-   Open Source Meshers: Gmsh, Netgen, CGNS, ... (http://www.cfd-online.com/Forums/openfoam-meshing-open/)
-   -   DecomposePar and sets (http://www.cfd-online.com/Forums/openfoam-meshing-open/61894-decomposepar-sets.html)
jhierroa January 2, 2007 22:32
I am interested in knowing whe
I am interested in knowing whether there is any way to work with a mesh divided into different sets (for instance rings around a central cylinder with different transport coefficients) where the final computation of the equations is, moreover, divided into different processors (with divisions along the z axis).
In other words:
Let it be a cylinder with rings around it with different transport properties and each cylinder is modelled by a different set (cellSet is used in the main code to set the transport properties in each ring). Is there any chance to compute the resulting system in parallel?
NOTE: a standard use of decomposePar works fine with everything (faces, nodes, points, patches, ...) except for the definition of the different sets which are not decomposed among the different processors.
