...
and then again the problem is same..
I am getting the same warning.
and similarly gmshToFoam is getting executed and I am getting polymesh directory with all files. but again... the files are reading just the points and not the faces or zones etc.
patches in boundary file is even taking nFace=0 and startface=0 in all patches.
Point(1) = {-1,1,0,0.1};
Point(2) = {1,1,0,0.1};
Point(3) = {1,-1,0,0.1};
Point(4) = {-1,-1,0,0.1};
Line(1) = {3,4};
Line(2) = {4,1};
Line(3) = {2,1};
Line(4) = {2,3};
Line Loop(5) = {4,1,2,-3};
Plane Surface(6) = {5};
Extrude {0,0,1} {
Surface{6};
Physical Surface(29) = {23};
Physical Surface(30) = {23};
Physical Surface(31) = {19};
Physical Surface(32) = {27};
Physical Surface(33) = {15};
Surface Loop(34) = {28,15,6,19,23,27};
Volume(35) = {34};
please suggest in this reagrd...
with regards ..
Nishant
Thanks and regards,
Nishant
Old   November 23, 2007, 20:05
Default Hi Nishant, Note that Gmsh on
Takuya OSHIMA
7islands is on a distinguished road
Hi Nishant,
Note that Gmsh only writes mesh for the parts where physical entities are defined if you define any physical entities. Thus you need to define physical surfaces for all the surfaces and a physical volume for the volume. For your cube case with some other corrections your .geo will be
Line(1) = {3,4};
Line(2) = {4,1};
Line(3) = {2,1};
Line(4) = {2,3};
e1[] = Extrude {0,0,1} {
Surface{6};
Physical Surface(29) = {e1[0]};
Physical Surface(30) = {e1[2]};
Physical Surface(31) = {e1[3]};
Physical Surface(32) = {e1[4]};
Physical Surface(33) = {e1[5]};
Surface Loop(34) = {6,e1[0],e1[2],e1[3],e1[4],e1[5]};
Physical Surface(1) = {6};
Physical Volume(1) = {e1[1]};
(you need Gmsh version >= 2.0.7 to load the corrected .geo). And if you'd like to use string labels for physical entity definitions ("Inlet_5" and "outlet_5" in your airfoil case) you want to try gmsh2ToFoam that comes with the gmshFoam package instead.
Takuya
7islands is offline   Reply With Quote
Old   November 26, 2007, 14:49
Default Thanks Takuya .. My mesh i
Nishant
Thanks Takuya ..
My mesh is generated now. However I am getting following error:
--> FOAM FATAL IO ERROR :
patch type 'patch' not constraint type 'empty'
for patch defaultFaces of field p in file "/home/343880/OpenFOAM/343880-1.4.1/run/tutorials/sonicTurbFoam/gmsh/0/p"
file: /home/343880/OpenFOAM/343880-1.4.1/run/tutorials/sonicTurbFoam/gmsh/0/p::default Faces from line 57 to line 57.
From function emptyFvPatchField<type>::emptyFvPatchField
const fvPatch& p,
const Field<type>& field,
const dictionary& dict
in file fields/fvPatchFields/constraint/empty/emptyFvPatchField.C at line 101.
FOAM exiting
Can you make any comment? Where could possibly be the error?
thanks in advance ..
regards..
Nishant
Thanks and regards,
Nishant
Old   November 27, 2007, 08:13
Default Hi Nishant, I can't say for s
Takuya OSHIMA
Hi Nishant,
I can't say for sure with all the information you provided, but I guess you are trying to do a two dimensional computation by setting the third dimensional patch type to empty. If that's the case make sure the base patch types of both the mesh (constant/polyMesh/boundary) and the initial field file (0/p) are set to empty.
Takuya
Old   November 30, 2007, 07:15
Default Hi Takuya.. Thanks. I am s
Nishant
Hi Takuya..
Thanks. I am still getting this error:-
Selecting turbulence model LaunderSharmaKE
Creating field DpDt
--> FOAM FATAL ERROR : This mesh contains patches of type empty but is not 1D or 2D
by virtue of the fact that the number of faces of this
empty patch is not divisible by the number of cells.
From function emptyFvPatchField<type>::updateCoeffs()
in file fields/fvPatchFields/constraint/empty/emptyFvPatchField.C at line 148.
FOAM exiting
I guess.. I have some problem with the plane surafe generation at the fin. Can you suggest what standard method should I use for it?
Thanks and regards,
Nishant
Old   November 30, 2007, 07:27
Default I guess.. I have some problem
Nishant
I guess.. I have some problem with the plane surafe generation at the airfoil surface (where I need to put the boundary condition). Can you suggest what standard method should I use for it in gmsh?
Please see your email where I send my mesh file.
With regards ..
Nishant Singh
Thanks and regards,
Nishant
Old   November 30, 2007, 19:03
Default Hi Nishant, As of now I still
Takuya OSHIMA
Hi Nishant,
As of now I still haven't received a mail from you... maybe sent to some wrong address? Could you post the .geo here via the attachment feature since I prefer to have all the discussions on the board (to use the attachment feature, see the Formatting section under the Documentation tree in the pane left of the board screen).
Takuya
Old   December 2, 2007, 11:56
Default Hi Takuya .. Sorry for repl
Nishant
Hi Takuya ..
Sorry for replying late. The .geo and mesh file is attached here.
aerofoil-quater2
aerofoil
Thanks and regards,
Nishant
Old   December 2, 2007, 12:29
Default Do not use the aerofoil mesh f
Nishant
Do not use the aerofoil mesh file. thats not the right file. Sorry fpr attaching that.
Plese check the way I describe the aerofoil surface plane in the .geo file. I would be glad to see ur comments in this regard.
and Thanks you for, letting me know the attachment related links.
