GmshToFoam
Hi
I am trying to convert the "CubeVer1.msh" (present in $FOAM_UTILITIES/mesh/conversion/gmshToFoam/). I created a case gmshTest in $FOAM_RUN/tutorials/icoFoam/ and then executed the following command gmshToFoam $FOAM_RUN/tutorials/icoFoam/ gmshTest $FOAM_RUN/tutorials/icoFoam/gmshTest/CubeVer1.msh and got the following output /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.3 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : gmshToFoam /home/vxv/OpenFOAM/varun-1.3/run/tutorials/icoFoam/ gmshTest /home/vxv/OpenFOAM/varun-1.3/run/tutorials/icoFoam/gmshTest/CubeVer1.msh Date : Nov 30 2007 Time : 18:49:21 Host : sarkeshwar PID : 30400 Root : /home/vxv/OpenFOAM/varun-1.3/run/tutorials/icoFoam/ Case : gmshTest Nprocs : 1 Create time Read nVerts:167 Read nElems:838 Mapping region 27 to Foam patch 0 Mapping region 28 to Foam patch 1 Mapping region 29 to Foam patch 2 Mapping region 30 to Foam cellZone 0 Cells: total:622 hex :0 prism:0 pyr :0 tet :622 Patches: Patch Size 0 36 1 36 2 144 CellZones: Zone Size 0 622 --> FOAM Warning : From function polyMesh::polyMesh(... construct from shapes...) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 573 Found 216 undefined faces in mesh; adding to default patch. Finding faces of patch 0 Finding faces of patch 1 Finding faces of patch 2 FaceZones: Zone Size Writing zone 0 to cellZone cellZone_0 and cellSet End After running the solver, I use the followign command for opeining the case in paraFoam paraFoam $FOAM_RUN/tutorials/icoFoam/ gmshTest When I click accept, paraFoam crashes with folowing error: /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.3 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ --> FOAM FATAL IO ERROR : attempt to read beyond EOF file: /home/vxv/OpenFOAM/varun-1.3/run/tutorials/icoFoam//gmshTest/0/p::internalField at line 30. From function ITstream::read(token& t) in file db/IOstreams/Tstreams/ITread.C at line 70. FOAM exiting I am new to OpenFoam. I will be extremely grateful if somebody could help. Thanks Varun |
gmshToOpenFoam
Hi Varun, I am new user of OpenFOAM and I have the same problem. How I will solve this? COuld you please help me? Thanks Goutam |
Maybe you forgot some semicolon - ';' at the end of line in you 0/p file.
Additionally, when executing gmshToFoam on you *.msh file, you need to do some minor changes in your constant/polymesh/boundary file (change patch types, ...). So for start, please post your: -/home/vxv/OpenFOAM/varun-1.3/run/tutorials/icoFoam//gmshTest/0/p -/home/vxv/OpenFOAM/varun-1.3/run/tutorials/icoFoam//gmshTest/constant/polymesh/boundary files, to see if there are some corrections needed. |
Gmsh
1 Attachment(s)
Dear friends,
Could you please see my attached files. You will find my cubic.geo, cubic.msh, and 0/p , 0/U files. Thanks |
Hi all,
Was there a solution to this problem I am having similar difficulties, I tried to copy the bubbleFoam tutorial folder and copied my .msh file into the case directory and ran gmshToFoam from this directory. I get the following output: /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.0.1-51f1de99a4bc Exec : gmshToFoam approx_profile.msh Date : Mar 13 2012 Time : 19:04:53 Host : matthew-desktop PID : 3326 Case : /home/matthew/Documents/FYP/OpenFOAM/TEST_CASE_1/PARABOLIC_TANK nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Starting to read mesh format at line 2 Read format version 2.2 ascii 0 Starting to read points at line 5 Vertices to be read:1032 Vertices read:1032 Starting to read cells at line 1040 Cells to be read:5271 Unhandled element 15 at line 1042 Unhandled element 15 at line 1043 Unhandled element 15 at line 1044 " " " " " 1045 Unhandled element 15 at line 1053 Unhandled element 1 at line 1054 Unhandled element 1 at line 1055 " " " " " 1056 Unhandled element 1 at line 1225 Mapping region 0 to Foam patch 0 Mapping region 0 to Foam cellZone 0 Cells: total:3219 hex :0 prism:0 pyr :0 tet :3219 CellZones: Zone Size 0 3219 Skipping tag at line 6314 Patch 0 gets name patch0 --> FOAM Warning : From function polyMesh::polyMesh(... construct from shapes...) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 614 Found 1868 undefined faces in mesh; adding to default patch. Finding faces of patch 0 FaceZones: Zone Size Writing zone 0 to cellZone cellZone_0 and cellSet End What corrections would be required in ploymesh/boundary and 0/p files? What are unhandled elements? And what has caused undefined faces to occur? I forgot to mention running paraFoam crashed and I got the following error: --> FOAM FATAL IO ERROR: size 1875 is not equal to the given value of 3219 file: /home/matthew/Documents/FYP/OpenFOAM/TEST_CASE_1/PARABOLIC_TANK/0/p from line 17 to line 1921. From function Field<Type>::Field(const word& keyword, const dictionary&, const label) in file lnInclude/Field.C at line 236. FOAM exiting Cheers |