Nishant Singh
Thanks and regards,
Nishant
Old   December 2, 2007, 13:11
Default Please overlook the previous f
  #11
Nishant
Please overlook the previous files and see these files:-
aerofoil-quater2
boundary
U
Thanks and regards,
Nishant
Old   December 3, 2007, 04:48
Default Hi Nishant, In a nutshell, in
  #12
Takuya OSHIMA
Hi Nishant,
In a nutshell, in OpenFOAM a 2D case should consist of an extruded surface mesh, i. e. a mesh with the identical bottom and top patches of type empty and with a single cell height.
Here I'm attaching a corrected .geo and other files for minimal setup copied from the sonicTurbFoam/nacaAirfoil case with appropriate patch name corrections. You'll need Gmsh version >= 2.0.7 and gmsh2ToFoam to convert the .geo to the polyMesh format. Also note that you would want to correct the case setup as necessary since other than the patch name changes the case setup is verbatim from the nacaAirfoil case (I only confirmed the case runs at least up to 1e-5 s).
nishantAirfoil.tar.gz
Takuya
Old   December 3, 2007, 08:57
Default Thanks for the help Takuya. I
  #13
Nishant
Thanks for the help Takuya. I hope to proceed further now. However I have few problem with my set up of Foam. I could not be able to recompile my Foam package. So I wanted to ask, if the gnsh2ToFoam need recompilation of complete Foam or just the binaries of the package will do? Let me know. I am using Openfoam 1.4.1.
Thnak you once again
Nishant
Thanks and regards,
Nishant
Old   December 3, 2007, 09:30
Default You can download and read usag
  #14
Takuya OSHIMA
You can download and read usage instructions of gmsh2ToFoam here. You just have to compile the gmshFoam package and no necessity of recompiling the whole OpenFOAM sources. Or if the installation procedure seems too much of work to you, just using the stock gmshToFoam with some hand-editing constant/polyMesh/boundary after conversion will do (you have to do the hand-editing every time you do the conversion though).
Takuya
Old   December 3, 2007, 16:02
Default Hi Takuya... Thank you so
  #15
Nishant
Hi Takuya...
Thank you so much. I really like the gmsh2ToFoam. Its a excellent piece of work. I could be able to run the sonicTurbFoam case.
Thank you for the help
Nishant
Thanks and regards,
Nishant
Old   December 6, 2007, 08:31
Default Hi Takuya, Your example fil
  #16
maitre touf
touf is on a distinguished road
Hi Takuya,
Your example file is very good.
Please just one question: How GMSH is numbering when extruding?
I saw that results from extrusion are stocked to arrays (e1[] and e2[]), but I didn't find how to know which number in the array is face, volume,...
Touf
touf is offline   Reply With Quote
Old   December 6, 2007, 23:06
Default Hi Touf, Well, it's a bit dif
  #17
Takuya OSHIMA
Hi Touf,
Well, it's a bit difficult to explain... Let's take the Nishant's case for example:
e1[] = Extrude {0, 0, 0.1} {Surface{149, 151, 153}; Layers{1}; Recombine;};
In this case the elements of the array e1[] are
e1[0]: the id of the extruded opposite surface of the first surface specified in the Extrude command (Surface 149)
e1[1]: the id of the extruded volume of Surface 149
e1[2] - e1[5]: the id's of the lateral surfaces, in the order of the Lines 69, 63, 109 and 135 in the corresponding "base" Line Loop 149, which constructs Surface 149
e1[6]: the id of the extruded opposite surface of the second surface specified in the Extrude command (Surface 151)
e1[7]: the id of the extruded volume of Surface 151
e1[8]-e1[11]: the id's of the lateral surfaces, in the order of the Lines 109, 134, 111 and 79 in the corresponding "base" Line Loop 151, which constructs Surface 151
e1[12] - e1[17]: same as in the first two surfaces specified in the Extrude command, but for Surface 153
The order of the lateral surfaces may not be guaranteed since AFAIK it is undocumented. Hope you get the idea
Takuya
Old   December 7, 2007, 01:33
Default Hi Takuya, Thanks for the exp
  #18
maitre touf
Hi Takuya,
Thanks for the explainations, it's now more clear
Touf
Old   April 22, 2015, 08:43
Default gmsh problem
  #19
Rafael Marques
rafa13 is on a distinguished road
Hi everybody,
I am struggling hart wirh the periodic line command on gmsh, i am trying to create mesh a triangular geometry with quads and triangles. I want to force 2 line to connect each other with the mesh...simply straight lines but it doesn't work for know! maybe some body with a idea?
someone knows how to use the periodic line command on gmsh?
I searched in many places on the internet but there isn't many information about this command.
greetings and thanks to all
Rafa marques
rafa13 is offline   Reply With Quote
Old   July 31, 2015, 05:10
KateEisenhower is on a distinguished road
Takuya
Hello foamers,
I have some problem with gmshToFoam producing a default patch. Could gmsh2ToFoam help me here or is gmshToFoam already corrected. I am asking because the cited post is from 2007.
Any help is appreciated! Best regards,
Kate
KateEisenhower is offline   Reply With Quote
Problem diverges when exhaust valve opens swerner0711 AVL FIRE 0 September 21, 2018 07:14
[Gmsh] gmsh meshing problem CHAYANIT OpenFOAM Meshing & Mesh Conversion 0 September 5, 2018 08:08
Gmsh problem liub Mesh Generation & Pre-Processing 0 December 17, 2015 13:26
[Gmsh] gmsh problem djamel OpenFOAM Meshing & Mesh Conversion 0 January 7, 2014 13:02
[Gmsh] Ubuntu 12.10 Gmsh installation problem sudo OpenFOAM Meshing & Mesh Conversion 0 November 7, 2013 12:47
